Question about Coleman (5040B750) Patio Heater
Have a Patio heater 5040 series. THe heater lights and after about 3 to 5 minute I hear a tick or Click and the flame go's out. What causes this.
Therinnaiguy
  • 1420 Answers
SOURCE: Coleman patio heater 5040A770
These heaters are not designed to be operated below 40 degrees F. If the heater is used below 40 and if you have a gas tank containing less than 25%, the unit will not operate for long and will start going out. If the heater all of a sudden goes out without showing any flickering or pulsations, you have a bad gas valve, there is no thermocouple on this model. Fill your tank and try the heater again. If it continues, give Coleman a call at 800-835-3278.
Posted on Nov 15, 2007
Therinnaiguy
  • 1420 Answers
SOURCE: No Gas in Heating Element
If you are using the heater at temperatures below 40 degrees, ther will not be enough gas vapor to run the heater. If the temperature is above 40, look for an obstruction in the gas piping or gas valve itself. There is a small screen on the inlet side of the gas valve that you can inspect if you remove the inlet hose. Make sure you reinstall the hose using a teflon base pipe sealant on the threads.
Posted on Dec 19, 2007
hotuna
  • 288 Answers
SOURCE: charmglow gas patio heater
The ticking noise is the ignigtor. If the gas tank is full, and the regulator is on, then try lighting with a match or fire of some sort. Be careful of the spark-er! If it lights, then the spark needs to be adjusted so it catches the gas better. If it doesn't lite, then the hole for the pilot is plugged. An outside heater is common for a spider or other creature to make this his home. You need to clean it out. Compressed air even another flame may do it. if not It needs to be removed and cleaned out. If you can see the little hole, trey poking a thin piece of wire into it, it may get it.
Posted on Mar 20, 2008
SOURCE: Patio heater keeps shutting off
Returned it to Home Depot, paid $50 for upgrade to "better" unit.
Posted on Sep 30, 2008
  • 233 Answers
SOURCE: Coleman 5040 Patio Heater w/ Light - Light works, Heater does not
BE VERY CAREFUL sticking matches in any propane appliance! With the gas OFF see if you can physically see the spark when you push the ignitor, if yes, the problem may be the regulator or bottle pressure the only test i am aware of for the regulator is replacement.
Posted on Jul 14, 2009
Why it doesn't stay lit
Replace the gas valve or thermocoupler.
Oct 15, 2013 | Coleman 5040-751 BackHome Open Flame Patio...
Pilot turns on but when I switch to turn it on,
When you light the pilot, are you holding it down for 30-60 seconds. When you release the pilot button, does the pilot flame stay lit? Or does it only go out when you turn the knob to on position. Make sure the pilot flame is heating the end of the thermocouple and that it's a strong blue flame, not a lazy yellow pilot flame. Make sure the tip of the thermocouple is not burn't off, which usually happens with lazy yellow pilot flames. Replace thermocouple is nothing else works.
May 13, 2010 | Coleman 5040-751 BackHome Open Flame Patio...
Unit will not light
you probably have a clogged pilot assembly or pilot tubing this is usually an aluminum tube that runs to the sparker try to pullit apart and clean it
Jul 05, 2009 | Uniflame 233000 Open Flame Patio Heater
Themal coupling needs replacing
Heating and A/C shop or supply. Plumbing supply too
Jul 03, 2009 | Coleman 5040-751 BackHome Open Flame Patio...
Charmglow gas patio heater
Your thermocoupler seems at fault. The thermocoupler is that probe that sits in the pilot flame. It controls the main fuel valve. Make sure that probe is in the pilot flame, better at the tip of the flame and hold the button down for a minute or so after lighting the pilot. If pilot extinguishes, the coupler is faulty. If pilot stays on the heater should fire up when you let up on the pilot button.. Good luck
May 30, 2009 | Coleman (5040B750) Patio Heater
Coleman Patio Heater wiring
This must be a top secret heater design. Coleman is dwfinately of no help. The whites go to the ignitors or the output of the spark generator. The black is generaly a ground. Good luck.
May 30, 2009 | Coleman 5040-761 Open Flame Patio Heater
Patio Heater SRPH02 will not light in cold weather
you may need someone to come in and adjust your pressure regulator that is inline to heater this is what controls the output of propane and should only be adjusted by a pro
Apr 15, 2009 | Coleman 5040-751 BackHome Open Flame Patio...
Coleman (5040B750) Patio Heater Logo
35 people viewed this question
Top Coleman Heating & Cooling Experts
Bill Long
Paul Carew
Dan Webster
Dan Webster
Are you a Coleman Heating and Cooling Expert? Answer questions, earn points and help others
