Question about Williams Heating & Cooling
Heater not heating in middle area or furnace
I have a Williams gravity vented wall furnace. model #: 3509622
serial #: J 094628
It turns on, but is not heating up all the area of the furnace. I am only feeling heat from top portion of the furnace and everthing below that, I can't feel anything. Wher the pilot and the burner is at, I can see it lit and burning...
Can you tell me what the issue is?
thank you in advance!!
CLEAN!!
Posted on Dec 10, 2009
Williams wall heater 2509622. How do I keep the pilot on? It tends to turn off after it reaches the desired temperature.
WILLIAMS 2509622 OWNER'S MANUAL Pdf Download.
www.manualslib.com > Brands > Williams Manuals > Furnace > 2509622
2509622; 2539622; 2559622; 3509622; 3539622; 3559622; ... WHAT TO DO IF YOU SMELL GAS: ... Williams furnace co. direct-vent wall furnace owner's manual (24 pages) ... Caring for Your Furnace ............24-25 Locating Wall Furnace and Thermostat ........6-7 Learn how to keep your new Williams Furnace operating.
How to light Heater or Furnace Pilot Light Gas Pilot of ...
? 5:01
https://www.youtube.com/watch?v=FZVQmKTYTTg
Oct 25, 2013 - Uploaded by 3p0cHx
How to light a gas pilot for a heater or furnace of the Williamstype. This is a general guide and is not ...
[PDF]Monterey Installation Instruction Manual - Home Depot
Dec 08, 2015 | Williams Heating & Cooling
The pilot goes out when the heater cycles
The thermocouple is not working correctly. sometimes you can clean the soot build up from it and it will work again. sometimes they just need replacing. the thermocouple is what the pilot light flame heats up when you turn on the heater. when the thermocouple gets hot it sends a 20 to 60 millivolt signal to the gas valve to activate the gas flow to the main burner.
Feb 18, 2015 | Williams Wall Heaters: 50,000 BTU/Hr...
Chimney type wall furnace. The furnace won't start However after switch was off for a couple hours and turn on the switch it started. What is a possible problem?
The problem sounds like the thermocouple is not working correctly. After being off for a couple hours allowed it to cool down and reset. Sometimes you can clean the soot build up from it and it will work again. Sometimes they just need replacing. the thermocouple is what the pilot light flame heats up when you turn on the heater. when the thermocouple gets hot it sends a 20 to 60 millivolt signal to the gas valve to activate the gas flow to the main burner.
Feb 16, 2015 | Williams Wall Heaters: 50,000 BTU/Hr...
3509622 model number furnace heats up but does not blow any air out. Neither hot or cold air.
You are describing a Convection heater , they do not have any fans inside.
Nov 08, 2013 | Thermos 3509622 Heater
It is a Williams circa 1985 gravity direct vent wall furnace mdel 30DV 5, 30,000 btu. Light pilot OK. Heat on OK. But when heat not called for (several hours) pilot must go out. There is a small penny...
That hole should only be a problem, if a strong draft comes thru and blows the pilot out. But that hole may also be for match lighting the pilot in an emergency. The older models like yours, had that feature. Check it closely, before you decide to block off the hole.
Hope this helped you.
Jun 19, 2011 | Williams 3003622 Ceramic Wall Mounted...
I have a Williams Ceramic Gas Wall Mounted Panel Heater, the pilot is on but the furnance is not working
Jump the two wires going to the thermostat, if it starts , you have either a bad thermostat or a broken thermostat wire. If it does not fire up, you will need to check for 24 volts AC going to the gas valve from the transformer. If you have voltage, you have a gas valve issue. If no voltage, check for a limit switch that may have overheated with an Ohm meter. If they all test good, replace the transformer.
Jan 22, 2010 | Williams 2509612 Ceramic Mid-Size Heater
How to reset vent safety switch Williams wall furnace model 3509622
the reset is at the top left side of the furnace. take the cover off n press the red button. the switch could be failing but CHECK drafting through the furnace. hold a flame at the top of the furnace n make sure its pulling inward. u could have a blocked vent pipe or vent cap which will cause excessive heat n tip the safety switch. good luck!
Nov 24, 2009 | Heating & Cooling
Williams heater 3509622
Go to the home depot website, they have pdf files for all the williams heates.
May 29, 2008 | Williams 2509612 Ceramic Mid-Size Heater
Williams gravity vented wall furnance - where is the pilot?
Its in the bottom of the heater behind the vent cover . I don't know where you are but your local gas utility will come out and lite this for free.
Dec 10, 2007 | Williams 2509612 Ceramic Mid-Size Heater
Heating & Cooling Logo
284 people viewed this question
Top Williams Heating & Cooling Experts
Paul Carew
vance jones
Superior Maintenance
Are you a Williams Heating and Cooling Expert? Answer questions, earn points and help others
