Question about Porter Cable Cable 135 PSI, 60 Gal. Oil - Lube Stationary Compressor C7510
Trying to wire up my new air compressor, need help with wires.
I have a new C7510 Porter Cable air compressor and I am trying to wire it to the circuit breaker. The motor has two posts, #1 and #6 and it says ''non reversible'' on the motor tag. Which wire, black and white goes where? 11 amp, motor.
    Scholar:
  • 169 Answers
If you are trying to connect power lines directly to the motor then stop what you are doing, I advise you refer to the owners manual for correct wiring of the compressor. I would highly advise that you seek the service of a professional to hook it up. otherwise you could damage the equipment or worse yourself.
Posted on Dec 09, 2009
Wiring diagram for porter cable air compressor CPF6020
Contact Porter Cable and request the wiring diagram for CPF6020.
Mar 26, 2018 | Porter Cable Air Tools & Compressors
How do Oil Lubrictors help in functioning of machines ?
The lubricants surely work as a magical wand between the friction and the moving parts of machinery. So it is necessary to look for best oil lubricator for the smooth running of machines. Home FDJohnson
Jul 19, 2014 | Porter Cable Cable 135 PSI, 60 Gal. Oil -...
How to test electric switch on porter cable air compressor
What you need is something called a volt-ohm meter.
Obtain one and use it to test your switch and wiring.
May 26, 2014 | Porter Cable C2002 150 Psi 6 Gal...
Order to put compressor valves back
If you go to www.ereplacementparts.com and search on your model number, they have a rough diagram of your valve plates that should get you close to where you need to be. I usually look at them from the mechanical perspective; make sure one reed valve is on the valve plate side away from the intake chamber of the head (the side the air filter is attached to) and the other one is towards the output side. You can usually figure out where gaskets go by how they're formed.
Feb 27, 2012 | Porter Cable Cable 135 PSI, 60 Gal. Oil -...
The breaker in the motor keeps kicking on and off, is the reset
I'm assuming that you're pushing in the red button to reset it to restart the motor? Check to see what the air pressure is when the compressor shuts off. If it's higher that rated, then perhaps lowering the pressure will prevent the motor overload. If you have an amp meter, check the amp reading and compare it to the amp rating on the motor nameplate.
Jul 04, 2010 | Porter Cable Cable 135 PSI, 60 Gal. Oil -...
I received no manual for my 60 gal. Porter Cabel air compressor (model #VT627504AJ) and I need to know the spec. for wiring.
being that its 220 on the compressor Is where I assume you are wanting to know where the wires go? There should be a terminal strip or box that has a terminal strip by each terminal there should be L1 L2 and either ground or neutral. The two hot wires one each go to the Line terminals and the ground or neutral to marked terminal.
Jan 09, 2010 | Porter Cable Cable 135 PSI, 60 Gal. Oil -...
Should air compressor tanks be drained daily and if so why should they not be left under pressure from day to day? Will the air under pressure in the tank cause additional water vapor to accumulate?
No additional moisture will accumulate over time. Some existing moisture may condense as the unit cools down, though. If you drain off the water at the end of the day, I see no good reason to completely drain the air.
Oct 24, 2009 | Porter Cable Cable 135 PSI, 60 Gal. Oil -...
Drain valve on air compressor won't open or close
I would use an ajustable wrenck to try and open the valve. Being at the bottom and in the water, this is a common occurrence. to replace the valve, there is a Hex nut outer fitting (part of the valve) that you have to remove right by the valve "T" handle. Put a wrench on this and remove the complete valve. It too will be very hard to remove. When you install the new valve, use some anti-seize compound to make future removal easier.
May 31, 2009 | Porter Cable Cable 135 PSI, 60 Gal. Oil -...
Won't start -Porter Cable Cable 135 PSI, 60 Gal compressor
ARE THE POINTS BURNT IN THE PRESSURE SWITCH? DO YOU HAVE A LEVER ON THE SWITCH SET TO ON OR AUTO? IF YOU THINK ITS THE SWITCH JUST BYPASS IT AND TIE THE WIRES TOGETHER TO SEE IF IT RUNS. BEWARE YOU HAVE NO PRESSURE PROTECTION EXCEPT POP-OFF VALVE. MOST P.O.S. COMPRESSORS LIKE PORTER CABLE HAVE 3500 RPM MOTORS AND HAVE A THERMAL RELEIF BUTTON ON THEM. JUST PUSH TO RESET. MAKE SURE YOUR WIRNG OR DROPCORD IS LARGE ENOUGH GAUGE. SMALL GAUGE DROPCORDS KILL COMPRESSORS.
Jan 17, 2009 | Porter Cable Cable 135 PSI, 60 Gal. Oil -...
Porter Cable Cable 135 PSI, 60 Gal. Oil - Lube Stationary Compressor C7510 Logo
288 people viewed this question
Top Porter Cable Air Tools & Compressors Experts
John Trevino
elunsford
Are you a Porter Cable Air Tool and Compressor Expert? Answer questions, earn points and help others
