Question about HP Photosmart 2410 All-In-One InkJet Printer
I upgraded my windows xp to windows 7 now my hp 2410 program will not install properly. Is there a program for windows 7?
    Guru:
  • 110 Answers
Http://h10025.www1.hp.com/ewfrf/wc/softwareCategory?product=303753&lc=en&cc=us&dlc=en&lang=en&cc=us
here are the new drivers what happen is your cd does not contain the drivers for the new operating system. Hopes this helps
Posted on Dec 09, 2009
SOURCE:
How do I recover or repair bootini and bootsect for Windows XP Professional after uninstalling Windows 7 Ultimate?
It's good that you have the recovery cds. Do NOT reformat the hard drive. Restore with the cds so you'll have a clean install . You will need to have any software cds that did not come with the original pc in order for them to rebuild the registry entries. That is the easiest way because there won't be any left over files from Windows 7 after you restore to XP.
Jan 24, 2014 | Computers & Internet
Tip
Upgrade Windows XP to Windows 7 - it can be done!
Windows XP has been around for over 12 years. With that much time in use, there are bound to be situations where exporting data, finding install disks, installing the new OS, reinstalling the program and then restoring the data is not a viable option or is doomed to fail. What can you do if you are faced with this situation? Simply, upgrade the system to Windows 7!
Despite Microsoft's claim that there is no upgrade path from Windows XP to Windows 7, there is a way to make this happen. As a consultant, I am faced with this issue several times a month and fully expect this to rise as more companies transition to Windows 7. The reasons to upgrade the existing system range from legacy databases that cannot easily be exported and imported, software that is permanently associated with the specific PC hardware and software that require a hardware dongle that does not work with newer PC's. Regardless of the reason, there is a way to upgrade Windows XP to Windows 7.
Let me say at this point that the process to upgrade Windows XP to Windows 7 is involved and there are some things you will need to prepare for to make this process successful. If you have Windows XP 64 bit, you can upgrade to Windows 7 64 bit. If you have Windows XP 32 bit (as most installs are), you will have to use Windows 7 32 bit.
Tools you will need:
1. Download Windows Upgrade Advisor
2. External hard drive
3. Windows Vista Business Edition Service Pack 1 (no license needed)
4. Windows 7 Professional with license
The Prep:
As with any major change, you need to create a backup of the existing system. Use your favorite method of backing up the OS, data and system settings (I prefer to use Ghost to get an entire image of the hard drive in a short period of time).
Create the backup of Windows XP:
Before continuing, disconnect all hardware from the PC and uninstall all printers, scanners and any other hardware devices that will need a new Windows 7 driver. This step will save you time troubleshooting a failed device once Windows 7 is installed.
Also, verify the Administrator account log in and password or setup a new local Administrator level user login and password.
Run Windows Upgrade Advisor. This will indicate if there are any software or hardware that is currently in use that absolutely will NOT work with Windows 7. Evaluate all non-compatible software and hardware issue with the user and see if this is a "show stopper".
You can still proceed with the upgrade and see if you can make the software or hardware to work by changing the compatibility settings in Windows 7.
The Process:
With Windows XP running, put the Windows Vista Business disk in and start the upgrade process. When prompted, choose UPGRADE. (This process can take some time so be patient.) Let this finish and the system will reboot. Verify Windows Vista is properly installed by logging in using the local Administrator account.
Reboot Windows Vista at least 2 times, logging in each time, to ensure the new OS is working correctly.
With Windows Vista running, insert the Windows 7 disk and start the upgrade process. Choose the UPGRADE option again and let this complete (again, this will take some time so be patient). Once Windows 7 is installed, the system will reboot. Use the local Administrator account to login and test the OS to ensure it installed properly.
Test everything:
Test everything - log into each program and verify access and functionality. Do not skimp on this step - get the user to log in and watch them run their programs.
Once initial testing is complete, re-install the printers, scanners and other hardware that will need updated drivers to work correctly.
I have followed these steps numerous times and it has worked perfectly each time. Removing the printers and hardware before upgrading will save you time and was a lesson I learned after my first upgrade.
on Nov 09, 2013 | Microsoft Windows 7 Professional for PC
Tip
Upgrade Windows XP to Windows 7 - it is possible!
The Prep:
The Process:
Test everything:
on Nov 09, 2013 | Microsoft Windows XP Professional
I have windows 7 and wants to install hp psc 1310 but facing code 43
you probably have the wrong driver installed. Most likely you have upgraded to a 64 bit system, and the driver is 32 bit. Find out which system you're running (right click 'computer' and click 'properties').Disconnect the printer and Uninstall the software, then go to hp website and download the proper software and install here:
May 13, 2012 | HP PSC 1315 All-In-One InkJet Printer
Just sucessfully installed 64 bit Windows 7 upgrade from Vista. HP 2410 will not print.
You need the download the Windows 7 driver for the printer. Go to www.hp.com to see if they have a driver available for this printer
May 25, 2010 | HP PSC 2410 All-In-One InkJet Printer
I'm trying to upgrade a HP a530n from windows xp to windows 7. I keep getting- Error Code 0x80070002, Windows was unable to create a required installation folder. All windows xp updates are current. Any...
Does your computer meet all minimum requirements? Try the Windows 7 compatibility program before tryin to install and it will tell yopu what the problem is.
Apr 17, 2010 | Computers & Internet
Windows 7 hp audio hp pavilion dv1000 drivers I upgraded to windoes 7 from xp and i have no sound went to alot of sites but nothing
Sir, i have HP Pavilion dv 1000 (XP operating system). Recently, i upgrade it by Window 7 but Now audio driver is not working properly now. pl suggest to solve it.----- pratik
Jan 10, 2010 | HP Pavilion dv1000 Notebook
I like to install windows7 what i need to do?is
So far Windows 7 is turning out to be not only the fastest booting operating system but the most stable and user freindly...it is also very good at diagnosing its problems and fixing them. Download and run the Windows & advisor tool. This will scan your system and let you know if you have any possible trouble spots such as unsupported hardware or software. Now, drivers for devices are still not 100%, but if your machine originally came with the Vista Operating system then more than likely you are not going to experience any problems with the upgrade, Windows 7 is an upgrade to this and not a clean install.....but if you have XP, then you need to save your files to an external drive because Windows 7 cannot be upgraded from XP, it will do a format and clean install on your computer. There is a chance it will recover all your old XP files and programs and put them in a folder called "old windows", it will appear on your "C" drive. You can access your documents, pictures, music, etc....but programs may not run properly from that folder because there are no registery entries for them. Below is the Windows 7 advisor link......
http://www.microsoft.com/windows/windows-7/get/upgrade-advisor.aspx
Nov 04, 2009 | Gateway MX6920 Notebook
HP Photosmart 2410 All-In-One InkJet Printer Logo
67 people viewed this question
Clive
Clive
Thomas F. Schneider
