Question about Hoover U5753-900 WindTunnel Bagless Upright Vacuum
Carpet/Floor Switch problem on Hoover WindTunnel Vacuum
I have a problem with my Hoover WindTunnel Vacuum. The Carpet/Floor switch seems to be off. When turn to carpet, the vacuum runs really faint. I have to put down pressure on the switch (not quite to the 'floor' setting) for it to work. As of recently, even that's not working.
I was able to access the switch area and there seems to be wiring, etc. that I didn't feel comfortable messing with. I can follow directions as long as it doesn't touch electrical.
Thanks in advance!
  • breban Dec 09, 2009
    Thanks for the recommendations guys! The wheels ARE turning, literally. The brushes work fine once I was able to 'engage' the setting. I can mess with replacing the switch. I was afraid someone was going to recommend soldering, etc.
    Thanks again!
    Sergeant:
  • 208 Answers
Well, you have to deal with it, you have to play with this electrical things if you want to fix this problems.
The good news is, the sources of the problems is the switch already broken.The first things before you do anything is, find this switch on the market first to changes the old ones.Then, remove the power cord from the outlet of course.
After have it, then you must open the old switch, and remove it from the unit by cutting the cables using cutter/ pliers or anything.But remember, you must remember the locations of each cable that been cut, you can use Camera Cellphone to make sure of it if you like.
Then put the cables back together with the new switch, after all done, clean all the mess and try operate it.
Hope it works!!!
Posted on Dec 09, 2009
Testimonial: "I got into the switch area and found that it has a clip at the end. I reset the switch and it's working better. I'm sure I need to replace soon. Thx!"
    Novelist:
  • 160 Answers
There is a couple of things I would check. First, is the beater brush Turning ? Check this by turning the vacuum on and laying on its side to look, but don't touch. If it's turning ... great, if not then you need to replace the belt. Second, with the vac unplugged check all hose's and ports for clogs.
Hope this helps,
RSMITH972278
P.S. PLEASE RATE MY ASSISTANCE
How do I change the selector switch
The easiest way is to lock the vacuum in the upright position and then tilt back slightly (raising the drive wheels) slide the carpet / hard floor switch to the desired position.
I’m happy to assist further over the phone at https://www.6ya.com/expert/robert_b96ba3f038cf317c
Sep 18, 2014 | Hoover U6437-900 / U6439-900 Windtunnel...
I replace both belts on my hoover windtunnel and the small belt has no tention why.
Be sure the selector switch is set to carpet and not "floor" would be the easiest thing to check first.
Sep 17, 2014 | Hoover U6437-900 / U6439-900 Windtunnel...
Hoover model U6425-900 brushes do not roll
-- Make sure slide switch is in carpet position
-- The idler arn which tensions the brush belt may be broken
-- The idler arm override which is attached to the carpet slide switch may be broken
The second one is common.
Oct 30, 2011 | Hoover U6437-900 / U6439-900 Windtunnel...
I have the Hoover, self propelled vacuum. I have only used the self propel function a few times, but our babysitter used the feature and now the vacuum only works on the highest carpet setting. The middle...
Move the carpet height control switch to a higher position if the vacuum is difficult to push. If the setting is too low for the carpet being cleaned, the brushes press against the floor preventing the vacuum from moving easily.Set to a medium-high height setting then check.Slide the "Self-Propel" button to the "ON" position if the cleaner does not self-propel. -----------
The self-propel feature operates only when the cleaner switch and the self propel button are both ON. ---------- Try this settings and check.This should help.Thanks.Helpmech.
Jun 24, 2011 | Hoover Self-Propelled WindTunnel Bagless...
How do I fix the carpet/floor switch on a hoover windtunnel bagged self propelled
The carpet / floor switch is a mechanical assembly. the bottom cover needs to be removed to expose the screws for the hood cover to be removed. then the switch can be accessed for repair
Oct 04, 2009 | Hoover U6437-900 / U6439-900 Windtunnel...
Beater bar
There may be a shutoff switch, located on the hood, that shuts off the agitator to permit bare floor cleaning. Return the switch to carpet mode.
Sep 29, 2009 | Hoover U6437-900 / U6439-900 Windtunnel...
Hoover 5470-900 no longer contacts carpet with beater brush
your floor adjustment spring is broken there is a plastic slider and clip if it is broken the height adj will not work you should get a new vacuum because this repair can cost as much as a new vac.also this is a common problem with the hoover brand I would get a sebo or an oreck they have a great warrentty and you will more than likly never buy a other vac.
Jan 24, 2009 | Hoover U6437-900 / U6439-900 Windtunnel...
Hoover Windtunnel carpet level adjustment
The suction is so great that it sucks up your carpet, then nothing works. I get my children to stand on the corners/edges of the rug so that it stays perfectly flat on the floor while I vacuum. Or, you can turn off the brush roller (set it to "hard floor" setting). Or, tip the vacuum cleaner's front up slightly while vacuuming, to reduce suction.
Oct 28, 2008 | Hoover U6437-900 / U6439-900 Windtunnel...
Hoover U5753-900 WindTunnel Bagless Upright Vacuum Logo
1,060 people viewed this question
Top Hoover Vacuums Experts
Jim Parker
Jim Parker
Gerry Harvey
Gerry Harvey
Are you a Hoover Vacuum Expert? Answer questions, earn points and help others
