Question about Kirby Generation 3 Bagged Upright Vacuum
We have a kirby generation 3 and it slows down and speeds up almost sounds like it is going do quit could this be a brush problem in the motor sometimes it will quit.
  • Kirby Expert
  • 324 Answers
You may need to service you Kirby. Go this page HERE, fill out Service Request Form and ship to us together with you Kirby. We will inspect it and will call you with an estimate.
Good Luck,
Rocky
Posted on Dec 10, 2009
  • 701 Answers
I think that you may need a new dive belt. You can get them here:
Kirby Generation 3 Belt
Posted on Dec 09, 2009
Kirby Sentria 2 burning smell (not belt)
Actually it can. If the machine has a defect but the good news is that is has a 3 year warranty. Take it to a Kirby authorized repair shop not a vac and sew and they will fix it right up....I am a factory authorized service tech for the Kirby co.
Dec 16, 2013 | Kirby Generation 3 Bagged Upright Vacuum
Kirby heritage 2 motor runs slow then speeds up with burning smell.
Replace your belt and clean your roller brush.
Mar 25, 2013 | Kirby Vacuums
Power light on but motor won't run. where do i
the motor carbon brushes need replacing which is a most difficult job to get the cleaner disassembled. Brushes are easy to fit if You have replaced carbon brushes in other appliances etc..
Getting to the brushes in the Kirby is very difficult...
Lee in Australia
Jul 28, 2011 | Kirby Generation 3 Bagged Upright Vacuum
My kirby g4 motor runs backwards and so the power drive when pushed forward wants to go backwards. I need the wiring diagram so I can get it wired correctly.
The wires to the switch, coming from the carbon brushes, have been reversed. The carbon brush closest to the switch goes on the lower switch terminal.
Dec 24, 2010 | Kirby Generation 3 Bagged Upright Vacuum
My kirby generation 3 wont come on
Make sure cord is not damaged. Check to see nothing is blocking hose or carpet nozzle(where beater brush is or brush roll). Plug unit in to a receptacle that you know has power going to it. (Lamp you know works when plugged into same. Using hose on front, make sure bag bottom completely attached to exhaust, the hose has a little arm like thing that will depress the safety switch on the front of the unit, and turn on using foot switch at the back of the unit. If these do not work, it could be one of two safety switches, dirt may have fouled or switch may need to be replaced. Authorized Kirby Dealer in your area: Replacement parts, Kirby Distributor, call: 1-800-437-7170 United States and Canada
Nov 01, 2009 | Kirby Generation 3 Bagged Upright Vacuum
The motor shaft on my G4 kirby gets very hot....any thoughts
take it in for its service,sounds like it needs a good cleaning.
Oct 19, 2009 | Kirby Generation 3 Bagged Upright Vacuum
There seems to been a high pitched sound in the motor. I'd describe it as a 'dry' sound, and the high pitch of it is very loud. I want to stop vacuuming because it's so loud. Are there any oil/greasing...
High pitched noise is not good. It may indicate that a bearing is going out. I would not use Kirby as it may lead to burned motor.
If you feel that it vibrates quite a bit too - then it may be only broken fan blade.
Fan blade - you are looking ar around $40-$50 and if this is a motor bearing - $60-$80. If anyone wants to charge you more - we will repair it but you will have to pay shipping both ways (roughly another $30 both ways all together)
Ohhh yeah - try it with the hose. If no sound then brush roll bearings may be bad...
Good Luck,
Rocky
If you want to send it for service - go to GoodVac.com click on SERVICE, print form, fill out and ship it here.
Apr 04, 2009 | Kirby Generation 3 Bagged Upright Vacuum
Kirby Generation 3
PUll the roller brush out and make sure it turns freely by hand. If not clean all hair and debris off the roller brush, you might also remove the end caps (one at a time) and clean the hair out from the bearings underneath the cap (in the shop I use WD-40 and a non-serated pairing-knife). Replace caps they only go one way. If you can not free up the brush you'll have to replace it.
If the brush spins freely probably just need a new belt they stretch out over time.
Jul 04, 2008 | Kirby Generation 3 Bagged Upright Vacuum
My G3 works with the hose, but not with the Tech Drive
Try removing the nozzle and poking a screwdriver in the little slot for the safety switch and seeing if it runs. Maybe the nozzle's poker isn't pushing it in adequately?
Apr 30, 2007 | Kirby Generation 3 Bagged Upright Vacuum
Kirby Generation 3 Bagged Upright Vacuum Logo
152 people viewed this question
Top Kirby Vacuums Experts
Jim Parker
Jim Parker
Richard Agent
Are you a Kirby Vacuum Expert? Answer questions, earn points and help others
