Question about Lenovo ThinkPad R51
Screen darkening from right side
My display is darkening, light wise, along the right & left edges of the screen from about 2" out getting darker as you near the edge. The LCD image is still sharp in this area which leads me to believe that it is backlight related. I was wondering if:
1. this is an indicator of s future failure of the inverter or backlight?
2. could this be dirt and just need the tubes to be cleaned?
3. what you think the problem is
Model R51 1830-UUB
Thank you!
    Genius:
  • 1,067 Answers
1 lool
change lcd panel ok
Posted on Jan 19, 2008
I have a 42 lg lcd tv when i switch it on the right side of the screen is darker than the left also there is a vertical bar about 1" at the edge
Be careful using this TV. There is a fault somewhere. No TV should ever do that, cold or not. Replace or repair it
Nov 24, 2017 | LG 42LC2D 42 in. LCD HDTV
Can This Mix of Display Problems Be Fixed ??
It most likely is all on the main signal process board which would have to be located and installed to see if it cures the troubles.
Mar 13, 2012 | JVC LT37XM48 LCD TV
How to make the images darker
Push the 'OSD' ("On Screen Display") button on the bottom-edge of the monitor.
Use the LEFT/RIGHT buttons to select BRIGHTNESS or CONTRAST.
Use the OK button to choose that selection.
Use the LEFT/RIGHT buttons to decrease/increase the BRIGHTNESS.
Use the OK button to confirm the setting.
Use the LEFT/RIGHT buttons to select CONTRAST.
Use the LEFT/RIGHT buttons to decrease/increase the CONTRAST.
Push the 'OSD' button to exit from the OSD.
Jun 01, 2011 | Acer AL1916W 19" LCD Monitor
I have the VL193 monitor attached to my laptop via blue cable, have checked all connections and display options, resolution, etc. The desktop background photo appears on the monitor but no Windows icons or...
connect external monitor and look it works properly or not .if problem persists , then format and reinstall the' operating system' . use licenced OS(operating system) to install . before that verify that all drivers are present or not . if not , then take the back up of the drivers .
Apr 19, 2010 | Princeton Digital VL193 19 in. Flat Panel...
Samsung syncmaster 914v monitor problem. right side of display is darker image. can see dots like a newspaper print or looking through a screen. when display is black it almost appears like an image is...
This is likely the LCD panel itself - you are describing a left/right image error that can be only created by the left/right division by the LCD driver wrapped around the outside of the LCD panel.
If your monitor uses a separate circuit board to drive the LCD, it could be this driver board.
Either way, it will require an LCD panel - $$$
Mar 29, 2010 | Samsung SyncMaster 914V 19" LCD Monitor
Vertical gray stripe on left edge, all pics and text gave a blur
any vertical or horizontal line (any color any size) showing stable on the screen that is the hardware damage at the LCD panel back board ( call panel driver board) . it repair complicate but easy to do change LCD panel (common parts). you need find a PC service dealer to do so.
Feb 07, 2009 | Dell E207WFP LCD Monitor
Black smudge marks along left side edge of paper.
Its probably a defective toner. If the film on the toner drum is scratched it can cause toner to stick to the drum everytime it spins causing the constant marks.
Jul 08, 2008 | HP LaserJet 1320 Printer
Dark band on left side, Samsung HL-R5668W
the reflecting mirror is likely loose and falling down inside the light reflecting tube. you should have seen the band getting darker and larger,
the small mirror is in front of the lamp and bends the light,
remove the lamp and look down the tube (light path)
May 06, 2008 | Televison & Video
Dark Vertical Stripe on Right Edge of Screen
I experienced the same approx. 1/2" vertical stripe on a Viewsonic vx1945 and ATI Radeon x1050 video adapter on Vista Business SP1, but the stripe appeared along the left edge of the screen, instead of right edge. I then temporarily decreased the monitor resolution, and the stripe went away. I then increased the monitor resolution back to its original setting, and the stripe did not re-appear. So, that was the 'fix' in my situation, hope this helps.
Dec 11, 2007 | Westinghouse LTV-32w4 32.02 in. LCD HDTV
Computers & Internet Logo
96 people viewed this question
Top Lenovo Computers & Internet Experts
Michael Vincent Cruz
Are you a Lenovo Computer and Internet Expert? Answer questions, earn points and help others
