Question about Remington At3017b Hedge Wizard
Wizard stopped working. worked fine, shut off,
Wizard stopped working. worked fine, shut off, started in again and it wouldn't start. completely dead
I have had battery and alternator checked, both are good. Battery was dead, jumped car, started and ran fine. Drove 30 minutes, shut off and sat for 2 hours. Started fine again, just went to gas station...
Most likely you have a bad battery. The second option is that you have a faulty wiring and there is a constant load that takes a lot of power, but it does not make a short circuit. Check the electrical relays, maybe it's in them.
Sep 06, 2017 | Cars & Trucks
Battery issues
Have you checked to see if the alternator is charging the battery when the engine is running ?
Jul 21, 2013 | 1995 Jeep Grand Cherokee
I have a 2001 buick regal ls, the problem I'm
Have a look for a hole in the block where the oil is coming from. If you have one you have blown a motor.
May 26, 2013 | Cars & Trucks
I have a 2003 Chevy Silverado 2500. Once again, it wouldn't start. The battery was completely dead, and it would not even start with a jump. Replaced the battery, started fine. But, now the voltage...
Battery was completely dead ? after how long , over night , or just out of the blue ? These year GM vehicle's 03 to 06 have instrument cluster problems , draining the battery . Do you know what parasitic draw is ? Google it . They used lead free solder constructing the electronics , an after a while it causes silver migration .
Chevrolet Truck Battery Dies Overnight Part
Chevrolet Truck Battery Dies Overnight Part II
Apr 19, 2017 | 2003 Chevrolet Silverado 2500HD
Bike has new battery and i was riding it,parked bike and came back a couple hours later and it was dead. push started it and it was fine,shut it off a couple times after riding places and it started up....
You should start by checking if its charging.
put a volt meter across the battery, it should read roughly 12v
then start the bike and it should rise to 14v
much more than this can blow bulbs and boil batteries
Aug 14, 2011 | 1993 Yamaha FZR 600
Vehicle: 2000 Dodge Ram 1500, 5.9L, Automatic Transmission, 171,000 miles. Vehicle will stop running, just shut off, after about 10 minutes of driving. Then after 5 minutes of waiting it will start again...
the first suspect is the igniton switch. when this happens, take the ign key and just barlely turn it, either way, not enough to go off/on just a little tweak, it the lights come back on or flicker, that ign switch will need replacement.
Sep 18, 2009 | 2000 Dodge Ram 1500 Truck
No power Dacor DCM24SS
I do a lot of work on Dacors / Sharps. Can you describe what you mean by "shutting off"? When it was shutting off before, was it completely dead with no display and no beeps? Was iut shutting off during a cook cycle or just while setting there or what? When it would come back on or start working again, how long did it take to come back, or how did you make it come back on?
Apr 28, 2007 | Dacor DCM24SS Convection Microwave Oven
Remington At3017b Hedge Wizard Logo
131 people viewed this question
Top Remington Garden Experts
Thomas F. Schneider
roeb
Joseph Mueller
Joseph Mueller
Are you a Remington Garden Expert? Answer questions, earn points and help others
