Question about GPX MW3836 MP3 Player
Bought a gpx8gb digital media player for my daughter for christmas. I have downloaded her cd's into itunes library. Now how do I get those songs onto her media player?
    Guru:
    Mentor:
    An expert who has written 3 tips or uploaded 2 video tips.
  • 27 Answers
Very perfect tutorial as hunter19_46m said .here I would like to add my method.you could remove drm from iTunes music and then convert all of them to mp4 and put them onto her media player
Posted on Jan 27, 2010
  • GPX Master
  • 7,482 Answers
Check to see that when you rip a music CD that your music is not copy protected. The RIP function in your Windows Media Player will allow you to convert the music CDs you have purchased into either an MP3 or a WMA format.
To adjust the copy protection setting on your ripped music files,
  1. Open the Tools tab at the top of your Windows Media Player.
  2. Select Options and then select the Rip Music tab.
  3. Choose the type of music file as well as the quality with which you would like to save the music. (Your GPX player has the ability to play music files in both the MP3 and WMA format.)
  4. Make sure to use MTP when transferring copy protected WMA files.
If you are using Windows Vista with Windows Media Player 11, you will need to follow these instructions.
Note: You will be able to download purchased/subscribed songs to the unit.
  1. Start Windows Media Player 11 and then connect your unit to your computer. If you have not set up synchronization between your computer and this device, the Device Setup Wizard starts.
  2. In Device Setup - Configure Sync, write a name for your mp3 player.
  3. Click Finish. The window closes and the Sync feature in the Player is displayed.
  4. From the left pane of this Sync feature, you can select from Playlists or Library and you will see the content of these folders in the center pane.
  5. Select the songs or entire albums from the center pane.
  6. Drag these songs or albums into the Sync List, which is the right pane of the Sync feature.
  7. Click the Start Sync button on the Sync List pane.
  8. Repeat steps 4-7 for any other items that you want to copy to your unit.
If you are using Windows XP with Windows Media Player 10, you will need to follow these instructions.
  1. Start Windows Media Player 10 and then connect your unit to your computer. If you have not set up synchronization between your computer and this device, the Device Setup Wizard starts.
  2. In the Device Setup Wizard, select Manual.
  3. Click Finish. The wizard closes and the Sync feature in the Player is displayed.
  4. Select the Library option. On the left pane select Sync List.
  5. From the left pane you can select All Music or My Playlists and you will see the songs located within these folders in the center pane.
  6. Select the songs from the center pane, and drag them to the Sync List.
  9. Good Luck, I hope this helps
  10. Please rate me, Thank you
Posted on Dec 09, 2009
SOURCE:
Ok I bought a riptunes mp3 player for my daughter for Christmas. I read the instruction manual 3 times and nowhere does it mention how to download music from itunes or the computer anywhere. I purchased...
I Tunes is only for Ipods, they use an ACC format to play
Most other MP3 players use Windows Media Player (WMVor WMA) format or other format to play their music and videos on their players.
You can convert the I Tunes (ACC format) songs and videos to WMA/WMV or other formats by using a "Format Converter"
You can download a free format converter at: http://www.formatoz.com/
After you get the songs,videos converted, download them to Windows Media Player, plug in your MP3 player and it will be recognized by the Windows Media Player and then transfer your songs to your player.
You should be good to go.
This is a FREE answer, Please take time to rate me
Dec 26, 2010 | Audio Players & Recorders
How do i get my songs from itunes on my digital media player. it says it compatible with itunes. i used the easyrip to get songs but it wont transfer them onto my player says it cant. how do i get the...
The Help module in easyRip provides step by step instruction
(Media Manager Module -> PC Library -> PC Library -> Import Media to PC Library)
1. Click on the "Import Media" control in the Media Manager module
2. Click on the "Other" button
3. Click on the "Files" button
4. Place a check next to the "Import from iTunes" check box
5. Click on the "Import" button
NOTE: Your player only supports playback of non-DRM iTunes media. If the easyRip Player Loader module will not transfer them, you can drag and drop them from their location on your computer to the drive that is associated to your player (in My Computer)
Jan 04, 2010 | RCA M4304 Digital Media Player
I guess I'm a bit technically challenged. I
if the music is downloaded onto your computer it should be able to be imported into the iTunes library. just go to file in the upper left hand corner in the iTunes library and in the down menu go to add file to library, or add folder, whichever your music is in. then if the music shows in the iTunes library plug in your iPod and see if it shows up in the iTunes menu. if it does click on the icon and in the bottom right hand corner click sync. good luck!
Dec 29, 2009 | Apple iPod touch
My daughter has an ipod nano and i dont know how to put songs for free onto it. i need easy instructions plz......
You need to have iTunes installed on your computer. It's a free download from Apple. Load your CD's into iTunes or buy songs from the Apple iTunes Music Store. Connect your iPod and synch. Note: most songs are copyrighted so you can't get them for FREE, that is stealing.
Nov 24, 2009 | Apple iPod nano
Need instructions on downloading songs onto IPod Shuffle
First you'll need iTunes, download it here free. Once you have installed iTunes, plug your iPod into your computer, then start up iTunes(it may start up on it's own). You will see your iPod under devices on the left side of the iTunes window, click it. If you bought your iPod brand new, then you will have to set up and register your iPod, it's a very fast and easy process. Now you need to put all your music into your iTunes library, if you have music on a CD, then insert your CDs into your disc slot, iTunes will ask you if you want to rip your music to your library, say yes. Once you have moved all your music to your iTunes library, your iPod will automatically be synced with the music you have added.
Hope this helps!
Nov 17, 2009 | Apple iPod shuffle MP3 Player
How to fill songs in apple shuffel i-pod
Being an Apple product, the only way to upload music onto your ipod is exclusively through Apple's software: iTunes. Go to www.apple.com, and download and install iTunes. After this, upload your music into the iTunes library. Then, click and drag the songs you want onto your ipod in the right hand side of itunes.
Sep 21, 2009 | Apple iPod shuffle MP3 Player
Coby MP3 player says file error wont download songs onto it
You plug it in then go on to the internet and download Tune4mac ALSO FOR PC then once downloaded you open itunes and add all the songs you want on it then go to file then library then burn play list to disk then change blank cd to tune4mac then weight till done then just drag to mp300 mp3 player and done
Jun 30, 2009 | Coby MP300 MP3 Player
How do i get songs from iTunes on to my Sansa ?
you can add music into the itunes library, than select it and drop into the ipod,
i or you just sync automatically.
Mar 28, 2009 | SanDisk Sansa m240 MP3 Player
MP3 Songs were downloaded into library but wont synch onto GoGEAR
All GoGears are completely incompatible with iTunes, AAC format.
-Tha Mp3 Doctor
Dec 28, 2008 | Philips GOGEAR SA6045 MP3 Player
ITunes Library
No, you will need to move the songs over. You can do this by backing up your music on a CD thru Itunes, and restoring the CD on the second computer. If you have enough room on your ipod you can copy all your music onto it and restore on the remote computer.
Nov 12, 2007 | Apple iPod nano
GPX MW3836 MP3 Player Logo
164 people viewed this question
Top GPX Audio Players & Recorders Experts
Joe Negus
Joe Negus
Are you a GPX Audio Player and Recorder Expert? Answer questions, earn points and help others
