Question about Kenmore Dryers
Cant install my belt back on my idler pully on my kenmore 80 series dryer . the idler pully i have is a piece of metal below but it does not open up so the belt will go through. i am missing something but i do not know what.
    Sergeant:
    Champion:
  • 278 Answers
Howdy: Check for the bolts that hold the pully on. Loosen the bolts and the pully should stat to open. You may have to put on the belt then install the pully. Look close at it. Good luck - Doug
Posted on Dec 09, 2009
Model# 110.72602101 Kenmore Dryer I had ordered the belt replacement but the instructions show an Idler Pully but I don't seem to have the wheel that goes on it. Not sure how this belt is to be...
you must have the older style pulley that's all metal with no wheel.rap the belt around the drum,on the side where the pulley is pinch the belt together stick it under the half moon part of your metal pulley and stick the looped end around the motor shaft,if i were you i'd call the place where you bought the belt from give them the model number and order a belt kit,you get the belt,the rollers and the pulley with the wheel not that metal **** piece and replace it,you get all those parts for short money,cheaper than buying them seperate or use it for now until it starts getting noisy.let me know how you make out and if you need anymore help let me know
Aug 05, 2010 | Kenmore 60172 Electric Commercial Dryer
How do I take the top off of a Kenmore 80 Series?
You remove the back panel that is how your get to everything. once the back panel is removed you will be able to put the belt and the idler pulley on. Please rate
May 24, 2010 | Kenmore 64852 Electric Dryer
With the Kenmore series 80 Dryer plugged in, Pressing the start button causes the motor to hum as if the belt, pully or motor is frozen. The drum doesn't turn during the humming and is difficult to turn...
You'll need to remove the back panel and determine the cause. Look for:
Seized drum support rollers (3)
Seized drive and/or idler pulleys
Burned out or seized motor
Possible bad motor start capacitor (if equipped)
Drum alignment
Mar 29, 2009 | Dryers
KENMORE SERIES 80 DRYER..The Tensioner use it or not and how?
To fit the new belt, you will need the idler pulley (tensioner)...
The idler pulley fits in the slots on the bottom of the cabinet (in front of the motor) with the wheel or glide facing the left side. Place the belt (grooves inward) around the drum. Pull the belt through the middle of the idler pulley from the left side. Once the belt is pulled through the idler pulley, pull it around the motor pulley (this should force the idler pulley to "open up" and add tension).
If you still need help, I will try to provide you with a diagram shortly.
Mar 02, 2009 | Kenmore 62622 Electric Dryer
Show me how the belt should be run
Stick the idler in the floorboard, even with the motor pulley and have the idler wheel facing to the left of that motor pulley. Insert the non twisted belt into the idler between the cheapass metal idler pulley mount(have yer woman hold that drum up, make her proud to assist) and now yank back on the idler good nuff to get that belt looped over that motor pully. Then let that idler go so the tenshun on dat boy cause dat belt to stay all propah on dat pulley. Replace that front panel. 05cc3f4.jpg
Belt config
If you need further help, reach me via phone at https://www.6ya.com/expert/dan_73bbd84fe1d95b61
Feb 26, 2009 | Kenmore 62802 Electric Dryer
Belt busted
lets see what we can do. wrap the belt around hte tub assy. the little white roller w/ metal arm (called the tension pulley) needs to be installed .there should be a few ****s directly under ther motor pulley on floor of unit.two sets of ****s you wanna use the set to ther rear of unit. insert the prongs into the left rear **** and then pull the roller portion to the right.(it should hook the back prongs of idler into the rt side ****s. tension holds this into position so it will fall out if you let go) theres an opening in the metal under the roller mounts, e**ugh room to slide the belt through.heres how it works, install the idler as described above, feed the belt through the opening in the idler from the left and under roller through hole pull hte roller and pulley hard to the right.(its springy and as long as installed correctly ** worry of popping out) and loop around the motor pulley.let go of the pulley. and the belt should remain tensioned. it will only go on on way. GOOD LUCK
Mar 10, 2008 | Kenmore 63942 Dryer
Idler pully
there has to be a spring on the idler to keep it pulled against the belt
Mar 01, 2008 | Kenmore 62622 Electric Dryer
Makes squeaking noise after running for about 10 minutes
you can check a lot of things. the motor itself, the rollers on the back, and the main bearing at the center of the drum. you can apply any lubricants to all of those rolling parts.
Feb 12, 2008 | Kenmore 84152 Electric Dryer
Dryer drum does not turn
how about the idler pully that keeps the belt tight did you see it in there has to be there look if its is ther try to turn the drum by hand a foregin object could be jaming the tub im here to help get back and let me know
Dec 29, 2007 | Dryers
Kenmore 80 series dryer.
true story.I brought my lawnmower to a friend of mine,i said to him Tony my lawnmore is making a terrable noise, he said to me worry when its making no noise...its possable a worn tension pully it would make a rattle like sound,Solution replace pully wheel!.Top of the morning to you Eire
Nov 15, 2007 | Kenmore 63942 Dryer
Dryers Logo
98 people viewed this question
Top Kenmore Dryers Experts
Sal De
Marvin
Marvin
Are you a Kenmore Dryer Expert? Answer questions, earn points and help others
