Question about HP Pavilion dv7-1240us Notebook
How to replace screen on Pavilion dv7-1040us. is diferent from other hps I have replaced, cannot figure out how to remove it.
    Scholar:
  • 97 Answers
Here it is! Have fun!
  1. Remove the four 4 mm P1 Phillips-head screws that secure the hinges to the display panel enclosure.
  2. Remove the two 4 mm P1 Phillips-head screws that secure the metal tabs on the bottom center edge of the LCD panel to the display panel enclosure.
  3. Lift the LCD panel out of the display panel enclosure.
LCD Panel replacement Note: Before replacing the LCD panel, remove the left and right hinges from the old LCD panel and install them on the new LCD panel.
  1. Place the LCD panel into the display panel enclosure.
  2. Replace the two 4 mm P1 Phillips-head screws that secure the metal tabs on the bottom center edge of the LCD panel to the display panel enclosure.
  3. Replace the four 4 mm P1 Phillips-head screws that secure the hinges to the display panel enclosure.
To remove in order to replace LCD, you will have to remove WLAN, keyboardwith the instruction :
Wireless LAN Minicard removal Caution! Observe all precautions when removing and replacing components.
Before you begin: Remove the batteryhow to replace screen on Pavilion - 2_bing.gif.
  1. Loosen the two captive P1 Phillips-head screws that secure the memory/wireless LAN Minicard cover to the bottom of the notebook.
  2. Use your finger or a flat-bladed tool to lift the edge of the memory/wireless LAN Minicard cover and remove it.
  3. Carefully disconnect the wireless antenna cables from the wireless LAN Minicard with a small needlenose pliers or tweezers.
    Remove the two 3 mm P1 Phillips-head screws that secure the wireless LAN Minicard to the system board and allow it to release to the spring tension position.
  4. Grasp the wireless LAN Minicard by the edges and pull gently to remove it.
  5. Place the wireless LAN Minicard in a static dissipative bag.
Before you begin: Remove the battery.
  3. Remove the 8 mm P1 Phillips-head screw in the memory/wireless LAN Minicard compartment that secures the keyboard to the base enclosure.
  4. Remove the two 8 mm P1 Phillips-head screws that secure the keyboard to the base enclosure.
  5. Turn the notebook right side up and open the display panel fully.
  6. Use a flat-bladed tool or your finger to lift the top edge of the keyboard and slide the keyboard toward the rear of the notebook.
  7. Using minimal force, push the locking bar toward the rear of the notebook to unlock the keyboard ZIF connector on the system board.
  8. Remove the keyboard ribbon cable from the ZIF connector and remove the keyboard.
Keyboard replacement
  1. Place the keyboard right side up on the top cover and insert the keyboard ribbon cable into the keyboard ZIF connector on the system board.
  2. Push the locking bar toward the front of the notebook to lock the keyboard ZIF connector on the system board.
  3. Toe the tabs on the bottom edge of the keyboard into the top cover.
  4. Press the keyboard flat.
  5. Close the display panel and turn the notebook upside down.
  6. Replace the 8 mm P1 Phillips-head screw in the memory/wireless LAN Minicard compartment that secures the keyboard to the base enclosure.
  7. Replace the two 8 mm P1 Phillips-head screws that secure the keyboard to the base enclosure.
  8. Toe the memory/wireless LAN Minicard cover into the base enclosure.
  9. Tighten the two captive P1 Phillips-head screws.
Posted on Dec 10, 2009
  • hunterking Dec 10, 2009
    I hope this is what you needed. Not hard to do just take your time and pay attention to where things go. Lots of screws! Good Luck Phil
    Sorry for duplication of instructions. I can't get use to Word 2007 yet, and end up with things like this happening.
SOURCE:
I spilled liquid on the HP 5610 scanner. Now I have a stain on the left margin of my scans. The stain is a strip that extends from top to bottom. How do I remedy this?
One way to remove all types of stains and fingerprints is Windex and a soft rag. That is one of the cheapest and easiest way to do it.
A better approach to it is to use monster cleaner. It is a special spray to clean tv screens, laptop screens, and even windows. It comes with its own cloth that works amazingly well. I have used it for years and has worked for me every time. You can pick it up at your local Best Buy or click on the link to buy online. http://www.bestbuy.com/site/Monster+Cable+-+TV+Screen+Cleaning+Kit/5774879.p?id=1069297113224&skuId=5774879&st=screen%20cleaner&cp=1&lp=1
May 06, 2011 | HP Officejet 5610 All-In-One InkJet...
Can I use any SATA hard drive to replace the HP Hewlett Packard Pavilion Slimline S3300F Desktop SATA? Thank you Albert
Yes, in fact you will most likely be able to get an upgrade as most HPs have a 5400 RPM hard drive and you can find great 7200rpm SATA hard drives.
There are also 10000rpm drives available but at this point they aren't worth the price in my professional opinion.
Good luck.
Regards,
KYTechnology
Mar 04, 2011 | HP Hewlett Packard Pavilion Slimline...
How to replace a lcd screen on a notebook
Hello
Here is the detail pictorial view of replacing screen of dv6000
http://www.insidemylaptop.com/remove-replace-lcd-screen-inverter-hp-pavilion-dv6000-laptop/
Good Luck, and do rate the solution if got help
Dec 30, 2010 | HP Pavilion dv6000z Notebook
I broke my laptop screen for my HP pavilion D7-1245DX. In order to avoid paying 500+ dollars to best buy just to fix the screen...I bought a replacement, but i cant figure out for the life of me how to...
Find a different computer-store with a qualified technician,
rather than risking your laptop, if you don't know 'HOW' to do it CORRECTLY and SAFELY.
Since you seem to have "saved" a bundle already,
spend some of those "savings" by renting the technician's services.
Last week, a local computer-store replaced my laptop's LCD screen,
and charged me for "one hour of labour", namely $60.
The store could have supplied a brand-new LCD screen for $200,
but they had a "used" screen on-hand, for $100.
So, "$500" seems far too expensive.
Jan 04, 2010 | HP Pavilion dv7-1245dx Notebook
I have an hp dv 9000 and when i turn on the computer the screen does not turn on completely blank.
typical. don't buy hps. they all have this problem. "graphic card overheated and now dead"
Jul 30, 2009 | HP Pavilion dv9000z Notebook
HP Pavilion DV1000 Screen Replacement
Here's the HP manual for it, too many instructions to post and the pictures should be helpful. Just take your time, figure out what you're going to do twice and then do it once. Much cheaper to take a few hours longer than you'd figured on than to fix a self-made problem:
http://h10032.www1.hp.com/ctg/Manual/c00312379.pdf
(Starts at 5-31)
Oct 17, 2008 | HP Pavilion dv1000 Notebook
HP Pavilion dv7-1240us Notebook Logo
350 people viewed this question
Top HP Computers & Internet Experts
Thomas F. Schneider
Alun Cox
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
