Question about Westell Wirespeed VersaLink (A99-327W11-00) Router (A99327W1100)
I can't connect with 100 duplex setting. it works
I can't connect with 100 duplex setting. it works fine at 10 but won't connect at 100 mbps. using verizon dsl and tried calling thier support but received no help. thank you
    Guru:
  • 1,738 Answers
You have to change the quality of service on your router.
Posted on Dec 09, 2009
No internet connection, a network cable is unpluged
check the cables - may be cable is not plugged in properly or cable is bad or else the DHCP device (modem or router )is turned off .
Also check in device manager (RIGHT CLICK ON MY COMPUTER - PROPERTIES - HARDWARE TAB - DEVICE MANAGER , CHECK IN NETWORK ADAPTER 10-100 ETHERNET STATUS ) should be enabled
if everything is fine then reduce the link speed - same process but double click on 10/100 Ethernet - click on advance tab - change the value to speed and duplex and set it to 10 mbps half duplex and click ok - close everything 30 secs it should change the status .
try with the very first one with cables first please .
Oct 04, 2010 | Computers & Internet
Hi, I purchased Trendnet TEW-651br today and set up the connection. Everything seemed to be working fine until I noticed I'm getting way too slow download speed. The reason I chose this rooter was 150...
Well The best way go get a new one... They are chep now ..you cant by a DLINK Ultra Fast data transfer for $69.99 they are good but if your want 8 to 10 HUB well it will be $160.. not bad
Sep 30, 2010 | Trendnet Wireless Home Router TEW651BR
How do i connect 2 d-link switches
i found that there is a MDI uplink port for cascading
Dlink DES-1016D 16-port 10/100 Switch
Product Features
  • 16 10/100Mbps ports
  • Full/half duplex support for each port
  • MDI uplink port for easy expansion Expansion is easy through a MDI uplink port. You cascade several switches together through this port to get more ports.
  • Auto-learning of network configuration
  • Flow control in full duplex mode for protection against data loss
  • Back pressure in half duplex mode
  • RAM buffer dynamically allocated for each port
What's Included?
  • DES-1016D Network Switch
  • Quick Installation Guide
  • CD ROM
Aug 27, 2010 | D-Link DES 1016D (DES-1016D) 16x10/100...
My internet speed is too slow, it only recieve 10Mbps as i view it on Lan. how can i make it to 100Mpbs? By the way my internet is connected on built-in lan (through Motherboard) do i have to buy Lan card...
So from Network Connections, you right-click the LAN connection, select status, and it displays Speed: 10 Mbps ?
If you select the Properties button from that dialog, and then with network card showing, select the Configure button; and from the properties shown on the Advanced tab, select Link Speed & Duplex. The value should be Auto Detect. If the LAN is configured correctly for 100 Mbps, you should get it.
Mar 01, 2010 | EliteGroup ECS G31T-M Motherboard - Quad...
Slow speed of data transfer 10 MBPS instead of 100 MBPS
the switch which ur pc is connected might have been set to 10 mbps ...if the switch is managable cisco switch try changing the port setting to 100mbps full duplex
Apr 18, 2009 | D-Link DE 824TP (DE-824TP) Networking Hub
I have a p5q-e with dual gigapots. but i cant get a network speed higher than 100 mps. my olr system works fine when i hook it up so its not the modem/connection...ect.i cant find any information in the...
hi,
If your network card or Lan Card is 10/100 Mbps, it cannot go higher than that. You can buy and intall new network card or lan card 100/1000 Mbps. And if you are using a switch, it support also the 100/1000 Mbps Card or else the speed will never go higher.
Andrezarion
Mar 22, 2009 | Computers & Internet
Intel 82562V-2 10/100 ethernet adapter does not turn back on from vista sleep mode
If you're using your system as the Host for the other systems, turn off your sleep mode. The Host should be active at ALL times.
Dec 09, 2008 | Intel Ethernet 10/100 Network Adapter
Running at 10 mbps
There's possibility that the network (router/modem/switch) you're trying to connect has limit to up to 10 Mbps only. Or it can be that the current LinkSpeed of the Ethernet adapter might be forced to 10 Mbps. Do the following to check this setting:
  1. Go to Control Panel> Network Connections.
  2. On Network Connections, look for Local Area Connection (for the D-Link adapter). Right click it then go to Properties.
  3. On Properties window, click Configure button.
  4. On the next window, go to Advanced tab.
  5. Look for Media Type, Connection Type, or LinkSpeed and Duplex Mode.
If the value is set to Auto Negotiation/ Auto/ AutoSense, try to force it to 100 Mbps.
Jul 22, 2008 | D-Link DFE-530TX Network Adapter
Network is SLOW
I can assist with the full and half duplex question...but I'll need a specific HP model number for the Procurve in order to give you correct advice about it.
If the Procurve is not configurable, or has never been configured, then it is using autonegotiation to determine speed and duplex. Each of your computers should also be set to auto for speed and duplex.
The general rule of thumb is to make sure that speed and duplex for both ports on a link are set the same. For example, if the port at one end of a cable is set manually, then the port at the other end must also be set manually...to the same speed and duplex values. If one port is set to auto, then the port at the other end of the cable must also be set to auto.
Jan 15, 2008 | HP ProCurve 24x10/100 Mbps Networking Hub
Switch port
switch setting
int f0/1
speed 100
dup full
and lan card shuld be shud be more then 100mbps or 1gb
then it will conect to full duplex means
u have to to any device shud have same duplex
Aug 11, 2007 | Cisco Catalyst 2950 24x10/100 Mbps...
Westell Wirespeed VersaLink (A99-327W11-00) Router (A99327W1100) Logo
167 people viewed this question
Top Westell Wirespeed Computers & Internet Experts
Prashant M
Prashant M
Michael Galve
Michael Galve
Are you a Westell Wirespeed Computer and Internet Expert? Answer questions, earn points and help others
