Question about Ovens
Frigidaire 24" single oven model fgb24l2asa
Sometimes but hardly always oven ignites and gas comes on but it almost gets up to temp and then shuts off. Most of the time, ignitor comes on and glows but no gas and it doens't turn on. I'm thinking the ignitor switch but could it be the safety valve or regulator? Help!
  • Anonymous Mar 21, 2009
    My oven just started to do this. I thought I was baking something until I went back 45 minutes later & the oven was still cool. I pressed different buttons, it ignited & began warming immediately. When I went back the next day no ignition again.
  • Anonymous Apr 22, 2009
    I have the same problem. The ignighter glows, but no gas...I tapped on the saftey valve and suddenly it lit. i'm guessing it's the saftey valve being that it is an electrical part.
4 Suggested Answers
captaynkyrk
  • 170 Answers
SOURCE: Frigidaire Gas Oven
The igniter needs to be replaced. I had the exact same thing happen to my oven. The igniter would glow, but after tested, it did not have enough amperage to actually ignite the gas, so the gas kept running with no ignition. You can get a replacement at an appliance parts store. If you have a friend or relative who is a heating/air conditioning repairperson they can test your current igniter. Good luck!
Posted on Jul 20, 2008
heatman101
  • 43501 Answers
SOURCE: Frigidaire FGB24L2ASA ignitor doesn't
The ignitor is not working right and is going bad....
have the repair man replace the ignitor, or DIY....
Check out this tip about your problem...
Oven not Working or
Oven not Heating
Oven Problems
Replacing the Igniter
heatman101
Posted on Apr 25, 2011
heatman101
  • 43501 Answers
SOURCE: Ignitor glows but burner doen't
Oven not Working or Oven not Heating
Oven Problems Replacing the Igniter
heatman101
Posted on Jul 26, 2011
Frigidarie stove model#PLGFZ390ECB burners and broiler works oven dont replace iginitor still do not work.
Good Afternoon Cheryl,
I understand that the burners and broiler are working in your Frigidaire range, model# PLGFZ390ECB, but the bake element does not work. I also see that you have replaced the igniter and it is still not working. I suggest contacting your local authorized technician for further assistance. They will be able to diagnose your appliance and determine why your oven will not come on. Hope this is helpful.
-Best Regards-
WP
Jul 01, 2014 | Frigidaire 24" Built-In Single Gas Wall...
Long preheat & strong gas order. Sometimes the oven will heat up & sometimes it wont. The broiler does not heat up at all.
The problem is usually the igniter not reaching the correct amp draw .When the igniter does not reach the correct amp draw it may allow the gas valve to partially open or not open at all. The igniters are inexpensive and easy to replace. This video will walk you thru the correct procedure for testing an oven igniter. It may be a different model but the testing will be the same.You can also enter your model # for diagrams and illustrations of your specific model. Not all models are available. All parts come with installation instructions.
Mar 11, 2011 | Frigidaire FGB24L2A Gas Single Oven
When i turn on bake i first smell gas then the burner goes on and off eratically and takes a long time to reach the temp model#fgb557cesd
Part #37 on diagram #3 will show the temperature probe that needs replacing.
http://www.appliancepartspros.com/partsearch/model.aspx?model_id=111385&diagram_id=232775#d232775
Jan 01, 2010 | Frigidaire 24" Built-In Single Gas Wall...
Our Frigidaire 24 in wall oven won't light. The igniter glows but there appears to not be any gas present.
The ignitor is weak and needs to be replaced. You can not tell by looking at it. You have to measure the amp draw through the ignitor.
Sep 01, 2009 | Frigidaire 24" Single Gas Wall Oven with...
Frigidaire gas wall oven clock unit sometimes says F1 and beeps.
F-1 is USUALLY a touch pad error, it thiniks something is stuck. The sensor error code is F-3.
Mar 17, 2009 | Frigidaire 24" Built-In Single Gas Wall...
Error F3 on display ovens beeps
the temperature probr is located inside your oven in one of the upper corners. it should be a round stick looking piece. some are removed from the front others are removed from the back.
Nov 26, 2008 | Frigidaire 24" Built-in Single Electric...
Frigidaire Gallery Professional Series - No clock/oven functions
i have an old model of the fridgedare gallery professional series stove. After self cleaning, the ignition sparks for the burners will not come off, they keep clicking and only stops when i pull out the plug. can you help me with this situation?
Nov 01, 2008 | Frigidaire FGB24S5A Gas Single Oven
Frigidaire Gas Oven
Jul 10, 2008 | Frigidaire FGB24L2A Gas Single Oven
Ovens Logo
266 people viewed this question
Top Ovens Experts
Marvin
Marvin
Sal De
Craig Butler
Craig Butler
Are you an Oven Expert? Answer questions, earn points and help others
