No popwer to keyboard or mouse or monitor psu ok any ideas?
    Sergeant:
  • 208 Answers
Try clearing the memory, clear the CMOS on the board.Then start again, if still wont start, replace the RAM with new ones.
Posted on Dec 09, 2009
SOURCE:
Hp p7 1010 desk top will not turn on . and yes it is plugged in. checked the mouse, keyboard and momitor. why will it not turn on
the fans most both spin, CPU and PSU fans. in the PC
the PSU can be tested.
do you want to test it? y/n
If not get a shop to do that.
the mouse, nor keyboard nor monitor turn it on .
just that one button on the PC. case.
is the PC dead silent, we can start there.
the jumper test is here.
http://www.pcdied.com/power.html#rapid_testing
Sep 14, 2018 | HP Computers & Internet
Purchased a used compaq S5300NX desktop with monitor,keyboard,mouse, and other devices.First thing I did,was hookup the tower to my monitor,keyboard,mouse and internet connection. turned it on and it...
If there is noise "beep" then it has RAM issue/RAM port. If is not noising then it has motherboard issue. I guess you need to take it to the technician and ask him to fix or replace it.
Nov 04, 2013 | HP Compaq Presario S5300NX (DM174A#ABA) PC...
I have HCL Ezeebee desktop computer when we boot the system monitor, keyboard, mouse blink for a while and monitor (HCL) show 'no signal' message, and keyboard num lock led not display mouse i
No signal at the monitor indicates (if you know the monitor is working ok) a failure of the graphics chip or graphics card, The lack of indicator light on the num lock LED and the lack of power to the mouse would indicate that there is a major issue with the motherboard.
you can try using another monitor to confirm the problem lies with the graphics, and in the case of the keyboard and mouse, swap them for a usb version, if they work, the Ps2 ports are probably damaged.
I'd be thinking of replacing the motherboard
May 19, 2012 | Computers & Internet
On start up fan runs, no beeps, black screen, no response from keyboard & mouse. Unplugged everything for 30 minutes, then tried again, start up began then went to black screen, no keyboard, no m
in your case, there might be some problem with the main board.
usually no beeps will related to the processor error / mainboard error / ram error / PSU error
to check the processor : try to exchange the processor with the same type.
to check the Memory: try use rubber eraser to clean the cooper plate of the memory. then plugged it again.
in case if there is a power supply error, then try to exchange the power supply using other PC PSU.
if all steps above are checked, the problem might be at the mainboard. in that case, replacement will be the best option.
Jan 20, 2012 | Acer Computers & Internet
Computer does not display any boot screen, although it turns on. no USB ports work, not do any other inputs on the rear of the machine. this was done after migration of parts to a new case for the...
DC5000MT (i think you left off the"T" right?) MT=mini-tower then.
they at SFF then too.
old old desktop pentium 4, with pata hard drive?
no monitor stated, make nor model #
no vga card stated.
migrating? oops.. why do that? nor if PC ran before?
NO OS stated,? windows XP what? (it came with XP)
ok the mobo turns on with case power button?
and the CPU fan spins fast, as does PSU fan?
what does USB ports mean>? using what there?
PS/2 keyboard. using that? or pS2/mouse?
does it beep:?
are you sure the monitor is ok?
if monitor is ok ?
and PSU and 1 stick of ram is ok
the BIOS screens work.
or the PSU
does this mobo have onboard VGA jack GPU:>
if yes, try both it and PCI video card.
and 1 stick of ram at a time. slot1, bank 0
Aug 12, 2017 | HP DC5000M PC Desktop
HP Pavillion won't bring monitor back from sleep mode
hi...if u can read " no input signal" from ur screen, this means that ur monitor is ok..
Look if u have power buttons on ur keyboard.. try to wake it from there.. some pc may have shortcut keys to bring back the pc... look @ ur pc docs on the internet for more info...
However if it's a hardware issue, it may be that ur RAM memory needs to be cleaned
Feb 01, 2010 | HP Computers & Internet
Ccomponants will not power up
David,
Your hard drive is junk. Replace the hard drive.
May 23, 2009 | Computers & Internet
Microsoft Keyboard (1045) doesn't work with new Samsung Monitor
Hi
Keyboard and mouse have no connection with Monitor
Since keyboard and all are linked with mother board
so firstly i suggest you yo check the wireless connections are ok
Now reinstall the software packages that came with the keyboard(And drivers)
i hope this will help you
Mar 23, 2009 | Microsoft Wireless Notebook Optical Mouse...
Mouse Freezes
I have the same problem in Vista, I found a true and working solution apart of droping the mouse to the trash, ok, go to... http://www.a4tech.com/ go to the english version if you dont speak chinese, then find the driver for the mouse model ***-49Z, and there is the solution, GE isnt the builder of this mouse.
Take Care.
HMMxD
Greetings from Mexico.
Jan 12, 2009 | GE HO97769 Deluxe Optical Mouse
Power supply
There wouldn't be anything from the PSU giving power to your keyboard and mouse. The mobo handles that unless your giving your mobo the wrong amount it needs which might be why your P2P and USB arn't working. Although it is odd that your mouse isn't working with P2P as that requires less power.
Sep 29, 2008 | Compaq (243890-001) 250-Watt Power Supply
Computers & Internet Logo
59 people viewed this question
Alun Cox
k24674
