Question about Toshiba 2060 Copier
Toshiba 2060 Our Toshiba 2060 makes copies ok, but the paper is darker all over. I wouldn't call them streakes, although there are streaks down the paper. I would describe it as more or less a grey tinge to the paper. What you are coping is there but the surrounding area is grey. I have tried cleaing the wires and this does not seem to help one way or another. This seemed to happen almost over night, the copies were fine and then this just happened. The counter is 179,953. Is this a do it yourself project to fix or does it need more specilized tech. You can reach me at richbell50@hotmail.com. thanks Rich Bell
    President:
  • 1,944 Answers
I suspect your problem lies with the drum, toner or corona wire. I would advise to have a technician look at it.
Posted on Jan 19, 2008
    Genius:
  • 1,067 Answers
I would buy new lazor toner 1st cartridge to see if yoru s bad or out
When using the auto feed, copies come out with black streaks down center of page
If you only get streaks when using the automatic document feeder, then in most cases it is dirt on the scanner glass. You do not state model but if you can also scan flat objects, trying copying a piece of paper that way. If that copy comes out fine, then you definitely have dirty glasss, if that copy has streaks you either have dirt on the scanner itself or a faulty scanner unit.
May 08, 2015 | Office Equipment & Supplies
Copies come through with a black streak down the length of the paper.
Remove the image unit,change drum cleaning blade,clean the drum.
Nov 10, 2011 | Minolta EP1030/1030F CS/PRO Copier
I have an hp LaserJet 3015 PCL-6 all in one printer, copier & fax. When I use the copy function, there is a black streak running down the length of the copied paper. I tried replacing the toner...
Clean the thin glass strip that sits to the left of the flat bed glass.
That is the glass used when the ADF is being utilized.
There is dirt on it causing the black streak.
Oct 11, 2011 | HP LaserJet 3015 All-In-One Printer
Copies come out with gray streaks all the way through the entire page
if you are copying through the feeder check the small glass under the lid has not got any typex or ink stuck to it you check by placing a copy on the glass under the lid and do a copy here.. if no streaks apear then check the glass area.. also if you are printing to it and no streaks appear this area is the cause.. if it happens on teh print side too then you have a drum /dev wear issue and it may need replacing.
Jul 12, 2010 | Toshiba 2060 Copier
The receiver states that our faxes that we send are unreadable down the right side of the paper--white or dark streak. The faxes we receive are ok
The glass scanner window (narrow strip of glass) needs cleaning. One "spot" of dirt will appear as a streak on the receiving end.
If you "copy" a document you can check the streak and see how effective your cleaning is.
Sep 28, 2009 | Brother IntelliFax-2820 Laser Fax
HP 7410 streaks on scanning and copying
First you need to determine if it's doing from both the  top and the glass.
1-assuming you are using the feeder to fax,copy or scan (the part that automatically picks up the paper) it comes out with a streak. Make a copy putting the paper on the glass and look at the copy. Does it have the streak?
2-lift the top and look to the left there should be a small 1inch glass, this is where it makes the copies from the feeder, is there a dot or white out or is the glass dirty? that's your streak, the paper is moving to make the copy,so the dot now looks like a line as opposed to making a copy on the glass it just sits there so a dot will stay a dot.
2- Clean with water or alcohol.
Oct 23, 2007 | HP OfficeJet 7410 All-In-One InkJet...
Streaking
hi im jules_09.his there any error code?if no error code try to adjust the voltage on the exposure lamp,if that does not work can you send me a sample print at cmhal_09@yahoo.co so i can see the print .
Oct 14, 2007 | Toshiba 2060 Copier
82 people viewed this question
Top Toshiba Office Equipment & Supplies Experts
didi2005
jasbo
jasbo
Branko Djurdjevic
Branko Djurdjevic
Are you a Toshiba Office Equipment and Supply Expert? Answer questions, earn points and help others
