Question about Kenmore Dryers
Kenmore dryer Model 11072822101 still not right
Hi again,
We replaced the belt on the drum with no problem...but since then the dryer turns but with 2 new problems:
1. it squeeks wnd shrieks a bit when turning and
2. we're not getting heat just air dry. We hear the whoosh of the gas sometimes but it doesn't last. Could it be a sensor problem, etc.?
    Brigadier General:
  • 3,917 Answers
Hi
Please check this link...it will give you an in-depth knowledge about your problem with the dryer..
http://apwagner.wordpress.com/2008/05/16/5-common-clothes-dryer-problems/
Thanks for contacting fixya.com
Posted on Dec 09, 2009
11076812693 drum won't turn.
Kenmore Dryer Model 110.76812693 (11076812693) Drum ...
www.repairclinic.com/.../Model-11076812693-Kenmore-Dryer-Drum-T...
Kenmore Dryer Model 110.76812693 (11076812693) Drum & Tub Parts in stock. One million parts for 125 brands. Guaranteed same-day shipping. Call 7 days ...
Kenmore Dryer Model 110.76812693 (11076812693) Motor ...
www.repairclinic.com/.../Model-11076812693-Kenmore-Dryer-Motor-...
Includes pulley for dryer drum drive belt. Other shaft has reverse threads for blower wheel. Common symptoms of a bad drive motor are: -Dryer stops turning ...
Kenmore, Whirlpool Dryer Repair - Heats properly, drum will ...
? 6:29
https://www.youtube.com/watch?v=bOShDc4kLfk
Jul 10, 2013 - Uploaded by ApplianceVideo.com
Service a Kenmore Dryer with some of the following issues: Heats but ... Kenmore, Whirlpool Dryer Repair - Heats properly,drum will not turn - 11068202794 ..... Whirlpool Kenmore Maytag Amana Dryer Won't Start - Easy Fix ...
How To Fix Dryer That Won't Tumble ' Dryer Repair
www.partselect.com/Repair/Dryer/Will-Not-Tumble/
Feb 08, 2016 | Kenmore Dryers
My dryer heat but tub want turn i open the back and the belt was laying on the floor on the rt. side i would like to know if i would be able to replace it or not.
Hi again, Your parts can be found here:
http://www.searspartsdirect.com/partsdirect/part-model/Kenmore-Parts/Dryer-Parts/Model-11086880800/0582/0151200?searchedModel=86880800&blt=11
The belt is item 30 of this page:
http://www.searspartsdirect.com/partsdirect/part-model/Kenmore-Parts/Dryer-Parts/Model-11086880800/0582/0151200/00041279/00002?blt=06&prst=&shdMod=
The manual that will help you is here:
https://secured.whirlpool.com/Service/SrvTechAdm.nsf/2cd44500d572193285256a45004fd9d6/4829abde74a34d7f85256ab000620794/$FILE/4322260.pdf
Removal of the top is on page 19 / 14 printed of the pdf file
Removal of the toe panel is on page 20 / 15 printed if the pdf file
Removal of the front panel in on page 24 / 19 printed of the pdf file
The belt is installed with the ribs against the drom and the udler pulley / motor routing for the belt can be found here:
http://www.repairclinic.com/Dryer-Belt-Diagrams#DiagramH
Once you have the drum loose inspect the rear bottom drum rollers and idle pulley for any signs of wear. Flat spots or hard to turn = replace.
Thanks for choosing FixYa,
Kelly
Mar 16, 2011 | Dryers
My Kenmore Dryer Model 65732 drum won't turn. I opened up the front so that I could see the drum and I can see that the belt is okay. I can also see that the rear drum seal has deteriorated. Can anyone...
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";} Hi,
There can be many reasons why your dryer will not start or turn...
The most common causes are the belt breaking or jumping off, or the motor going bad...
Here are a couple of tips that I wrote will help you to figure out why your dryer will not run...
Dryer Repair - The Dryer is not Turning
Dryer Repair - The dryer will not start
heatman101
Aug 11, 2010 | Kenmore Dryers
I have a used Kenmore Series 80 dryer & the drum stopped turning
Good day,
Not hard to do but check the 2 rear wheels that support the drum and change at the same time if needed. Inspect the belt tensioner as well.
Here's a good tutorial on the belt change.
http://www.wikihow.com/Replace-a-Dryer-Belt-on-Whirlpool-Models
Dec 15, 2009 | Dryers
Dryer drum does not turn
Most likely the belt broke, replace the belt
Aug 14, 2009 | Dryers
How to get into the cabinet? I have a Kenmore Dryer that hums but the drum won't turn, maybe belt! Model # 110 62942100 thanks, tom
Kenmore dryer belt
  • UNPLUG DRYER
  • remove lint filter
  • remove two screws in lint filter panel securing cabinet lid to filter frame
  • with putty knife or other blunt blade, depress clips ~2inches in from the front corners of the lid to release cabinet lid
  • tilt lid up
  • remove 1 screw from each side 1/3 the way down
  • remove cabinet front and door
  • motor bearings tensioner are all visible
  • lift out drum forwards
  • check support rollers felts and nylon glide bearings for wear
    (worn bearing surfaces are the most common cause of belt breakage, and you dont want to do it again next month)
  • make sure tensioner is still installed in cabinet base, sometimes breaking belts pull them out
  • loop belt around drum at prior wear marks
  • reinsert drum
  • pull tensioner to end of travel against spring
  • loop belt around motor pully and tensioner
  • relax tensioner
  • rotate drum by hand to make sure belt wont jump off.
Thanks
Fame !
May 04, 2009 | Kenmore 63942 Dryer
Drum does not turn
THE BELT HAS BROKEN,TO REPLACE REMOVE THE 2 LINT SCREEN SCREWS,PULL THE TOP TOWARD YOU AND UP,REMOVE THE 2 SCREWS FROM THE TOP FRONT PANEL ONE ON EACH SIDE,REMOVE THE DOOR SWITCH WIRES,PULL THE FRONT UP AND OFF,PUT THE NEW BELT AROUND THE DRUM AND UNDER THE DRUM PULLEY AND ONTO THE MOTOR PULLEY,PUT ALL BACK TOGETHER,YOU CAN GET THE MODEL NUMBER FROM INSIDE THE DRYER DOOR,GO TO YOUR LOCAL APPLIANCE PARTS STORE TO GET A BELT,OR GET IT FROM SEARS .COM
Mar 08, 2009 | Kenmore 63942 Dryer
Dryers Logo
50 people viewed this question
Top Kenmore Dryers Experts
Dan Webster
Dan Webster
Sal De
Tim Whalen
Are you a Kenmore Dryer Expert? Answer questions, earn points and help others
