Question about E-Machines eMachines Monitor E15T4
Why does only 1/2 of my monitor screen flicker. Left side only
  • 585 Answers
You have one CCFL backlight or half of the inverter failing. My bet is on the inverter.
Posted on Dec 10, 2009
Can I fix a flickering band on VP2250wb?
It sounds like one of the backlights are going, or one of the inverter transformer and there are two capacitors near the inverter transformers that do give trouble. The monitor would need to be dismantled to investigate the problem and it will involve money, since it is four years old I would be inclined leave it alone until a new one is required.
Apr 15, 2012 | ViewSonic VP2250wb LCD Monitor
Picture flickering and faded on left had side of the screen
if rebooting the monitor would do no good, try to get a spare monitor cable if the same flickering issue took effect. If it is so, then call your pc provider to repair your monitor..
Nov 26, 2011 | Philips 47 in. LCD HDTV
Monitor flickers, similar to a fluorescent light bulb that is going out. Also, there is one line on the left side of the screen, going up and down, that changes color, but it comes and goes. I thought...
The problem is in the monitor screen, there is a large circuit board connected behind the main display screen. The video signal is feed to the main board and generates the proper color balance, the second problem is the lamp behind the display is flickering and breaking down. To repair this will not be cost effective, cheaper to replace the monitor. But I would suggest hooking a spare monitor to the computer to make sure there are no additional issues.
Jan 21, 2011 | Dell SE198WFP LCD Monitor
Sumsung 930b goes dim,and flickers after about 3 min.
This sounds like the inverter has gone bad. If the bulb were bad only, you would see a faint image on the screen with a flashlight.
The problem is on this monitor, it will probably cost about $100 or so to take it to a shop to get it fixed, and that is nearing the cost of a new monitor.
If you are a little bit handy, and can disassemble the monitor, you can replace the inverter. The hardest thing about this, is getting the monitor faceplate open. Just use something firm and softer, such as a nylon spudger (this is something you can find online) or you can carefully use a thin scredriver. You just have to be careful, those cases are really tight.
Here is a good guide for general ideas on how it is done.
http://www.instructables.com/id/Replace-LCD-Backlight-Inverter-on-Any-Monitor-for-/
Paul
Apr 09, 2009 | Samsung SyncMaster 930B 19" LCD Flat Panel...
Flickering at bottom left hand corner of screen
Remove every Electromagnetic interference source in a 50 CM radius: speakers (low cost speakers are unshielded), fan, transformer, UPS.
Make a symple test using an AM radio: if you ear noise when approaching the area (screen Off) remove the source of interference.
Some time a different orientation of devices will fix the problem.
It worked for me
Jan 10, 2009 | LG Studioworks 700S 17" CRT Monitor
I have noticed recently that the screen words flicker.
If the monitor is less than a year only, then your best bet is contact the manufacturer for warranty support.
http://www.acerpanam.com/synapse/forms/webpage.cfm?siteid=7117&areaid=2&website=AcerPanAm.com
Jun 14, 2008 | Acer AL2017 20" LCD Monitor
Westinghouse LCD monitor
flicker to which side, horizontaly or verticaly. does it compress from both side or all side. only flicker from sides or from the center also??????????
provide proper information for solution
Feb 08, 2008 | Gateway FPD2275W LCD Monitor
E-Machines eMachines Monitor E15T4 Logo
69 people viewed this question
Top E-Machines Computers & Internet Experts
Alun Cox
Are you an E-Machines Computer and Internet Expert? Answer questions, earn points and help others
