Sharp AR-162 Laser Unit
Sharp AR-162 copier error code L6 - Laser Unit. How do I change the Laser Unit? It's not in the online user manual.
  • picas36 Apr 07, 2008
    hi, i have the same problem, L6, in Toshiba e-Studio 161 Copier Copier, does exit´s any reset code?
Searching for solve problem L6 error in the machine sharp m 160
Posted on Mar 19, 2009
  • 61 Answers
Hi, the laser unit is situated under panel where the copies come out. Replacing the unit requires removing the front op's panel and sliding the panel out. the unit is held in with four screws, rear ones can be tricky, unplug and replace.
regards
Andy
Posted on Jan 20, 2008
I have an Error on my Sharp AR-M350n+ copier that says "L6-10" Can you please tell me that that error code means? Thanks
L6 10 Polygon motor trouble
it is a very common problem on sharp copiers
that means the laser unit is defective, tou have to change it , allso is very expensive..
regards,
Adi
Nov 03, 2010 | Sharp AR-M350N Copier
Code F2-04 solution
http://www.retrevo.com/support/Sharp-AR-M162-Multifunction-Printers-manual/id/600ag113/t/2/
Above is your user manual below is your service manual.
http://www.eserviceinfo.com/index.php?what=search2&searchstring=AR-162,+AR-163,+AR-201,+AR-206,+AR-207,+AR-F201
http://www.eserviceinfo.com/fulltext.php?search_ft=DPX-7010MD
You have a sensor error. I have included your user and service manuals so you can attend to the error.
F1-04 Bin limit position sensor error in sorter
Aug 12, 2010 | Sharp AR-M162 All-In-One Laser Printer
L6-10
sorry you must change laser unit
May 26, 2010 | Sharp AR-M450N Copier
Sharp AR-M205 - Error Code L6
Hello sir; "L6" display it means laser motor defect need to replace.
Aug 19, 2009 | Sharp AR-M205 Copier
L6-10
According our service manual 'L6" sub code 10 is laser drive, motor, problem, replace laser unit . the laser unit item# is DUNTK0013QSZZ, it located at left hand side of the toner cartridge inside the machine. or it may be mostly due to Polygon mirror motor not up to speed... You may be able to air it out and fix the problem.
Jun 19, 2009 | Sharp AR-M450N Copier
The L6 code is flashing on my copier
No you can't, it is the polygon motor not rotating. It is inside of the Laser unit. You should replace the polygon motor. The part code is RMOTN0028QSZZ. It will cost you about US$ 80
Jun 04, 2009 | Sharp AR-160 Copier
Gunawan
Hi Gunawan,
The error 'L6' is usually an indication of problems with the Laser Unit in the copier.
Unfortunately the unit will have to be replaced and can only be done by trained personnel.
Contact your closest Sharp Dealer for assistance.
Regards
Gavin
Oct 13, 2008 | Sharp AR-5316 Advanced Digital Imager...
Sharp AR-M280U
Hi:
L6-10 will be a polygon mirror motor error, (a multi-sided mirror that rotates in a similar way as a hard drive spins. writes laser data to the drum) .When this code comes up it usually indicates that the motor is locked. You will need a new polygon motor , most techs would change the entire laser unit.
Sorry but It will have to be serviced professionally.
Jan 18, 2008 | Sharp AR-M280U Grayscale Copier
Sharp AR-5316, showing L6 on display
The L6 code means trouble with the laser unit ( polygon motor), it has to be replaced. The laser unit is under the exit tray. Hope this helps.
Jan 02, 2008 | Sharp AR-5316 Advanced Digital Imager...
882 people viewed this question
k24674
jasbo
jasbo
