Question about B&W ASW1000 Speaker
Sub kicking out full volume bass for no reason
Hi. My sub is driving me nuts. It (apparently randomly) goes to full volume, then will stay on for a random amount of time. It happens regardless of what is being played, what RCA leads are being used, or what input (left, right, or both). Moving the lead (at either the sub or amp end) *sometimes* makes the bass stop.
It's now doing it 30% of the time and is un-useable as a result. Someone in a hifi shop recommended taking unscrewing the back & blowing the connections with an aerosol blower which I did best I can, but the inside of the RCA's are mainly covered with plastic so I'm not sure that it would've done any good anyway.
Any help is much appreciated!
  • 1 more comment
  • BWtroubles Jan 21, 2008
    Anybody?
  • BWtroubles Jan 26, 2008
    You're poo!
  • Anonymous Jul 17, 2008
    SAME EXACT PROBLEM... SAME EXACT SUB... can anyone help??
It's you power from the battery/alternator, it's not supplying enough power to kick it on, if you turn the volume down you'll notice that it'll stay on. You may need to re adjust the settings on your amp or get a bigger alternator, maybe even install a second battery.
Posted on Dec 22, 2008
  • Anonymous Dec 22, 2008
    if it's a home theater try buying a amp. with a greater output, my last post was for auto, but the reasons are the same
6ya staff
SOURCE:
Volume controll is going nuts.
Hi Manuel
I suppose the problem of your unit is memory, sometimes this problem can be fix by applying service mode, but if not, then memory should be replace and I would advise you to send your unit to service center.
Jan 16, 2014 | Televison & Video
Xtc 7500w amp
The amp might be on protection mode when both subs are driven...sign of an overloading problem. Does it work fine at lower volume levels? Check also the amp's supply voltage if it fluctuates out of tolerance level...might also be a loose connection in the wiring or terminals in the supply rails.
Jan 05, 2014 | Motorcycles
I need to turn up the bass on my denon amp
A few ways to get more bass here you go John.
If you have a sub check your level and crossover settings on sub and on amp, on the sub half volume and 90-120 crossover should be kicking,
Run a speaker level test on your denon and turn up sub channel.
if you want more bass in your speakers press the tone button on the front panal. for some i believe its in the menu system under parameter
Depending on what the source is you can turn up the bass on the source. aka ipod, some dvd players and what have you.
Chris B
PHTBA tech
Dec 20, 2009 | Denon AVR-587
My bass keeps turning off and on. I can be driving thinking my bass is fine, then it just kicks in. Sounds great but then you can here the bass just shut off and feel the non solid bass.
Your probably overheating your amp from running at too low impedance. Check what your amp minimum impedance is, and make sure you have your subs wired at or above that. Remember, if your running a multi channel amp bridged the minimum impedance goes up. Check the manual and see what the bridged impedance is if your have your amp bridged. If this isn't the problem, check your sub wires and make sure they're good and secure, and not connecting, and disconnecting... Hope this solves your problem
Sep 15, 2009 | Car Audio & Video
Bass freezes at a certain volumn and no longer gets higher
JUST CHECK THE CROSSOVER SWITCH, AND MAKE SURE THE SWITCHES ARE IN THE CORRECT POSITIONS
May 22, 2009 | Jl Audio 500/1 Car Audio Amplifier
Kicker CVR 10" "stuck"
sounds like the wiring in the speaker from the factory is shoty. rare but does happen. if you bought this from a retailer and have all of your warranty information id send it back and let em fix it
Mar 03, 2009 | Kicker Solo-Baric L7 S15L72 Car Subwoofer
Sub volume stays the same
in the back of head unit u might have 2 pre outs try swicthing them if u dont then on the amp u should have nobs turn them all the way up
Jun 16, 2008 | Kicker CVR12 Car Subwoofer
Bass sounds flat when volume is increased
probably your power is too short, increase your gauge wire, and your ground wire of the amplifier has to be shortly as possible, and the positive has to be enough to support peak power, you can also put a big capacitor on the positive wire to give some more power while the bass peak.
Apr 26, 2008 | Earthquake Sound PH-D2 Car Audio Amplifier
Subwoofer help
hard to tell whats causing this .Just curious make sure speaker wires going to subs are POLARIZED meaning positive from amp is with positive at woofer and NEGATIVE is with negative at woofer.When these are crossed and when volume is raised you will hear the bass cancell each other out..
Dec 06, 2007 | Car Audio & Video
Subwoofer Trouble
Turn the bass gain all the way down., Turn up your your volume on bass test song. Crank up the little box next to the steering wheel wide open . Now go gradually turn up the bass gain on the RF amp until you get distortion. Turn the gain down slightly. Now you can enjoy playing the bass from one end of the little boxes setting to the other without ovrloading your amp and subs. Open a can of whoopass on anyone who tries to crank up on your gain.
Nov 09, 2007 | Car Audio & Video
B&W ASW1000 Speaker Logo
186 people viewed this question
Top B&W Audio Players & Recorders Experts
Marvin
Marvin
Andrew Taylor
Andrew Taylor
Are you a B&W Audio Player and Recorder Expert? Answer questions, earn points and help others
