Have Mits HDTV have horizontal lines running across screen, whats the problem? After it warms up, seems to lessen but does not go away.
  • Antonio Cruz May 11, 2010
    Hi if its a Dlp it will be an issue with the dmd This is how the dmd works:http://electronics.howstuffworks.com/dlp... Basically the dmd is a chip that carries 2 million pixels that create the image and colors .When its bad it will cause pixilation,color discoloration or stripes.If its an Lcd it seems you are experimenting a light engine problem.This is how your tv works:http://www.youtube.com/watch?v=ZLLHnQ4y-... So basically the 3 Lcd chips that create the colors and image is going bad and thats why you get that color discoloration.Contact Mitsu or look for your light engine online.God bless you and your house!
  • 336 Answers
Hi if its a Dlp it will be an issue with the dmd This is how the dmd works: http://electronics.howstuffworks.com/dlp1.htm Basically the dmd is a chip that carries 2 million pixels that create the image and colors .When its bad it will cause pixilation,color discoloration or stripes.If its an Lcd it seems you are experimenting a light engine problem.This is how your tv works: http://www.youtube.com/watch?v=ZLLHnQ4y-wo So basically the 3 Lcd chips that create the colors and image is going bad and thats why you get that color discoloration.Contact Mitsu or look for your light engine online.God bless you and your house!
Posted on Dec 09, 2009
My phillips 2006 hd tv has a black line across the screen with a snowy freeze
If you have parallel horizontal black lines on a white background, you can see the separation between the lines when it is viewed at close range (Figure 1). As you view the lines from further and further away,the image gets smaller, you eventually get to the point where you can no longer see the separation between the lines, and it looks like one line. Losing the ability to see separation in the lines is exactly what happens when you sit too far back from an HDTV set. If we apply the same principle to an HDTV, a 1080p resolution HDTV has to fit 1920 vertical and 1080 and horizontal black lines separated by the white space on the screen, (that is the pixel grid of a 1080p HDTV display). Furthermore the spaces between each cell of the grid need to be very small in relation to the area each cell occupies, or you will get a screen door type effect. A bigger HDTV can increase the size of the cells and the separation between the cells, so everything doesn't run together when you sit further back.
Performance chip
May 22, 2012 | Philips Televison & Video
Horizontal wavy lines on picture
Sounds like the convergence has failed. This video gives more details
Apr 12, 2012 | Mitsubishi WS-55513 55" Rear Projection...
Have horizontal lines across the screen and some
Yeah we have the same exact problem here. Defective TV....ours would correct itself after 30 mins, but now it's blurry all the time. I'm never dropping 2K on a SONY tv again.
Aug 01, 2010 | Sony Bravia KDL-46VL130 TV
Horizontal Lines in Picture, Picture Possibly Dimmer
The dimming is usually caused by the mirror needing polishing. The lines floating across the screen is usually caused by failed caps on the FMT board you can get the V26 FMT repair kit from
http://servicemanuals.vstore.ca/product_info.php/pName/v26-dlp-fmt-pwb-repair-kit/cName/repair-kits
Jul 07, 2010 | Mitsubishi WD-52525 52" Rear Projection...
Picture quality
Contact your local service rep as this sounds like a "not so easy fix' related to the main board or power supply (known issues with Mits boards, especially the capacitors). Cleaning, resetting, re-configuring will not likely make any difference. Verify the problem occurs across all input modes (such as DVD, etc). before taking any service actions.
Jun 25, 2009 | Mitsubishi WD-52525 52" Rear Projection...
Line in left side of screen
bad panel call mits has 2 year extended warraty for panel, need to call for authorized service center
Jun 04, 2009 | Televison & Video
H Lines on the left side of the screen
just in case you came across this - it is the light engine! $950 - thanks mits for complete junk
Oct 13, 2008 | Mitsubishi WD-52725 52". Rear Projection...
Horizontal lines on TV are bouncing across screen and will disappear after TV warms up (sometimes). Please help!
It's caps most likely and one of the more common that fail is C2p08 100mfd/16v in the 5v line. But there are undoubtedly others and you'll probably need to shop it to get them all...
A tech will use an ESR meter to test the caps, testing for their equivilent series resistance. Too high or open caps need to be replaced.
Caps are not that expensive so the parts cost will be minimal. But it is labor intensive to go through each circuit and find the failed ones...
Mits are some great Tv's though and worth the repair.
Bill
Dec 19, 2007 | Mitsubishi VS-45607 45" Rear Projection...
Televison & Video Logo
74 people viewed this question
Top Televison & Video Experts
