Question about Maytag Neptune Washer
Spin issue with first model of washer maytag neptune
Hi, i was away for one month and i found that my washer does not spin...anymore.
i do not have the manuel and i do not know what is wrong....5 everything looks good....
please help.
thanks
I think you have what's known as the "R11 and Q6 Problem".  The quick and costly repair method is to replace the circuit board.  The less expensive way is described at this Web site:
http://members.shaw.ca/gavb/index.html.  I followed the steps for replacing the R11 resistor and the Q6 Triac on the circuit board and ti solved my no-spin issue.
The vendor that I used is Unicorn Electronics located at http://www.UnicornElex.com/.
Here are the parts that you need:
NTE5657 Triac-600VEM 0.8A
Item #: 49-6272
Price: US$3.63
3.9K Ohm 1/4 W Carbon Film Resistors 50 Pack Item #: 10-8086
Price: US$1.99
Posted on Jan 26, 2008
At spin cycle, the tub spins out of its orbit hitting the sides, then it stops moving with an error on the screen. this is a maytag neptune 7AV6800AWW
When my washer did that, I found that the shocks that hold the tub were bad...
Check out this tip I wrote about the noise and vibration that front loadwashers can make..
Washer Problems Washer noise when spinning
heatman101
Jul 10, 2011 | Maytag Neptune Washer
Maytag Neptune - MAH5500BWW makes loud, loud noise during spin cycle. What parts are necessary to repair the unit? I assume there are bearings and seals needed. Thank you.
heatman101
May 26, 2011 | Maytag Neptune MAH5500B Front Load Washer
My Maytag Neptune smells very musty. I have used vinegar, baking soda, and bleach but the smell wont go away!!!
This is gunk build up under the agitator and/or the drain area under the drum. It needs to come apart...
Apr 16, 2010 | Maytag Neptune FAV6800AW Top Load Washer
Maytag neptune washer model mah6500a, took the back off and the tub spins but still get the code Lr
Looks like another motor/motor control panel replacement. This machine has a faulty motor/motor control board, it has been re-engineered with a replacement. Has yours been replaced? Have you found the tech sheet behind touch panel and placed machine in service mode to test? We had the same issue, worked sporadically, didn't drain, got LR code then eventually stopped working. Check your spin in service mode, if it doesn't spin properly you should find out here. It is a very simple repair in all actuality. Contact Maytag and they will sell you the parts for a discounted price, make sure that you buy directly from Maytag, also check your boot very carefully since that part will also fail and allow water to get into the bottom of the machine where you have electronics.
Feb 15, 2010 | Maytag Neptune MAH6500A Front Load Washer
Maytag Neptune TL clutch problems- Class Action Lawsuit??
I sounds like this is a common problem with the Maytag Neptune TL after about 3-5 years. Mine finally went out yesterday after several months of bearings getting louder all of the time. It looks like the bearings and the controller are gone. What happened to washing machines that last 15 - 20 years?
Dec 07, 2009 | Maytag Washing Machines
Maytag neptune fav9800aww has error for unbalance circuit always open or out of range
I had the same issue with FAV9800AWW, the Quick Spin Test showed "Machine cannot spin because the unbalance circuit is always open or out of range." Removed the Tub Displacement Sensor, disconnected the wire harness to the sensor, and found corrosion between the contacts, especially on the 12V DC pin. When I cleaned it with isopropyl alcohol and soft brush, discovered that the trace had corroded away, and so the board was not receiving the 12V DC input. Also had checked on the pins of the blue/white (signal) and pink (gnd), and was always negligible millivolt reading. The part number is Whirlpool 12002194. Ordered it from Appliance Parts Pros after reading various reviews. I found it cheaper other places, but those places got too many poor reviews for my taste.
http://www.appliancepartspros.com/partsearch/model.aspx?model_id=5169373&diagram_id=28406005#d28406005
Oct 17, 2009 | Maytag Neptune FAV9800AW Top Load Washer
Extremely loud noise during spin cycle of my Neptune dryer--just started happening in the last month. The dryer is probably 7-8 years old, so it's not the newer Neptune model.
Here is a tip that I wrote about dryers and noises...
It will help you determine what is happening there...
Dryer Repair Squeaks, Grinding, Clicking and Knocking Noise
heatman101
hgd76
Jun 26, 2009 | Maytag Neptune Washer
Maytag neptune mah3000aww tub size
The answer is:
CAPACITY 3.1 Cubic Feet
The reference for this answer can be found here:
http://www.servicematters.com/maytag_library/docs/16010061.pdf
Seach in this document for "capacity".
SECTION 1. GENERAL INFORMATION Page 1-4
Nov 20, 2008 | Maytag Neptune Washer
Washing Machines Logo
130 people viewed this question
Top Maytag Washing Machines Experts
Bill Long
Ronny Bennett Sr.
Ronny Bennett Sr.
John Tripp
John Tripp
Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
