Question about HP DeskJet 1280 InkJet Printer
Printer All about HP1280 printer. A few time ago is the printer not used.By using the printer now t will not print and a lamp is still blinking. What should i do or is the cartridge empty
    Brigadier General:
  • HP Master
  • 3,614 Answers
For a long period of time the printer has not been used, the printer ink has dried out even you did not using it.
You need to replace the ink of your printer, the blinking codes means that there was no more ink on the tank and need replacement.
After replacing the ink, do a deep cleaning on the printer to wiped out some dirt that in the printer head.
Hope this initial info/idea helps.
Let me know for any clarification.
Thank you.
Posted on Dec 09, 2009
SOURCE:
I have a hp1280 deskjet printer it is print so much slowly
At its fastest, the Deskjet 1280 only prints at 14 pages per minute, and this number decreases if you print in color, use a higher resolution, or use larger than 8.5" x 11" paper.
To increase print speed, try dropping the print resolution from 600x600 (Best) to 300x600 (Fast), and if you are printing something that doesn't have any color, make sure you select black and white in the print properties, rather than color.
Jun 03, 2010 | HP DeskJet 1280 InkJet Printer
My hp1280 prints only one color at a time. some days it prints only blue and black; another day, only red and black etc. I haven't a clue what the problem might be.
Try doing a cleaning cycle on the heads. If that does not work try updating the firmware of your printer. I am not sure if the firmware of your model is upradeable though
Feb 11, 2010 | HP DeskJet 1280 InkJet Printer
I cant print on A3 paper through microsoft excel on hp1280
in excel sheet please change the page size to A3 and try to print ..... if you are using office 2007 go to page layout then go to size icon there change the page size to A3 and check .......... if you are facing the same problem please post your comment ............. while you giving print please select the document which one you want to print ..........
Dec 31, 2009 | HP DeskJet 1280 InkJet Printer
Machine has an error code & won't print. We have no manual.
If the lamp is on solid that is a cancel job or reset printer indicator
If the lamp is blinking (flashing) that is the secondary Jam error meaning somewhere in the paper path is a jam. The lamp shoul dbe blinking in a sequense - that sequence indicates what are of the printer the jam is. So the lamp should blink a number of times, pause then blink the same number again.
1 blink - jam in feeder sensor
2 blink - jam in manual feed
3 blink - jam under toner
4 blink - jam in output are
5 blink - jam in tray 1
6 blink - jam in tray 2 (if present/option)
Sep 03, 2009 | IBM Infoprint 1412 Laser Printer
Light is blinking, doesnt print, it prints before but now it doesnt. appears online and ready on the computer.
If the port had been changed to LPT1 the printer will not work.
LPT1 is the large parallel port, while you are using USB on this printer.
the red light came on probably because of a jam , or because of one of the documents in the printer cue.
The easiest thing to do is
Unplug printer usb.
Go to control panel>installed printer.
Delete all the instances of this printer from there and chose to delete drivers if asked.
Reistall the printer using the printer disk, plug in printer data cable only when asked by setup wizard.
If you have a different USB cable, also use it, just in case.
If that does not fix the problem , then there is an internal fault in the printer.
Regards.
Jun 01, 2009 | HP DeskJet D1460 InkJet Printer
The yellow light blinks and it won't print
I also started having problems with my HP 870Cse when I began using refilled cartridges and had ink leakage (cartridge contacts corrupted). Check for this problem. If so, remove cartridges and gently clean the spillage. Then try using HP brand cartridges and see if this doesn't remedy the problem.
Jan 21, 2009 | HP Deskjet 870cse Printer
HP printer F4200 wont print
I have a similar problem. Took to authorised service station. Say no problem. After few pages stopped again. B.S
Nov 10, 2008 | Office Equipment & Supplies
Help please
Use custom settings then set your paper to 297x420mm
Aug 04, 2008 | HP DeskJet 1280 InkJet Printer
HP DeskJet 1280 InkJet Printer Logo
73 people viewed this question
Clive
Clive
Thomas F. Schneider
