Question about Kenmore 3.8 cu. ft. HE3 Front Load Washer
Towards the end of wash cycle it flashes an f 11
Towards the end of the wash cycle it flashes an f 11 what does that mean
    President:
  • 1,653 Answers
The F11 indicates a Serial Communication ErrorCommunication between the Central Control Unit (CCU) and the Motor Control Unit (MCU) cannot be sent correctly.
Action:
Disconnect power and unplug unit. Check wire harness connections to the motor, Motor Control Unit (MCU), and Central Control Unit (CCU). Check the drive system for any worm or failed components and reconnect power and plug unit in. Verify CCU is working by performing diagnostic test or any cycle. Check MCU by looking for operations of the drive motor and check drive motor for powered rotations. Make sure the serial harness at the MCU is not mounted upside down. The wires should be to the left when facing the MCU connectors. Replace failed component
Posted on Dec 09, 2009
Mfw9700sq0 error code F11
It's a communication error.
Most of the time it's the motor control board (located inside cabinet, towards the bottom on the left), but it wouldn't hurt to check the wires going from the main board to the motor control board.
It's a Whirlpool part. Part number 8182706.
http://www.repairclinic.com/PartDetail/Motor-Control-Board/8182706/1184161
Oct 13, 2014 | Maytag Washing Machines
What does f 11 indicate. The wash gets to the end of the cycle but F11 then appears and the door will not open.
F11 - Pump cannot be activated
f11 lights 1&3&4, pump/draining error
this means an open circuit pump or fauty pcb
Nov 28, 2010 | Hotpoint Aquarius WD640 Front Load...
LE error after full cycle toward end of wash it comes up with an error. not sure if it LE or upside down F E? Anyone have this prob?
LE toward the end of cycle probably means you had a bulky load which you tried to spin out at the high spin speed setting. Use a low spin speed with bulky loads. For this load now, just put power on and without selecting a cycle, push the spin speed selector button until a low speed comes up (should be about a 14 minute display) then push start to do a pump and spin only cycle.
Sep 25, 2010 | LG WM2277H Front Load Washer
Whirlpool front loaded getting stuck in wash and rinse cycle
You can remove the top cover of the unit and put your hands towards the door lock and just hit fair enough to get release the lock mostly it will open if not means just break the lock and replace it since if you are technician it will be easier for you if not kindly call the technician and do the service
May 28, 2010 | Whirlpool Duet GHW9150P Front Load Washer
Towards the end of any cycle the machine displays a code F 11
Here is what the F11 means.
Possible Causes / Procedure 1. Unplug washer or disconnect power.
2. Check wire harness connections to the MCU, the motor, and
3. Check the drive system for any worn or failed components.
4. Plug in washer or reconnect power.
5. Verify CCU operation by running a Diagnostic test or any
cycle.
6. Check the MCU by looking for operations of the drive motor.
7. Check the drive motor for powered rotations 8. Check that the serial harness at the MCU is not mounted
MCU connectors.
Dec 27, 2009 | Whirlpool GHW9400SU Front Load Stacked...
Eco and fast wash lights flashing together and
this does mean draining cycle has timed out due to either blockage or faulty pump...
Dec 21, 2009 | Dishwashers
Zanussi ZWC1300W Front Load w'Machine
is it spinning during spin cycle
your timer may have gone
Jan 18, 2009 | Zanussi ZWC1300W Front Load Washer
Washer will not work
Possible drain fault, check filter. Regards Advisor
Jan 28, 2007 | Zanussi FJS1225W Front Load Washer
Kenmore 3.8 cu. ft. HE3 Front Load Washer Logo
136 people viewed this question
Sal De
fordexpert
Jim Goldsmith
Jim Goldsmith
