Question about IBM ThinkCentre A30 PC Desktop
Integrated network not working
Integrated network card not working
  • Eric May 11, 2010
    More information please. How is it "Not working?" What have you done so far? What symptoms are you seeing?
    New Friend:
  • 99 Answers
Install driver Intel Broadcom lan driver.or enable bios configure.
Posted on Dec 09, 2009
SOURCE:
I need to know whether the ethernet card for the Optiplex GX 240 is integrated in the motherboard or it is a card in itself. Thank you.
Pretty much every computer built within the last 5 years has built on network interface. However, to answer your question completely - look at the back of the computer where the network cable plugs in? Is it clustered around the video/sound, power, printer, usb, etc (integrated in); or is it located elsewhere (perhaps in the series of long narrow rectangular openings openings where the expansion cards go - separate).
Hope this helps.
Jun 02, 2011 | Dell Ethernet Card Network Adapter
Integrated 10/100 Network Card for HP Pavillion a705w: My brother-n-law HP Pavillion a705w is dropping it's internet connection after about 2 minutes. We thought it was the Cable Modem Box (Motorola)......
Hello my name is Israel. On your type of cpu your network card is integrated into th emother board. YOu can purchase one and just connect it inot one of the slots. the instructions as well as the software should be included in the package. It will be a very painless installation. You can probably get a dlink network card at Best Buy for about $15. Good Luck.
Feb 15, 2011 | HP Pavilion a705w PC Desktop
What is NIC?
Network Interface Card.It allows you to connect to a network.Most common cards are PCI 10/100 ethernet network cards.NICs can be integrated into a motherboard which knows as an Onboard card.
Aug 12, 2010 | LaCie Computers & Internet
I need to replace the Ethernet card but I see no card. All the Ethernet/USB ports are linked together in a small box. They look like they go directly into the motherboard. Suggestions???? I checked all the...
Sure you can't see the Ethernet card because that is integrated motherboard so that means all the controller cards(graphic, audio, network) are in same place in chip set.
First try to uninstall network drivers and to install again if that will not work you can install PCI network card (they are very cheap).
Jul 24, 2010 | Dell XPS 410 PC Desktop
I have Dell Opitiplex gx270 it looks like there are no cards on board. Trying to connect to the internet, says no network adapter cards found. wont let click on to the internet. I have other cards, I...
The network card (also the sound and video) is integrated onto the motherboard on this computer. You probably just need to install the drivers. You can download the drivers from Dell here. Also make sure the onboard network hardware is enabled in the computer's BIOS setup. (If you didn't use a restore set from the manufacturer and just install Windows, you almost always need to install the drivers for integrated hardware.)
Mar 30, 2010 | Computers & Internet
I have a gate way laptop with Intel® PRO/Wireless 802.11g integrated wireless 10/100/1000 Mbps integrated Ethernet LAN card, i cannot connect to my wi-fi network, is it possible that the wi-fi card is...
Wi-Fi card can be considered broken only if its not able to scan for any available networks. Also, do check in the device manager of the computer. Check for the device status of this wireless adapter there. If its properly installed, etc., it should say, "This device is working properly". There is also a fix for other error messages. Regarding hardware breakage, we cannot come to a conclusion so easily as we have all these things to check. The case may be little complicated as its an in-built wireless card. We cannot even remove it and try on a different computer.
Mar 17, 2010 | Intel PRO/Wireless 2200BG 802.11g/b
Need network card driver
Try this or this. One should work on 2003 even though it's not listed.
nLinked
Computer Support Services
Jun 01, 2009 | Intel Computers & Internet
Does dell dimension 2400 have ethernet card inside?? Basically when dell made the dimension 2400, did the put an ethernet card inside. Or do i have to buy one and install it myself? I have this Broadcom...
The 10/100 Integrated controller is the onboard network card
That basically mean yes it does have a network card built onto the motherboard.
If this helped please leave a Rating
Best of luck
Blazamane.
Jan 08, 2009 | Dell Dimension 2400 PC Desktop
Dell 4700 Computer Integrated NIC Problem
Check for the pins inside the integrated NIC to check if the pins are bent / disfigured. Does not look like the additional card is making any different, looks more like a moving NIC cable is makin the difference.
Lemme know if this helped!
Dec 13, 2008 | Dell Ethernet Card Network Adapter
Network connection
It probably stops working due to the heat. The solder connection to the motherboard may not be up to par. To get round it I would purchase a PCI network card and use that instead. If the mouse bothers you, you can always unplug it, but it is something that you dont need to worry about.
Mar 22, 2008 | Computers & Internet
IBM ThinkCentre A30 PC Desktop Logo
101 people viewed this question
Top IBM Computers & Internet Experts
Alun Cox
Steve Allison
Steve Allison
Are you an IBM Computer and Internet Expert? Answer questions, earn points and help others
