Question about Brother IntelliFax-2820 Laser Fax
Changed the toner cartridge in fax machine and it said to clean the corona. I vacuumed close to it and also slid the blue button back and forth 10 times. it still will not work. what now?
  • 622 Answers
Reset the machine and if that does not work replace the drum unit...
I’m happy to assist further over the phone at https://www.6ya.com/expert/norman_d2fa496dce30c65d
Posted on Dec 09, 2009
I have a similar black line (about 2inches in width, on the right side) on faxes sent from my Brother 4100e. I cleaned the scanner glass as suggested by you, but it continues to have the same problem on...
Either your machine's
primary corona wire for printing may be dirty, or the sending party's fax scanner may be dirty. Clean
your primary corona wire. I recommend placing the drum unit on a drop cloth or large disposable paper
to avoid spilling and scattering toner.
1. Clean the primary corona wire inside the drum unit by gently sliding the tab from right to left several times.
2. Return the tab and snap it into the Home position, (Caution: If the tab is not at the Home position, printed pages may have vertical stripes).
3. Reinstall the drum unit into the machine.
4. Close the front cover.
5. Plug in the power cord first, and then plug in the telephone cord.
or ask the sender to make a copy to see if the problem is with the sending machine.
Try receiving from another fax machine.
If the problem continues, call Brother Customer
Service at: 1-800-284-4329 (in USA) or 1-877-BROTHER (in Canada)
OR
You can also try these steps below
2 Reset the drum counter if you have already changed the drum recently. Open the device's front cover and press the button labeled "Clear," then close the cover and press the "1" button on the device's control panel.
3 Pull down on the top of the device's front cover. Slide the print cartridge assembly out of the inside of the printer and place it on a scratch piece of paper.
4 Depress the lever on the right side of the assembly and separate the toner cartridge from the drum assembly. Remove the new drum unit from its aluminum bag and snap the toner cartridge into it.
5 Place the print cartridge assembly back into the device and keep the front cover open. Press the "Clear" button, then press "1." Close the front cover once the device's screen reads "Accepted."
Regards,
Ron
Mar 09, 2011 | Brother IntelliFAX 4100e All-In-One Laser...
Tip
How to clean the corona wire on Intellafax 2800,2810, 3800 machines
Does your brother printer or fax machine have bad printing such as very light print or spotty print. If you have these problems chances are you have a dirty corona wire. The corona wire is used by the printer to put a charge on the paper so the toner is attracted to it in the pattern that the laser draws out. Below are the directions to clean the wire.
1. Open the front cover and pull out the drum unit and toner cartridge assembly.
2. Clean the primary corona wire inside the drum unit by gently sliding the blue tab from right to left several times.
3. Return the blue tab and click it into the Home position.
4. Reinstall the drum unit and toner cartridge assembly in the MFC/Printer.
5. Close the front cover.
Be sure to return the sliding blue tab back to the home position next to the arrow or you will have dark streaks on your printouts
on Dec 09, 2009 | Office Equipment & Supplies
The fax machine is saying remove the drum there is dust on the corona wire.
Use the corona cleaning wire to clean the dust off. Open the front cover. Remove the drum/toner unit. look on the right side of the drum portion above the toner unit for a plastic tab with a triangle arrow that points to the left. Slide this tab back and forth several times. Move the tab back to the right. Reinstall the drum/toner unit. Close the front cover.
Clean the corona wire in this manner every time you change the toner/drum.
May 21, 2010 | Brother IntelliFAX 4100 Laser Fax
Copies are black and where is this corona wire? I
Your cartridge has two sections, the drum and the toner section. The corona wire is on the drum section. There should be a blue tab on the top left hand side of your drum unit. Slide this tab across the cartridge one or two times, returning the tab to its original position. There should be an arrow on the blue tab that will match up with an arrow on the drum unit when the tab is in its resting position. Performing this action cleans the corona wire inside the cartridge. If this doesn't fix it you may need to purchase a new drum unit.
Dec 22, 2009 | Brother IntelliFAX 2800 Laser Fax
I have a KX FL511 fax machine. I just replaced the toner but it is still making faded out vertical lines on the sheet. on left side, middle, and mid right part. I have cleaned glass and roller with rubbing...
There are two things to try. First, did you shake the toner cartridge back and forth prior to installing? This evenly distributes the toner throughout the cartridge. A lot of people skip this step or just give it a perfunctory shake. The other thing to check is although you cleaned the drum/roller assembly, did you clean the Corona wire? This is important because a dirty wire will interfere with proper disbursement of toner as well. The wire should have a TAB that rests on the side. Run the TAB back and forth a few times to ensure the wire is clean and return the TAB to is resting spot.
These 2 steps should fix your problem. If they don't you either have a bad toner cartridge (check the date) or a bad drum. Best of luck to you.
Oct 27, 2009 | Panasonic KX-FL511 Plain Paper Laser Fax
Verical lines of inconsistent or un-even printing,
In almost every case, the problem you describe can be traced back to 2 things. Dirty corona wire or dirty drum (or both). Pull out the toner cartridge, slide the wire cleaner back and forth a few times, clean the drum. The gently shake the toner cartridge from side to side to evenly distribute the toner and replace. This should solve your problem. Best of luck.
Greg
Jun 21, 2009 | Panasonic KX-FL501 Plain Paper Laser Fax
"Toner Low" keeps showing
Hi Meridy!
There could be a few reasons for the Toner Low msg you're getting.
  1. The toner wasn't evenly distributed when the cartridge was changed (shake gently from side to side before installing)
  2. The cartridge wasn't properly installed (ensure that the lock lever "clicked" into place
  3. The corona wire wasn't cleaned when changing the cartridge or the the blue tab wasn't put back in place (this is less likely the issue but still a possibility)
  4. The new toner cartridge was old and is now defective
I hope this helps with your problem. All the best!
Greg
Jun 17, 2009 | Brother IntelliFax-2820 Laser Fax
Changed the Toner in Fax Machine and Still reads "Low Toner"
First, the obvious
  • Did you gently rock the toner cartridge from side to side to evenly distribute the toner?
  • Did the cartridge "click" into place?(did lock lever pop up when it was inserted)
  • Did you replace the protective cover securely?
Another thing to check is cleaning the Corona wire inside by sliding the Blue tab back and forth several times. Important to return the Blue tab back to the "Home" position afterward.
If you've done ALL of these steps correctly, and the low toner message is still there, a service call is in order. Best of luck with your machine!
May 06, 2009 | Brother IntelliFax-2920 Fax
Black vertical streaks on faxes & copies
On top of the toner/drum cartridge there should be a blue slider, move back and forth 10 times.
If no fix, you need a new toner cartridge.
Dec 30, 2008 | Brother IntelliFAX 2600 Fax
Dust on Drum...
I had this problem too. I took out the drum and vacuum the drum with a vacuum cleaner ( no brush ) while at the same time manually rotate the drum cyclinder. It worked. After a month or two, you might have to do it again. But everytime, it solved the dust problem.
Nov 23, 2007 | Brother MFC-7820N Laser Printer
Brother IntelliFax-2820 Laser Fax Logo
80 people viewed this question
James Cagle
James Cagle
Samyfam
Samyfam
Victorman
Victorman
