Question about GE Model: WCVH6260HWW Kitchen Hood
GE FRONT LOADER WASHER Model#: WBVH5100HWW
I CAN NOT GET THIS MACHINE TO TAKE THE FABRIC SOFTNER OR LIQUID BLEACH, YES IT IS IN THE RIGHT SPOT TOO? IT TAKES THE REGULAR DETERGENT FINE BUT NOTHING ELSE?
  • info697 Sep 13, 2008
    same problem same machine, no one seems to know. Some guesses are the solonoid that dispenses the water to the fabric softner or the control board that tells the solonoid to turn on or off. Either case I believe it will not be warranteed. My unit is 1 1/2 years old.
You need to put the setting on whites in order for it to take the bleach. Not sure about the fabric softener. I use dryer sheets
Posted on Aug 21, 2008
I have a LG wave force top loader and I have a mold smell that doesn't go away. I have run the tub clean mode a few time, usually adding bleach to where you would normally add bleach. However I...
I have the same model washer and also have that gross mold smell. However, it has NOTHING to do with liquid fabric softener because I ONLY use dryer sheets.
May 02, 2012 | LG Washing Machines
The fabric softner reivore wont take in/ empty the fabric softner
I had this problem also. I pulled the drawer out, then removed the softener assembly. (the blue piece) In the front there is a hole that lets the softener liquid drain into the funnel to go into the machine. It was clogged with a little bit of dried up softener liquid. Cleared that and it worked fine. We've had the washer for 3 years and have had to do this several times. Seems to be a problem.
Oct 08, 2009 | GE WBVH6240F Front Load Washer
Fabric softner still in compartment after wash is completed
take out soap box first and clean,i would say that water valve coil is probably blown though,should read around 3kilohm resitance checked when unplugged hope this helps
May 06, 2009 | General Electric WBVH5100HWW Front Load...
My HE washer doesn't dispense the fabric softner
Try removing the dispenser cup - and washing the inner cup thoroughly- run a sanitary cycle with whites and chlorine bleach mold and mildew likes to haunt these front loaders - be sure to run a bleach hot water cycle once weekly
Mar 01, 2009 | Kenmore Elite 45986 Front Load Washer
"fabric softner staining the clothes"
make sure you delute it with water. yes fabric softner will start to stain your clothes if you use too much of it. I would recomend stop useing it for a while. so you can clean the washer out. There is a product called Washer magic or Affresh that cleans out residues built up in your washer. or you can just run several loads of HOT water and bleach to clean it out. The hot water will melt the left over fabric softner in your washer. Fabric softner is kind of like hardend bacon fat thats what it looks like in your washer after time and if you do not clean your washer it builds up and builds up.
Also i do recomend alternating liquid detergent and powdered detergent. The reason why is powder leaves a residue that liquid takes away and vise versa. try this and let me know how it goes
Feb 12, 2009 | Maytag PAV2300 Top Load Washer
Clean clothes that smell bad
Peace,
ngafm at your service!
You may have a small amount of water or lint lift in the machine somewhere that is not completely dumping out !
This is sometimes common on front loaders! Or the pump is weak!
I tell my customers to try running the washer without clothes once a week with hot water and a 1/4 cup of bleach!
. BUT the first load you do after this must be white in case there is a drop of bleach left in the system, that it does not spot bleach a white spot on your colored clothes!
If not this does not remedy the situation you will need hands on service!
please rate me here at our site before you sign off!
Thank You!
Sep 04, 2008 | Whirlpool Calypso GVW9959K Top Load Washer
Kenmore front loader
There are little holes for the liquid to release form in the cups.
Check that the holes are not clogged!
Sep 02, 2008 | Kenmore 22062 Top Load Washer
Fabric softner is building up in dispenser
Same deal - I have to soak up all the residual water in the softener dispenser between washes. (The detergent and bleach compartments are fine).
Jun 13, 2008 | GE WSXH208A Front Load Washer
Fridgidaire front loader washer/ problems with softner dispensor
In the back of the dispenser is a button / lever to press down to remove the entire dispenser. Remove it and take off the cover over the fabric softener / bleach chambers. You may find some junk under the cups in that cover, or in the tubes sticking up through the bottom of the dispenser.
The way this thing works is like this: You fill up the dispenser with the liquid, but that liquid doesn't get up to the top of the tubes. When it's time to dispense, the washer adds water to the appropriate chamber, raising the level to above the tube. The liquid then goes down the tube, creating a suction which (ideally) draws the rest of the liquid up into the cup, over the edge of the tube, and down the dispenser. The washer will add water several times to accomplish this. The system isn't perfect, but it usually works with few moving parts.
If the fabric softener is especially thick, it will have a hard time getting siphoned down through the tube. If it looks as thick after the wash as it did before the wash, the machine isn't adding the water to the cup. I believe on the Frigidaire, there's a separate valve (all part of the same valve assembly) for each dispenser chamber. If it isn't adding the water, you'll have to replace the whole valve assembly.
Mar 12, 2008 | Washing Machines
GE Model: WCVH6260HWW Kitchen Hood Logo
290 people viewed this question
Top Kitchen Ranges Experts
Ismael Rodriguez...
Craig Butler
Craig Butler
Sal De
Are you a Kitchen Range Expert? Answer questions, earn points and help others
