Question about Nokia 5800 XpressMusic Smartphone
Phone loses charge after making several calls or texts,drops 2 - 3 bars overnight,battery changed,latest software downloaded .problem still exists
    Guru:
    Mentor:
    An expert who has written 3 tips or uploaded 2 video tips.
  • 139 Answers
You can change its battery sir and you gonnah get rid off this. :) cheers
Posted on Dec 13, 2009
SOURCE:
How do you check the battery charger?
https://www.youtube.com/watch?v=aO4I2v3XgM0use volt meter check all batteries first, then check voltage when it is charging
Sep 16, 2015 | Health & Beauty
My Motorola Defy will not hold a charge. Had full charge at 8:00 Am and by 2:00 PM battery was dead. No apps running or Wi-FI on. Second day in row this has happened
The DEFY is feature-rich and can run a virtually limitless number of applications, making it useful for many tasks. Your particular usage will affect how long you can go before recharging your battery. Playing games, running applications, and surfing the Web increase the power use of the computer-like functions of the DEFY Calling and texting utilize its phone functions. Depending on your use mix, time between charges will vary. We know you want to use the device to its fullest and offer you these tips to help you get the most from your phone while going as long as possible between charges.
Things you should know about charging your battery.
New batteries are not fully charged. Plug the battery charger into your phone and an electrical outlet. Your phone might take several seconds to start charging the battery.
Tip: It may take several charging cycles for your battery to reach optimum performance.
The battery charger shipped with this device is designed specifically for Motorola mobile phones. Other chargers might take longer to charge your battery, or cause your calls to fail during charging.
Tips to extend battery life:
  • During initial set up of your MOTOBLUR account, your phone's battery may drain faster than usual due to the amount of data transferred. After the initial sync, and a few charging cycles, your battery will reach its maximum capacity.
  • We strongly recommend to keep the phone attached to the charger during the MOTOBLUR initial sync.
  • When not transmitting a lot of data or surfing the Web, set your device to connect to 2G network.
  • When setting the phone down after use, quickly press the power key to invoke a blank screen. Selecting a shorter back light duration will also help conserve power by blanking the screen when not in use.
  • Lower the display brightness.
  • Use the AC adapter to charge your phone whenever possible.
  • Toggle Bluetooth, Wi-Fi, and GPS on or off as needed. There are some apps that can help do this easily. While we do not endorse or guarantee these solutions, or provide support for them, some owners have reported success using an application called "Battery Widget " which can be downloaded from Android market.
  • Ensure applications are closed when not in use.
  • Clear all notifications from the notification bar as much as possible. Click Here to learn more about notifications.
  • We suggest charging each night so you start the day fully charged and ready to go!
Motorola DEFY Battery Manager - Benefits
A feature called Battery Manager is now part of the DEFY software
  • It provides options for significant battery savings by reducing data traffic when not needed, and by dimming screen when battery is low.
  • Two optional settings:
Data Timeout
· With this feature: After a period of inactivity, background data updates stop until the user starts using the device again.
· Without this feature: background data is constantly updated (Email, Social Networking, News Feeds, etc.), even overnight.
Auto Brightness
· When Battery Level gets low, screen automatically dims.
Battery Manager: How To Use It
To access battery manager
  1. From the home screen press the menu key
  2. Tap settings
  3. Tap battery manager
Three Modes are available:
  1. Performance Mode (default) - Data Timeout and Auto Brightness are OFF
  2. Smart Mode - Data Timeout and Auto Brightness are ON with different settings during Peak and Off-Peak times of day. User can change various settings.
  3. Battery Saver Mode - Data Timeout and Auto Brightness are ON with settings to maximize battery savings. User cannot change the setting
May 24, 2011 | Motorola Mobility Defy Cell Phone
I can recieve text messages but cant send them
there are several reasons why you can't send a message, here are several options that you can try:
1. if you are a prepaid user, make sure that you have enough credits left :) 2. try to reset your phone by turning the phone off, removing the sim and the battery and wait for a few seconds before turning the phone back on 3. make sure that the call barring is deactivated (go to your settings then call settings, call barring, cancel all) you may be asked for a password try 1234 or 12345 or 0000 (as these numbers are set as default pin) or you can try to contact your service provider for the default network pin 4. you can also check your sms centre number and try to change it (for this you need to call your service provider to ask them for the sms centre numbers that you can use) save it, then do step number 2. then try to send a message 5. contact your service provider and ask them to check if your outgoing sms is not barred 6. try to insert your sim card to another phone and try to send an sms using another phone (to isolate if it is a phone problem)
Apr 19, 2011 | LG Optimus Black Smartphone
My NK5800 does not charge the battery all the way to full. Whenever the battery bars shows 1 or 2 bars left, I will connect the charger to the phone and leave it to charge. But lately, whenever I tried...
Hello Anthony,
Please update the software of phone from :
http://www.nokia.co.in/support/download-software/phone-software-update?5800xpressmusic=
Also visit the link provided below :
http://www.nokia.co.in/support/download-software/device-software-update/how-to-update
Mar 16, 2011 | Nokia 5800 XpressMusic Smartphone
Battery does not work more than 4hrs even i do not use multimedia files too.....
If a recharable battery is more than 3 - 4 years old then the battery could be wornout. Rechargeable batteries have a finite number of charge and discharge cyclesand will lose their charge capacity over time, i.e. won't charge to 100% andgradually the charge reduces until the battery won't charge up atall. ORThe battery shows a 100% charge but when the adapter is disconnected thebattery drops off to zero capacity in a very short time. Ifthe battery drops to an unacceptable charge level then the battery needs to bereplaced.
Mar 09, 2011 | Cell Phones
When i make a call my strength bar decreases an drops the call
You might be on the border of two coverage areas, like the overlap between two towers.
First try powering your phone off then back on. Watch the strength meter for a minute or two then try your call.
It also might be dropping as you move it, or block the internal antenna with your hand. If you have speaker mode, hit that as soon as the call connects and watch the bars. They're not realtime, so you only see changes after several seconds or longer.
Try other sections of your house or car, wherever you're trying to use the phone when this happens.
Also, check your battery strength. If it's down to one or two bars, you should charge it up and see if that solves your problem.
Dec 18, 2010 | Nokia 6790 Surge Cell Phone
LG Dare quickly dying even after a long time charging.
The cells of the battery of your phone is very low that it can no longer hold charge.
All you need to do is to get a brand new battery for replacement.
Please charge the new battery with your phone to indicate the battery is full before you start using it.
This will help in a long way to keep your battery life span last long.
Take care.
Apr 21, 2010 | LG Dare VX9700 Cell Phone
Screen shows a battery with a red slash
This could mean a few things. Here are the different ways to try to fix it:
1. Charge your battery for at least an hour, preferably overnight. If that doesn't get rid of the red slash, continue down this list...
2. Try a fully-charged battery from another phone. Either borrow a battery from someone or go to a local store to try one. If the red slash goes away, your battery is defective. If you have had your Blackberry for less than a year, your service provider should replace it at no cost. The number for warranty service is: 1-800-801-1101.
3. Try your battery in another phone. Again, if your battery does not work in the other phone, your battery is defective. If your battery does work in the other phone, you have a software issue.
You need to download the latest version for your device. You can get that either from your service provider's web site or from Blackberry (www.blackberry.com).
Save the folder to your desktop, double click it to install it your computer - be patient - it can take a while.
After you have downloaded the software to your desktop, connect your blackberry. Go into the Desktop Manager on your computer and use the program called Application Loader to install the new software on your Blackberry. Make sure that, when you see the "Advanced" box, you choose that option. Make sure you check both boxes to remove all current installed software.
4. Finally, if reloading the software does not work, likely your Blackberry is defective. You should call your service provider and ask that it be replaced (Note: call them even if you are out of the warranty period; if you are a good customer, they will often replace your phone anyway).
Hope that helps.
Jan 09, 2009 | AT&T Blackberry Curve 8300 Smartphone
Phone won't make or receive calls or text messages
Maybe it isnt programed correctly. U can call your sp to reprogram the device or take it to the store u bought it at and get them to reprogram it.
Nov 16, 2007 | Motorola Mobility Moto Q
Nokia 5800 XpressMusic Smartphone Logo
79 people viewed this question
Top Nokia Cell Phones Experts
jonathan mariano
jonathan mariano
Damen Wong
Damen Wong
