Question about Lowrance GPS
Lowrance Endura-projections other than Lat/Long?
Can one change to a projection other than Lat/Long on the Lowrance Endura Sierra?
Yes, if you download the newest firmware upgrade version 1.2 it will add in other projections and datums, as well as fix other known issues. I would recommend that you run both the 1.1 and 1.2 upgrade for your Sierra, the 1.1 upgrade will fix some issues with the base map.
Both upgrades can be found at the following location: http://www.lowrance.com/en/Endura/More/
I hope this helps.
Posted on Dec 11, 2009
Where should I connect the NMEA data cables from my lowrance elite-5 chirp fishfinder combo unit.
you only use if you connect a radio with long/ lat display or auto pilot. otherwise do not connect them
Sep 22, 2014 | Boating
How do I program my lowrance to locate reefs if I have the lat log reference?
You can go to your GPS page and zoom out and then using your cursor pad and move your cursor so it is in the general area of your coordinates. Start zooming in andifferent as you do the the lat, long readings on your screen will become more precise. Continue to adjust your cursor position so the coordinates match up with known position you have. Continue until the cursor position on screen and your known coordinates match.
Push "ENTER" twice. Your way point will be saved at the current position of the cursor.
OR
Push your cursor pad to bring up your crosshairs on the GPS screen. Save that waypoint, then go in and edit the coordinates to match your location data and save it. The waypoint you created will move to the new coordinates.
Aug 10, 2014 | Lowrance HDS 5 Fishfinder GPS Chart...
ENDURA POWER BUTTON BROKEN
Sounds like the power button is pulled loose from the circuit board or the power switch went bad for some reason. You can't check this out as it is sealed to be waterproof and opening it violates the warranty. The only way to address this would be to send in to Lowrance Customer Service.
This should not be a common problem and should be covered by manufacturers warranty if still within the 1 yr warranty period. If out of warranty, Lowrance Customer Service should still be able to replace or repair it for some sort of cost.
To speak with US based Lowrance Customer Service, call toll-free at 1-800-324-1356, Monday through Friday from 8:30 am to 4:45 pm Central. Or email them at products@lowrance.com with problem, product model and serial number (located between the batteries in the battery compartment). CS On Hold times range between 0 and 4 minutes right now with Monday mornings being their busiest times.
A Lowrance Guy
Jan 30, 2012 | Lowrance Endura Out&Back Handheld GPS...
I just put a new lamp in my projection tv.....it is a kdf-42e2000....now there is a pink line on the top of the screen and a blue line on the bottom of the screen......the lamp i installed was a XL2000...
HI ,
I Advise to fixed that Lamp again ( sometime you fixed but one of any wire miss connectivity ).
Or Remove and fixed again all related Jack's you removed lat time.
If everything's OK , then Change lamp. try other one.
Shahzad - IT
DUBAI - U.A.E
Mar 12, 2011 | Sony Grand WEGA KDF-42WE655 42" Rear...
Why wont my lowrance endura outandback upload the 2010 lake master chip put in i updated the firmware and it still wont work
Two requirements:
1) You must have version 1.4 software on your Endura. Remove the map card, press and hold (10 sec.) the menu key until software information appears to see what you have. Upgrades are available on Lowrance's website.
2) You must have the Endura Compatible LakeMaster map card. These were made available in May 2010. The packages have an "Endura Compatible" sticker on the front.
Call LakeMaster regarding your options if the card is not Endura compatible.
Moccasinboy
Nov 27, 2010 | Lowrance Endura Out&Back Handheld GPS...
Navionics Gold charts will not display on a Lowrance Endura
i have lost my maps on the gold card Australia e&n i have not taken the card out of my lowrance gps sounder lms 339c since new some three & a half years can they be restored i have had no luck trying to contact navionics australia
Jun 07, 2010 | Navionics Gold United States East...
Lowrance Endura Safari screen has gone white.
sorry to say but its broke, same thing happened to me after one day of ownership, lowrance tech support had me return it for a replacement, he called it the white screen of death.
May 31, 2010 | Lowrance Endura Safari Handheld GPS...
How do I unlock a computer that has Windows XP if you do not remember the password?
On the login screen, press ctrl alt del twice fast, then type in administrator as the user and the password as blank. Once signed in, go to the accounts section in control panel and remove the password for the user.
Dec 30, 2009 | Lowrance Endura Sierra Handheld GPS...
How i can reset an a lowrance endura sierra?
Hello there:
here is what you can try to do is first unplug any power going to the unit and remove the battery these units have a internal reset device that will reset it'self after a given amount of time which is about 1 hour.
during this time press in on the power button for 2 minutes and if it has a reset button it press in on this for 2 min leave the battery and the power out of the unit for the rest of the remaining time i had mentioned.
now plug in the power cord back in it and start the unit now if it works ok simply turn off and replace the battery and you are now done ok
Hope this is very helpful for you
Best regards Michael
Dec 22, 2009 | Lowrance Endura Sierra Handheld GPS...
How do you get geocaches on a lowrance endura gps. plez help
Loading Geocaching information on the Endura Safari GPS
You can load individual caches into the Safari as a .loc file or load a pocket query file of up to 500 caches as a .gpx file.
The trick with the Safari is to load these onto the unit using the data cable that comes in the box. Connect the Safari to your computer using the data cable and transfer your .loc or .gpx files into the GPX folder on the device.
These files have to be in this GPX folder to be recognized by the device. It will not work if you load the .loc or .gpx files onto a microSD card and insert it into the bottom of the Safari. I am told that this will be fixed in the 1.2 software update that is supposed to come out at the beginning of December.
Once you have the files loaded, all you have to do is disconnect from the computer and wait for the Endura to restart, go to Main Menu --> Find --> Geocaches and see all of the caches listed. For .loc files, there will be limited information provided from Geocaching.com. For .gpx pocket query files, you will have access to the full description, cache size, terrain difficulty, find log and hints. The great thing about the Endura GPS products is that they have a great filter function for geocaches. I use this with my 7 yr old daughter when I only want to find caches that are easier to find and have full size traditional caches that are more likely to have better "treasure" inside. Hope this helps. Have fun!
Nov 15, 2009 | Lowrance Endura Safari Handheld GPS...
GPS Logo
116 people viewed this question
Top Lowrance GPS Experts
Marvin
Marvin
Harrie
Andrew Taylor
Andrew Taylor
Are you a Lowrance GPS Expert? Answer questions, earn points and help others
