Question about Vehicle Parts & Accessories
Terrible odor coming from vents of 2000 dodge grand caravan. When the heater or just the vents are first put on a strong ordo comes from the vents. After a few minutes it goes away. This happens regardless if the heater, A/C or fresh air is on.
  • 486 Answers
THERE IS A CABIN FILTER IN THE FRONT UNDER THE WINDSHIELD THIS GETS DAMP AND MOLDY, NEEDS REPLACING
Posted on Dec 09, 2009
    Guru:
  • 642 Answers
It's usually caused by condensation in the A/C. Perfect place for fungus and algae to grow. Get yourself some aircon cleaner. Any spares shop would stock some. There are even some available online. Google should save you some trouble searching.
SOURCE:
How can i add damp tea bag at air intake vale to eliminate odor?
Check your inside filter most often behind the glove box or in that area. It may just need changing or something got in it.
Mar 02, 2015 | 2014 Dodge Grand Caravan
AC problem
Check under the dash to see if the duct work for the vents has come loose.
Jul 08, 2013 | 2000 Dodge Grand Caravan
Bad smell coming through the vents when I open the windows
There is a dead mouse inside of your vents. You will have to either take it to a repair facility or wait out the smell. It should pass after a couple weeks.
Jul 09, 2012 | Dodge 2007 Grand Caravan
Passenger side heat doesn't work in my 2007 Dodge Grand Caravan. There is no heat, only cold air, coming from the dash, floor, & defrost vents. There are dual temp controls for the driver &...
I really can't be sure off hand, but what you wrote looks like the control valves are sticking(these flaps allow air to go different directions at the vents). its located at the heater core(towards the left side of the heater core) under the plastic just under the dash. you can manually move them, encase they are stuck, they do stick sometimes. while checking the vent doors, make sure your vacuum lines are connected. also check to make sure your vent hoses are tight. I hope this helps
Jan 11, 2011 | 2007 Dodge Grand Caravan SXT Minivan
No air comes out the rear vents in my 99 dodge grand caravan what could it be?
If you don't hear the blower motor check the fuses and relays for the rear heater
Dec 30, 2009 | 1999 Dodge Caravan
Heat & air in our 06 Dodge Caravan won't blow out at the floor
unfortunatly yes the vent arm must be brokin and probaly is the cable going to it most of them u can access that by taking the cover where vent turn is located and just have a boo and see if its off or not
Dec 08, 2009 | 2006 Dodge Caravan
Glo Warm Self Venting Heater Model FB3B Emits strong odor
The propane may have a higher sulfur content; however, the odor may go away soon. It is probably caused by the dust and oxidation (micro-rust) that attached itself to every part of the heater while in storage, even though it was "sealed".
Sep 29, 2009 | Dyna-Glo D-E36 Infra-Red Wall Mounted...
2000 dodge grand caravan rear heater core tubes need replacing
a lot of pain and heart ache. even on a rack they are a pain . check with your dealer there wae a recall on them for failing its worth the phone call to see kdc744
Feb 08, 2009 | 2000 Dodge Grand Caravan
Heater blowing clod air
the heater core behind the dash may be bad, it is the coolant tank for the heater system that is to say it is where the heat comes from. kinda pricey to have repaired at a dealership, if you can hear the fan turning but no heat, than it is a good possibility, or a vent hose has fallen off, get down and check under the dash
Feb 01, 2009 | 2004 Dodge Grand Caravan
Vehicle Parts & Accessories Logo
95 people viewed this question
Top Vehicle Parts & Accessories Experts
Marvin
Marvin
Thomas Perkins
Thomas Perkins
Are you a Vehicle Part and Accessory Expert? Answer questions, earn points and help others
