Question about Bissell 7920 ProHeat Pro-Tech Upright Wet/Dry Vacuum
Can't get the water to spray out when I turn it on?
  • 701 Answers
When it doesn't dispense water or solution that means that the pump belt needs to be replaced. You can get a replacement and view the manual here:
Bissell 7920 Pump Belt and Manual
Posted on Dec 09, 2009
LIttle Green Bissell Water goes directly to collection tank, won't spray
Had a problem with mine not spraying, took ot apart and the heater for the solution was plugged with scaling, cleaned it up and works the very best now. As far as clean water going directly into the collection tank, sounds like the little hose may have a break or a leak in the vacuum hose.
Mar 14, 2018 | Bissell Vacuums
Can't get the water to spray and the red star is not turning
DIY - Fix your bissell if it doesn't spray solution any longer ...
? 5:33
https://www.youtube.com/watch?v=SLyDeM10k9k
Feb 6, 2010 - Uploaded by kronomarine
Common problem with most Bissell Carpet Cleaners is that it stops ... to no one repeats my mistake, this is NOT the Bissel Proheat 2x Turbo Model .... water go back to use 8 months later and now it only sprays water ... I can't understand ANYTHING said to me by the Bissell reps in India or .... Get video URL.
All comments on DIY - Fix your bissell if it doesn't spray ...
Nov 28, 2015 | Bissell 7920 ProHeat Pro-Tech Upright...
Bissell pro heat wont spray water
Hi, it's Allie from Crucial Vacuum!
Your Bissell ProHeat 25A3 may have stopped spraying water for several reasons. Make sure the bladder or water tank of your unit is filled with water properly and that the 2-in-1 tank has been placed properly.
If the water tank/bladder is filled and the 2-in-1 tank is placed properly, your unit's pump may have lost prime, to check this turn your unit's power off and hold spray trigger for 30 seconds. Turn the machine back on and check the spray flow.
Another thing that may not be allowing your unit to spray properly or spray at all is having a clogged solution filter and may need to be cleaned.
Last, your unit's pump belt may be broken. To replace, turn off your unit and unplug from any electrical outlet. Use a flat head screwdriver into the slot of the belt access door to release where you should have access to your unit's pump belt.
You can purchase direct your replacement belts from Crucial Vacuum with free shipping and an exclusive 10% coupon for Fixya.com readers, use code: FIXYA10
http://www.crucialvacuum.com/bissell-proheat-2x-belts-2pk.html
I hope this was helpful. If you would like further assistance, please feel free to give us a call at 877.750.9239. We have helpful and friendly customer care representatives on the line ready to assist you.
Alejandra (Allie) Sepulveda-Rivera
Crucial Vacuum Customer Care
Oct 05, 2014 | Bissell Pro Heat Deep Cleaner Model 25A3,...
Solution will not spray on carpet unless you use tools or spot spray also brushes are not turning
proheat 9300
Remove the water tank. You will see 2 red tabbed plastic spray tubes.(where the spray comes out if not clogged) Pinch the clips to remove from the machine. Then you will need to pinch the hose clips to remove the red tabs from the hose. Clean out those red spray nozzles. Next step: have a towel ready and fill the solution tank with water. Put the solution (not water) tank on to where the water tank would go. Place the machine selection knob to rinse/wet only. Now with towel under the hoses that you removed the red tabs. Turn on the machine and pull the trigger to activate the water. You should see water flow out of the hoses that had the red tabs on them. If not, release and pull again the trigger several times. If only 1 hose has water coming out of it then block the one that works and try the process above again to de clog the one that isn't working. Good luck.
Dec 07, 2011 | Bissell 9500 ProHeat 2X CleanShot Upright...
My bissell steam cleaner will not spray any water
Check to ensure there is liquid in the water tank and the formula bottle.
Note: This machine will spray with liquid in the Water tank only if the machine is set to the Water Rinse setting. On any other setting, you need to have liquid in the formula tank as well.
If no: add liquid to the Water tank and the Formula tank.
If yes: check each of the following....
- Check the bottom of the Water Tank and the Formula Tank to make sure each has a red auto-load gasket attached. Make sure the Water Tank and the Formula Tank are seated properly.
- Ensure the tank lid is properly attached to the bottom of the tank. To attach this properly, remove the Water Tank from the machine. Hook the front window onto the lip of the bottom container and then allow the window with lid to cover the complete tank. Secure the latch on the back of the bottom tank to the back of the tank lid. THE TANK LID CANNOT BE ATTACHED PROPERLY IF THE BOTTOM TANK IS ALREADY INSTALLED IN THE MACHINE.
-If everything is seated and attached properly, prime the machine by turning off the power, waiting one minute, and then turning the power back on and depressing the trigger on the handle.
- If priming the unit fails to fix the problem, remove the handle completely and re-attach. Once the handle is re-attached, re-attempt to spray.
If the machine continues to not spray, check the following:
REMOVE THE COLLECTION TANK:
• Make sure the unit is set to water rinse
• Remove the smart mix bottle and fill it with water only
• Place the smart mix bottle into the collection tank reservoir
• Run the unit and try to spray. If the machine sprays, you will be able to see the water level decreasing in the smart mix bottle and you will need to replace the bottom tank. It is possibly warped.
Jun 15, 2010 | Bissell 9500 ProHeat 2X CleanShot Upright...
The unit sprays for the first few seconds after I turn the unit on and then stops spraying any water or solution. I turn it off, wait a few minutes and the same thing happens. What is going on and how...
This sounds as though the pump belt is slipping. This may be caused because the pump belt has stretched slightly or the pump is seized and will not turn. Remove the pump belt and turn the pump rotor with your fingers to see it turns freely. If it does then the pump should be OK but the belt may be stretched and will need replacing. If the unit does not spray after changing the belt then clean the spray nozzles at the front of the machine and make sure that water flows to the nozzles OK. You can check this by temporarily disconnecting the nozzles from the plastic pipes.
Main causes for no spray.
Bladder may be empty.
SmartMix Bottle may be empty.
The Filter may be clogged.
Tanks may not be seated properly.
Pump may have lost prime. Check all the fluid tubes / hoses for leaks or blockage (see below).
The Pump Belt may be broken.
2 front jets are blocked. This is a common problem. When the machine is standing for a while the detergent turns to a gel causing the blockage Lay the Bissell on its side then where the water comes out of the jets at the bottom of the machine unblock them using a pin to poke through the hole in the centre.
Try running hot water through the system with no detergent to empty out all the residual detergent. Keep running hot water through the system by pressing the button you press for it to spray the water do this for about 5 mins and keep swapping the water for hotter water as it starts to cool doing this 4 or 5 times might solve your problem if not get the tools out and start looking for the blockage. Do this once a month to ensure that the pipes and jets are kept clean and free of any detergent gel build up.
Oct 30, 2009 | Bissell 7901-R Clearview Proheat Plus...
Bissell Proheat does not spray water along cleaning brush. Seems to spray just down either side only.
Are the brushes turning? If not then that could be your problem. If they are, check the spray nozzles, they may be partially clogged. Try water a mix of vinegar and water thru it to see if it will unlog your kines and spray nozzles.
May 06, 2008 | Vacuums
Water spray
Are the brushes turning while you are shampooing? If not then this could be the problem. The turbine is what turns the brushes, it may have gone bad.
Mar 01, 2008 | Hoover V1 SteamVac SpinScrub Vacuum
Bissell 7920 ProHeat Pro-Tech Upright Wet/Dry Vacuum Logo
197 people viewed this question
Top Bissell Vacuums Experts
Jim Parker
Jim Parker
Are you a Bissell Vacuum Expert? Answer questions, earn points and help others
