Is it necessary to bring the signal from the ant. if I never intend to record? Do I still need to use the "out to tv" hook up?
  • 45 Answers
If you want to watch TV you will need to hook the antenna to ANT. IN and run a coaxial cable from OUT TO TV to ANT. IN on the TV. Otherwise disconnect the antenna from everything. Good luck to you!
Posted on Dec 13, 2009
How to hookup and use
A DVD recorder can hook up to any TV that has at least a set of AV inputs (you will need an RF modulator if your TV does not have AV inputs).
Just hookup your cable or antenna feed to the ant/cable input of the DVD recorder and loop it out to the RF input on the TV.
Nov 13, 2011 | Televison & Video
Connecting up Digital TV, DVD recorder and VCR
You need to hook the VCR and the DVD recorder to the scart connections on your TV.
VCR to one scart on the TV
DVD recorder to the other scart on your TV
Jan 31, 2008 | Televison & Video
On the vizio 55' hdtv led lcd my mother just bought yesterday . I need to hook up TV cable which is a coaxial cable and the roof top Antenna which is also a coaxial cable but on back of the set ,there is...
Hello
On alot of cable boxes there is also an "ANT IN" that you can bring your rooftop antenna in to. When you turn the cable box off, it passes the ANT signal to the tv.
I hope this helps you out
Nov 28, 2010 | Vizio VF550M 55 in. LCD HDTV
Hi just got a LG dvd/vcr Model RC897T. I have it hocked up right, but i can't get it to switch over so that it would be seen on the TV. can you help
If a cable box is not required for cable signal reception, connect the cable line to the ANT. IN connector on the recorder.
If a cable box is required for cable signal reception, connect the cable line to the IN connector of the cable box. Connect a coaxial cable from the OUT connector of the cable box to the ANT. IN connector of the recorder.
To view or record a CATV channel:
  1. Tune the TV to the Recorder output channel (CH 3 or 4).
  2. Set the Recorder channel selector to the cable output channel. (Example: CH3).
  3. Select a channel using the cable converter.
With this connection, you cannot record one program while viewing another.If you are using a cable box to tune channels, it is not necessary to do Auto Channel Set.
Oct 20, 2009 | LG RC897T DVD Recorder/VCR Combo
Analog VCR
no you can use your regular VCR. You will just have to make sure you put your coverter box to bring the signal into your vcr. You can also bring the signal into your TV from the vcr so that you don't have to have 2 converter boxes.
Jan 23, 2009 | Memorex MT1134 13" TV
My new tv digital converter box weill not pass analog tv signals. The tv works fine if I take the box out of the circuit. I am in a motorhome using the normal tv antenna on the roof.
you need to split ant. signal then get a manual selector switch hook 1 wire to convertor input then the output& the other ant wire to the selector switch then from selector to tv
Dec 20, 2008 | RCA Televison & Video
My Zenith VCR is not working with the digital converter box
When the VCR is "off" the converter signal should go right through the box, which you say it does. Then, when you turn the VCR "on" the picture disappears. That, so far, how it should be. To get your picture back while the VCR is "on" you must set the VCR to "receive" channel 3, and use your new converter box to change channels...accordianman
Dec 16, 2008 | Televison & Video
I can't hook it back up
Is your DVD player a DVD/VCR combo? If so, hook the "tv out" (sometimes called "ant out" ) to the "ant in" on the DVD/VCR, then hook the "ant out" of the DVD/VCR to the "ant in" on the tv. Then make sure the DVD/VCR and TV are on the appropriate channel (3 or 4).
If it's NOT a combo, or these instructions don't work for you, i will need pictures of the inputs/outputs of the devices.
Nov 08, 2007 | DISH Network DVR-625 DTV Receiver /...
Televison & Video Logo
Top Televison & Video Experts
