Question about Coleman Propane Grill Stove 9921-700
I have the colman 9921 A454 And every time I go to use this grill when its cold out the valve(propane valve) gets frost on it and the I dont get enough propane to the burners to get a fire. I also make sure thr tank is twisted in tight. Thanks You
SOURCE: Propane tank
yes, you need to buy an accessory cord that connects your tank to the regulator
Posted on Jul 17, 2008
SOURCE: propane will not come thru burners
Most propane problems are due to a new valve on the top of the tank. It is designed to only allow a minimal flow until the line is pressured. This prevents fire flair up from broken or leaking hoses. Always turn the bottle on and wait before trying to light a burner. If the burner is on first, the propane will never come out at full flow or if you have a leak in the system, it won't pressurize sufficiently to allow full flow out of the bottle. There is never "air" in the tank.
Posted on Jan 13, 2009
TheMobilian
  • 8220 Answers
SOURCE: cannot conect regulator to small 16.4 oz propane tank
It must have some sort of packing spacer you need to remove from the hose to attach the tank. LOL
If you need further help, reach me via phone at https://www.6ya.com/expert/dan_73bbd84fe1d95b61
Posted on Apr 12, 2009
SOURCE: gas coming out near burner knobs
The issue is with the valve that is connected to the knob. it is poorly designed. To fix it take off the lid assembly and remove the front black cover that covers the knobs. remove the almost diamond shaped metal piece that the knob shaft runs through. put on your gas tank and adjust the valve to a position where no gas comes through.. might be lucky or you will have to replace that valve.
Posted on Jun 05, 2009
  • 332 Answers
SOURCE: weber grill three burner. New tank of propane but
The new style2_bing.gif OPD valves have a small brass ring located in the female fitting on the LP tank. Over time this ring can work loose and then it does not allow the male fitting to fully depress the OPD valve thus reducing your gas flow
Using a small flat bladed screw driver tighten the small brass ring This should solve your problem
IF not you might want to remove the cap (white) on your regulator and try slowly adjusting the regulator, make small adjustments and try the BBQ My Weber if I set the front and back burners to MED I get right at 350 degrees in 60 degree outdoor temps. Adjusting the regulator will take some time to get it right but If it is not your tank it is most likely your regulator out of adjustment
Posted on Mar 30, 2010
I have a full propane gas cylinder for my grill in my garage. It is very cold in the garage and I'm getting a propane smell. Does the cold effect this or is there probably another problem?
Cold shouldn't present any special hazard to a propane cylinder. Just make sure the valve is fully off. You can check for leaking with a little soapy water solution around the valve - look for bubbles. If any doubt, remove from enclosed space.
Jan 08, 2015 | Grilling
Coleman 9921 low flame stove
Tony B. s answer gave me the idea to try and spray carburetor cleaner to try and unclog the filter. Worked like a charm. I now have a full flame coming out of both burners.
Apr 10, 2014 | Coleman Propane Grill Stove 9921-700
I don't have an instruction manual for my Coleman grill stove #9921. Is it possible to get one? Thank you.
Sure! Go here http://tinyurl.com/28k8shq select the item you are looking for a manual for, enter your model and download a free manual.
Nov 06, 2010 | Coleman Propane Grill Stove 9921-700
Coleman propane stove, tank got very cold. why?
as propane is used it can create frost on the tank or just cause the tank to feel cold. this is normal. this will be worse when the tank is almost empty.
May 28, 2010 | Coleman Propane Grill Stove 9921-700
Black is on the burners
the fuel to air mixture is set incorrectlty or your pressure at the ouitlet for the gas valve is too low.
you culd play around adjusting the first part of this but for the gas valve part you have to have a manaometer to check it out correctly. then it should be set at 10"wc. Good Luck
Jan 10, 2009 | Coleman Propane Grill Stove 9921-700
Coleman Propane Stove 2 Burner 5430E700
Ho cold waas it out? remember that when its cold out the presswure of the propane tanks are real low and you have to warm them for the pressure to go up. if your by your car then you can place them inside with the heater going till they warm up ofr now worm them up inside first. good luck
Sep 06, 2008 | Coleman Propane Grill Stove 9921-700
Coleman Propane Grill Stove 9921-700 Logo
211 people viewed this question
Top Coleman Grilling Experts
Paul Carew
john h
Marvin
Marvin
Are you a Coleman Grilling Expert? Answer questions, earn points and help others
