Burning Smell Maytag Washer Model LA112
We have had this wash for 20 some years and yesterday we were washing a medium sized load and a burning smell from the washer was very pronounced and we cut the washer off. After a while , with the washer full of water we went to spin cycle and it spun the water out with no smell. Try to fix or is it time to buy a new washer?
Rick & Joyce Ann Freeman
Elkin, NC
eandlfan
  • 9 Answers
SOURCE: washer repair
The transmission might have locked up causing the motor to overheat.
Posted on Dec 23, 2007
Destinova
  • 46 Answers
SOURCE: Kenmore Elite Heavy Duty King Size Capacity Top Load Washer Won't Spin/Agitata
I am sorry to say that you WILL need a tech to come out and service this unit.  From what you are telling me it is either a dead short in the motor, OR one of the conntections got wet and cause a short.  BUT I would put my money on the motor, since this is a direct drive unit.  Sorry
Posted on May 26, 2008
  • 39 Answers
SOURCE: very loud final spin cycle with burning rubber smell
Hi Mcbride2
It could be one of 2 things. 1 the belt. or 2 the main seal and bearing. i recomnd to get a tech just to make suer.
brent
Posted on Sep 16, 2008
huuum
  • 750 Answers
SOURCE: Front load washer doesn't spin
My Maytag® Neptune® washer filled with water, but it won't spin or drain-what now?
Start by making sure the machine is plugged into a live (working) electrical outlet. Then check the appropriate circuit breaker and reset it if necessary (or check the fuse if you have a fuse box).
Next, inspect the drain hoses and remove any kinks. Take a look at the drain, too - if it's clogged, call your usual drain service person.
Then close the washer door and firmly press the START/STOP button. In a few moments, after the door locks, the washer should begin to spin. (For your safety, the washer will not tumble or spin unless the door is closed and locked.)
If this doesn't work, please contact Customer Service at 1-800-688-9900 for toll-free assistance and service scheduling if necessary.
Posted on Oct 04, 2008
  • 78 Answers
SOURCE: Burning smell when my Maytag top load washing machine is running
Sounds like the belt is sliping. ether it's loose, or the trans needs lubed, or both.
Posted on Jan 14, 2009
Burning plastic smell from washer dryer combo
You have something between inner and outer tub remove top cover smell coming from air vents of outer tub then that is were it is
fun job its has to come all apart
Jun 28, 2016 | LG WM3987HW Front Load Washer / Dryer
My washer keep shorting out why is this
It may be the motor, transmission, or both. If these are shot on your washing machine, the result may be an electrical burning smell. Both are necessary to run your washing machine and can be costly to repair. The first thing to do if you notice an "electrical" smell in your washing machine and not a "rubber" burning smell, is to unplug the machine and call the manufacturer or a repairperson.
An electrical burning smell may also be caused by a water leak coming into contact with electrical wiring. Both are major concerns and should be addressed immediately. A water leak can cause structural damage in your home and can short out the electrical wiring in your washer and cause additional damage to the machine.
Another more likely cause of a burning smell in your washer is overloading. Adding too many clothes to your washing machine can stress the motor or transmission, causing them to overheat or malfunction and emit a burning smell.
If the washing machine is old (15 - 20 years) you could have nuisance tripping on aGFCI outlet, however that doesn't mean you get rid of the protection of the outlet, it means you probably should consider replacing the washing machine for a newer model.
Apr 30, 2011 | Washing Machines
Maytag washer model # MAVT236AWW Ser # 11354800GV This thing will not wash or drain or spin. It will fill up with water. I have smelled a burning smell and smoke filled the back room. To me it has...
Problems with a washing machine not spinning or not draining are often interrelated..
If you are having a problem with your top load washer then check out thistip...
Washing Machine does not Pump or Spin
If you are having problems with your front load washing machine then checkoutthis tip...
Front Load Washing machine not draining and or not spinning
heatman101
Apr 20, 2011 | Maytag Washing Machines
Washer has a burning smell and will not drain
the burning you smell is probably your belt. if you change the belt and it still has this problem then your transmition has failed. This is a very comon problem with maytag washers.
Apr 24, 2010 | Maytag PAV2300 Top Load Washer
Maytag washer sounds like a jackhammer when rinsing - this is a new thing with all loads. Yesterday it shut down mid cycle while still full of water and we smelled a burning rubber smell. Any ideas?
There is only one belt on the machine (the burning rubber smell, probably). Sounds like something is wrong with the clutch /drive mechanism. Unless your an accomplished DIY'er, it sounds like a job for the Maytag Man.
Sorry.........................
Sep 15, 2009 | Maytag PAV2300 Top Load Washer
Burning oil smell from washer
Sounds like you may have overloaded your machine and overheated the transmission. Try smaller load and see if you still have the smell.
Hope this helps.
Aug 07, 2009 | Maytag Bravos MTW6600T Top Load Washer
Jan 14, 2009 | Maytag SAV5710 Top Load Washer
Very loud final spin cycle with burning rubber smell
Hi Mcbride2
brent
Sep 06, 2008 | Maytag Neptune MAH5500B Front Load Washer
Maytag neptune 98 burning smell
check to see if the door boot is intact. if there is a hole in it water could be getting to the motor control board and you are in danger of shorting the machine out. the other possibility is the main computer board may be on its last legs and is doing a slow sizzle
Sep 18, 2007 | Maytag MAH6700AWW Neptune Front-Load...
Washing Machines Logo
196 people viewed this question
Top Washing Machines Experts
