Back to:
Tags:
Thinkfree Corporation ThinkFree Office 2.0  for PC
Uninstall thinkfree premium
posted by jwtp on Jan 19, 2008
When I try to uninstall thinkfree premium a box opens which reads: "UNINSTALL HAS DETECTED THAT THINKFREE PREMIUM IS CURRENTLY RUNNING. It is NOT currently running at that point - no application is open!! The same box appears when I use XP's add/remove programmes! How can I uninstall this programme?
I have the same problem.
This Problem has been added to the Share Your Expertise Page under "My Work Queue".
Solution #1
posted on Jan 24, 2008
Not Rated (0)
Tangoblue
Rank:Wiz Wiz
Rating: 84%, 85 votes
Running (as in you using it) versus it being active in memory...(loaded on start up as a kernel) are different. There are two ways to fix that....first press ctrl, alt, delete simultaneously and
check both applications and processes. Secondly download Hijackthis (free)....install and do a scan....if you see anything that relates to your software....check the box and click on fix...then try to uninstall your application.
Was this solution helpful? Show your Appreciation by rating it:
Thank You!
Was the solution helpful?
Show your appreciation by commenting on Uninstall thinkfree premium:
I don't want to Accept this solution
Can you Help with these Business and Productivity Software problems?
please can you help me i need to find out what formula to...
i need an english manual for software program called...
Can I get sample codes for creation of access mdb file?...
I have a computer windows XP. To telephone I have the...
I had the Home/Student Edition pre-installed on my HP...
Loading problems.
Repair Service
Find Business and Pro. Repairman Near You:
Browse the Repair Directory
Repairman, Get Listed FREE
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
