Question about Kenmore Washing Machines
My kenmore washing maching stop working the machine has a letter f every time you tried to start it model HEt3
  • 15,935 Answers
Drive Motor Tachometer Error
The control is unable to properly detect motor speed and the machine will shut down. If a failure occurs during high-speed spin the door will be unlocked after 3 minutes.
Potential Causes:
* Check wire harness connections between the Drive Motor/Tachometer and the Motor Control Unit (MCU), and between the MCU and the Central Control Unit (CCU)
* Check the Drive Motor
* Check the MCU
* Check the Wire Harness
begin troubleshooting right at the motor. Why start there? Because the motor is one of the prime suspects and it's easy to check. Remove the back panel and unwind the belt from the drum pulley. Now turn the motor pulley (sans belt) by hand. If it doesn't turn smoothly and easily, you have a bad motor.
If the motor pulley turns smoothly and easily by hand, next step is to run the motor with the belt still removed from the motor pulley. If the motor seems to run fine that way, put the belt back on and run it again. If the motor won't run under load (with the belt on), then that's another sign that the motor is bad.
Suppose the motor turns easily and freely by hand but won't run either with or without the belt. This is a more subtle condition because we're probably dealing with a bad MCU or flakey wire harness somewhere between the motor and MCU, or between the MCU and the CCU.
One trick that often works at this point is to remove and reinsert all wire connections at the board and motor. This tends to clean the small amount of corrosion that will build up on the connections. After you do this put the machine into a service cycle (see the instructions in the tech sheet found inside the unit or you can ). Part of the service cycle is running the motor at certain set speeds which checks the tach.
If you've removed/reinserted the wire harnesses and still no joy, then usually the problem is the MCU.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question
Posted on Sep 15, 2010
SOURCE:
Why is my Kenmore elite three speed top loader washing maching model number 110.23022101 only washing on HOT water? The cold will not work. We recently had workers remodeling that room and the washing...
Make sure the cold water supply is on and not blocked.
If the machine fills but does not wash try to find a thermal switch that is supposed to come on when the cold water has heated up.
Jul 20, 2014 | Kenmore Washing Machines
Right after the Lid Locks on both the wash and rinse cycle, the F1 light starts flashing and stops the cycle. We have to stop and restart at least 3 times for it to finally engage. Your suggestions...
F1 is a ( pressure sensor failure) which controls water intake in the machine control unit. The fix is to replace the machine control unit ( computer) This is an easy but costly repair..... At one time kenmore sent out letters to owners of certain models offering replacement of the computers Good Luck
Sep 21, 2010 | Kenmore Oasis HE 27082 Top Load Washer
I have an het3 elite washer. I have done all the trouble shooting....removing hoses and cleaning out debri. i took the pump assembly out and noticed that the "fins" 3 out of 4 were broken. Does this mean I...
yes sir..  those are the impeller fins and with only one you are not going to get much push on the water to expel it.  time to replace it and make sure all pockets are cleaned out before washing..
Jul 27, 2010 | Kenmore Elite 45986 Front Load Washer
My kenmore elite het3 has a code f
F is an indication of a failure with the machine. If you look at the window where the 'f' is it should also be followed by another letter(s) or number(s). I would need to know what those additional numbers or letters are to determine what kind of failure occurred.
Thank you
May 18, 2010 | Washing Machines
I wanted to take some clothes out during the cycle but don't know how to stop it properly and get the door unlocked
your mach depending on model and cycle selected has a 3 to 5min "add a garment" feature.that means in the 1st 3-5mins of cycles when add a garment light is lit you may hit pause button once and the mach will stop and unlock door.after add a gament light is off,if u hit pause the cycle the mach will drain water and reset cycle..hope this helps
Mar 29, 2009 | Kenmore 42822 Front Load Washer
10 year old model kenmore top load washing maching won't fill.
That means that eithere the membrane water lever switch is faulty (most common) or that the drain pump solenoid is stuck on open.
Dec 21, 2008 | Kenmore 24032\24036 Top Load Washer
Kenmore washer
Has it stopped agitating completely now or does it start each time then stops? Do you hear anything - say like a humm when you try it afterwards. Dose it spin/drain water from washer?. Post a response so we could know what next
Regards
Sep 01, 2008 | Kenmore 24032\24036 Top Load Washer
FH code HEt3
check your incoming water supply, f/h is lack of water entering machine, if you had high iron levels its quitre possible that youve clogged theinlet water valve in which case youll need to replace it, ( water supply hoses screww in the water inlet vaslve
Apr 19, 2008 | Kenmore Elite 45986 Front Load Washer
Washing Machines Logo
Sal De
fordexpert
Whirlpool
Whirlpool
