Question about Sony DVP-NC675P Multi-disc DVD Player
Sony DVP-NC675P - Sometimes it won't spin a DVD, but the (disk) motor IS spinning. Also (again, sometimes) just quits playing in the middle of a movie and turns off. Cleand rubber disk-grip and magnetic spendle - helped, but still does the same thing occasionally. Help?
  • 3 Answers
You want me to pay you for your "help," but want me to tell you how I fixed the problem -- for free! Send me $14.99 and I'll be glad to tell you.
Posted on Dec 10, 2009
My Sony DVP-CX995V quit playing DVD's. I was listening to a CD, stoped it, went to menu, picked a DVD and bow it say's " Cannot Read Disc " On ALL of My DVD's. All CD's & DVD's are storebought. I've had...
does the spindle motor even try and spin the disk? Pop the top (8 screws) and watch the loader grab a disk and place into transport. The disc should immediantly start to spin and the little laser should scoot back and forth looking for something. If the disc never spins but the laser is moving, you may have a bad motor, or a bad pickup (transport mechanism includes motor and laser pickup). A replacement for this model is about $125 but you can get the same part out of a cheap DVP-S360 for about $20 on ebay. Just make sure you ask if it works before you buy it on BOTH CD and DVD as its 2 different lasers in that part.
Sep 09, 2013 | Sony DVP-CX850D DVD Player
Dvd not spinning properly
I had the exact same problem.
There was a bad batch of spindle motors (why they didn't use brushless is any body's guess). I replaced mine and it is quite easy. I even soldered in the single-DVD player's (same basic model number, just not multi-disk) motor because I couldn't find the right part for the multi-disk model (or the single was cheaper, I forget). That was years ago and it still works great today (I didn't like the lack of features on a cheap replacement player).
Apr 08, 2008 | Sony DVP-NC675P Multi-disc DVD Player
Sony dvp-fx750 dvdplayer is dvd disc is nodisc problem ,but audio cd,vcd runing
In most cases when the CD does not play it is possible that the optical head is a suspect. Sometimes it might pick up ordinary audio CD but will not play other formats. This indicates that the optical head is weak and so there is no detection or scanning of the CD . If the optical is working the tracks will be read immediately but with no scanning the laser head can be defective.
The main motor will not work in some cases as unless the tracks are read the drive motor will not work with signal from the processor. Also in some cases the central motor base can shift and so the distance to the disc can be more resulting in low detection. You can pull up the spindle to come closer.
Sometimes certain cleaner disks will not be tracked to run for cleaning as it will not be read and so will reject. Hence it is ideal to manually clean the laser head eye using a cleaning swap /cotton bud with gentle pressure on the lens eye.
If there is no result then watch if the CD spins or tries to spin. If so the board seems to work unless a test is taken on the main board but the possibility of a defective optical head can be the suspected fault.
If any of the above seems otherwise we must recheck with possibilities of a malfunction of the main processor board
Thank you for using Fixya
Sep 03, 2011 | Sony DVP-FX750 Portable DVD Player
I have a Sony DVP-NS57P DVD player, The disc doesn't spin unless I give it a light touch; then it spins, reads and plays fine. If I stop it, eject it and reload it, the same thing happens again and I...
Problem seems with spindle motor that needs little bit lubrication of WD40 contact cleaner spray.
Let me know if you are willing to take apart dvd player and have WD40 spray.
Thanks.
Jul 29, 2011 | Sony DVP-NS575P DVD Player
Getting "can not play disc" message from sony DVP-NS725P dvd player.
Have you tried taking off the cover to see if the disc is spinning inside when you get this message? The motor that spins the disc could be shot.
Sep 04, 2010 | Sony DVP-NS725P DVD Player
Sony DVP-NS325 "Cannot read disc"
there is some problems with your optical lens that is why not spinning or reading data on disc. before change the lens adjust first the two trimmer for DVD and CD adjustment for laser beam.
Sep 09, 2009 | Sony DVP-NS325 Multi-disc DVD Player
My Sony DVP-cx995v stopped playing DVD's
I had the same "Cannot play" problem - happened suddenly, I don't think I was doing anything unruly at the time.
After checking repair (exchange) prices in excess of $250 from Sony, I decided to open the cover to see if I could see anything wrong - normally a futile exercise with electronics except that in the past I have cleared errant disks that have lodged themselves near the drive/player at the rear of the library.
Upon opening and watching the library try to load and play I noticed the drive itself was not spinning the disk once loaded. It would sit for awhile, thinking about it I'm sure, then would unload and load the next dvd, again failing to spin.
I thought okay, maybe try to spin the dvd while in the player to see if it's jammed or otherwise hard to turn. It was not hard to turn and spun freely. In fact, when I put my finger through the hole at the exposed side of the player at the hub to spin the dvd, clockwise, it suddenly started to spin - and play!
I put the whole thing back together to test and all seems to be working fine at this point. Not sure what would cause the motor to stop spinning and remain in that state through poweroff/on cycles etc. but I'm sure this is not the last time I will have trouble of this kind.
I would note that when replacing the library back in its home on the shelf, be careful not to tip the library, especially toward the player area because the disks will spill out of the carousel near the player and become jammed when you power it on and attempt to load. A final tip of the library away from the player area may clear this if you hear the disks rolling out of their slots and you don't want to open the top again (it's a darned heavy box when fully loaded).
Jan 05, 2009 | Sony DVP-CX995V Multi-disc DVD Player
Won't play any media types
The unit probably needs a spin motor. It apppears sony got the lowest bid from Alps ON their spin motors. It needs to work flawlessly in order for the laser and the A/D converter to process digital information. The spin motor itself is relatively cheap. It is the labor that is involved in replacing it that is the real issue. In a multiple disc unit there are timing issues, which sometime can be challenging. In this particular case it would probably be cheaper to replace the unit than to take it to a local service center and get an estimate for $20-40 and tne be told that the unit cost $200 dollars to be repaired. Scrivitron Take the estimate charge and apply it toward the purchase of a new unit. Scrivitron
Jun 17, 2007 | Sony DVP-CX860 Multi-disc DVD Player
Sony DVP-NC675P Multi-disc DVD Player Logo
278 people viewed this question
Top Sony Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
