Question about DXG Technology DXG-538 Digital Camera
DXG-538 as a webcam
I have DXG-538...when the camera is in mass storage mode and i connect the usb cable to my pc, it would open up a storage window. but when i change the camera mode to pc cam, and connect the usb to the pc, it wont even connect or give any opening instructions. i have windows xp.....what am i supposed to do in order to get my dxg-538 to work as a webcam????
JDeRuvo
  • 48 Answers
SOURCE: my camera is a dxg digital camera and its stuck on busy mode and doesn't know how to fix it can u help me?
busy mode? First thing I would do is reset the camera. This is a fairly easy procedure which involves either going into your setup menu and choosing "reset," holding down the menu key for 5 seconds, or, removing the batteries for a few minutes. It may be that the firmware loading got corrupted and the camera just needs to be "rebooted," which is something that turning it on/off won't accomplish. But after which, you should have the camera reset to factory default settings.
J. DeRuvo
Digital Camera HQ
Posted on Dec 18, 2007
IKnow
  • 68 Answers
SOURCE: DXG-608
DPS mode is used to connect this camera directly to a printer. Unhook any cables from the camera and use the mode dial to remove it from DPS mode.
Posted on Jan 11, 2008
SOURCE: DXG-538 Problems!!!!
i do not know how to turn it on
Posted on Jan 20, 2008
SOURCE: Cant install DXG-305
I am having same problems with WinXP but driverguide.com has a driver download that may help with your vista problem. If you are not a premium member you will go through several ads, but if it fixes the problem it will be well worth it
Posted on Apr 16, 2008
SOURCE: Video camera DXG-305V
for dxg 305v not working in windows vista I found the total solution to this problem. I am able to make my dxg 305v work in vista home premium addition now. To put it simple I bought a new computer with vista that also has a slot for the sd card that is in my dxg camera. If I should video or take pics on the camera, store it to the sd card and then place the sd card into the computer card reader-
-The pictures shot can be opened directly through the computer start menu choice (on the far right), then go to the icon for the sd card drive, then open the icon and appropriate folder containing the pictures on the memory card. then pics can be dragged and copied to the hard drive and opened up as any other photo picture file.
-The same thing can be done with the video files saved on the memory card, if you request that they be opening only with a free video player called divx, download it at http://www.divx.com/. No other vdeo player on the market, at least to what I have seen has the codex to open the video files except for divx.
I also did one other thing earlier. I have no idea if it assisted in the solution or not. I will probably never now. By chance from earlier on I went to http://dxgusa.helpserve.com/index.php?_m=downloads&_a=viewdownload&downloaditemid=24&nav=0
and downloaded the current driver available for the camera and all I can tell you is that this drive did not help in any way to get the computer to recognize the camera with the usb plug plugged in. Maybe it helped with the sd card being readable. I'm not sure.
any questions email me at pete32963@comcast.net
Posted on Jun 02, 2008
What is meaning of "
The USB mode controls what the camera looks like (behaves as) when you connect it to your computer. "Mass Storage" means that it will look like a flash drive, and it will appear as a disk drive in your Explorer on your computer. Hint: this is probably the mode that you want if you're going to copy your photos off from the camera.
To help understand this, if your camera could be used as a webcam (it probably can't) then it might have a 'webcam mode' where connecting it to the computer made it appear in "scanners and cameras" on your computer instead of in your Windows Explorer. In that case you wouldn't be able to copy photos off the camera because you wouldn't be able to browse to the folder that contained them.
There's a definition here: http://www.phonescoop.com/glossary/term.php?gid=356
Jan 22, 2011 | Sony Cyber-shot DSC-T10 Digital Camera
I do not know how to get the pictures from my camera to the computer. I have sim card and a usb cord.
www.dxgusa.com/CustomerService/Manuals/DXG305VE.pdf
http://www.dxgusa.com/downloads
OK, it's simple really, go to the below website and find and download your driver, install the Driver and software, then, when you connect up with the USB cable, the PC will "See" the camera, then you should see the camera as a "Drive" and as such you can, copy, pate, and cut, as normal.
May 26, 2010 | DXG Technology DXG-305V Digital Camera
HOW DO I USE THE CAMCORDER AS A WEBCAM?
You can use the USB mode to connect to a printer or a host PC. Before connecting to a printer or PC, refer to Installing software and drivers on the page 76 of the User Manual.
When the video camera is connected to the computer or printer using the USB cable, one menu displays in your monitor.
Use the joystick to highlight an option and press the scroll wheel inwards to confirm.
You can select PC Camera feature, when you set in this tag, the video camera can be used as a webcam for video conferencing.
I hope helped with this.
Dec 04, 2009 | DXG Technology DXG-565V Flash Media...
How do i download music to my samsung T919 from the computer
v\:* {behavior:url(#default#VML);} o\:* {behavior:url(#default#VML);} w\:* {behavior:url(#default#VML);} .shape {behavior:url(#default#VML);} Normal 0 false false false MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;} You can try to use the phone as a mass storage.
1. Insert a formatted memory card into the memory card slot on the handset, located under the battery cover
2. Navigate to the location of the MP3 file(s) then copy to the Windows clipboard
3. Plug the USB cable into both the handset & the PC
4. If the Select USB Mode box appears on the phone display, select Mass Storage
o If the Select USB Mode box doesn't appear, change the USB setting to Mass Storage
o When successfully connected, the handset will show the connected icon clip_image001.gif on the top of the display
5. A new Removable Disk box will appear on the PC's monitor, prompting "What do you want Windows to do?"
6. Double click on "Open folder to view files using Windows Explorer"
7. Paste the MP3 file(s) into the phone's Sounds folder
Jul 17, 2009 | Samsung Cell Phones
Uploading pics
- Connect the smaller end of the USB
cable into the USB port of your DXG.
- Connect the other end of the USB cable to your computer's USB port.
- The Digital video camera’s LCD Panel will turn on and will display
the PC Connection Menu
- Press the select button up or down button to select Mass Storage
Device option on the menu screen.
Goto my computer, you can see new 1 drive appear (or 2 if you have SD card in your DXG). So now you can copy/upload your pictures to your computer hard disk.
May 31, 2009 | DXG Technology DXG-305V Digital Camera
I,ve missed my operating manuel for my DXG 538 digital camera. can you help me find a replacemrnt book?
Hey,
try this page and let me know if you get it. I haven't test this one.
http://www.devicemanuals.com/guide/Digital%20Cameras/DXG/DXG-538-User-Guide-TmpJNU56az.html
open the above page and find where it says
DXG-538 User Guide Download
Let me know if you need anything else.
Thanks,
Ekse
Mar 04, 2009 | Cameras
Pc camera dose not work properly even if software is installed.
there is a web cam mode in the camera settings put it on webcam mode check the settings in camera , and then connect it to ur computer actually u are connecting in usb mass storage mode it will only allow u to copy pics to ur PC for webcam if ur camera supports it u should have this mode in ur camera menu check and then connect it thru usb see if it works ok
pls vote fixya if i fixed ur problem
regards
zohail
Feb 02, 2009 | Vivitar ViviCam 5355 Digital Camera
Using DXG 506v as webcam
when you hook your camcorder in via USB cord, there will be 3 options, mass storage, DPS, and pc cam, choose the third and usualy chatting websites will automatically recognise the camera and your all set!
Apr 09, 2008 | DXG Technology DXG-506V DV Digital...
Dxg digital camera
use a USB cord found at a local computer store or even kmart, choose mass storage when you hook it in, a window will pop up, go down until you see "open folder to view files" go to DCIM, then go to 200img, and your photos will be there, from there, just copy them to a picture folder
Apr 04, 2008 | DXG Technology DXG-506V DV Digital...
Nov 19, 2007 | DXG Technology DXG-538 Digital Camera
DXG Technology DXG-538 Digital Camera Logo
77 people viewed this question
Top DXG Technology Cameras Experts
Jerry Greenberg
Jerry Greenberg
Derick Williams
Level 1 Expert
Are you a DXG Technology Camera Expert? Answer questions, earn points and help others
