Question about Hotpoint NVL333EY Electric Dryer
Hotpoint tdc 30 door catch will not push into door switch when I close door, have taken switch out and it fits into catch manually but not when it is installed so door will not close to activate drying
  • Hotpoint Master
  • 3,463 Answers
I would say that the problem is due to the door handle spring being weak or broken.
Purchase a door handle kit, and it should solve the problem, if it does not, then you need a new door switch.
Hope this helps with your problem.
Posted on Dec 09, 2009
My interior lights won't turn off and kills my battery where's the fuse or how do I fix it?
It appears that one of the door operated switches for the interior light is making contact even though the door is closed. This is indicated by the interior light staying on. It could also be that the "Off/ Door/On" Control switch on the main interior is faulty. Check each door switch by operating manually with finger with door open to see if light goes out.
It this check makes light go out then it could be that one of the door catches is slightly out of adjustment allowing door to sit slightly away from body. Try checking each door for a loose fit by pushing the closed door in and observing if interior light goes off, especially the driver's which gets the most use. There should be only a little movement as the sealing rubbers are squeezed a little more. If door catches are tight then it may be that the rubber pad attached to the door that pushes on the door switch button has compressed and is allowing switch to make contact. If these checks don't produce results then there could be a problem with one of the door switches being faulty and making constant contact.
Dec 19, 2010 | 1988 Lincoln Town Car
2000 Mercury marquis dome light comes on in middle of night and will run battery down. What is problem? Thanks
It appears that one of the door operated switches is making contact even though the door is closed. This is indicated by the interior light coming on. It could mean one of the door catches is slightly out of adjustment allowing door to sit slightly away from body. Try checking each door, and at same time observing dome light, for a loose fit by pushing the closed door in, especially the driver's which gets the most use. There should be only a little movement as the sealing rubbers are squeezed a little more. Adjust catch if necessary. If door catches are tight then it may be that the rubber pad attached to the door that pushes on the door switch button has been compressed slightly and is allowing switch to make contact. Check rubber for an indentation and either put some packing behind it or replace.
Oct 28, 2010 | Mercury Marquis Cars & Trucks
Door ajar light is on but all doors are closed? Havent checked anything aside from shutting all the doors. Its a 2003 vw jetta gl 2.0l 4cyl. Not sure why the door open light in the driver panel stays on
It appears that one of the door operated switches is making contact even though the door is closed. This is indicated by the door open light coming on It could mean one of the the door catches is slightly out of adjustment allowing door to sit slightly away from body. Try checking each door for a loose fit by pushing the closed door in, especially the driver's which gets the most use and see if the light goes out. There should be only a little movement as the sealing rubbers are squeezed a little more. If door catches are tight then it may be that the rubber pad attached to the door that pushes on the door switch button has compressed and is allowing switch to make contact.
Oct 26, 2010 | 2003 Volkswagen Jetta TDI
Hi, i have a hotpoint wf640 washing machine and i cant open the door.it seems like the catch has gone on the interlocking door as ive tried to push the door in but still no go. Is this something i can fix...
if there is water in the drum it wont open, so you need to drop the drain hose low to gravity drain....then the door should open. sometimes this fault is due to a broken door catch utube is quite good for fitting help.
Jan 08, 2018 | Hotpoint First Edition FEW12 Front Load...
Im having the same an issue with my Kia..the dorr light comes on and makes a beeping noise while driving.. i was wondering how i could fix it. Any suggestion would be helpful. Thanks
It appears that one of the door operated switches is making contact even though the door is closed. This is indicated by the interior light coming on and the beeping noise is alerting that the vehicle has a door not closed properly when the vehicle is in motion.
It could mean the door catch is slightly out of adjustment allowing door to sit slightly away from body. Try checking each door for a loose fit by pushing the closed door in, especially the driver's which gets the most use. There should be only a little movement as the sealing rubbers are squeezed a little more. If door catches are tight then it may be that the rubber pad attached to the door that pushes on the door switch button has compressed and is allowing switch to make contact.
Sep 16, 2010 | 2003 Kia Sorento
My door for a hotpoint ctd40 tumble drier wont stay closed. The spring latch seems ok but not holding dooe closed. Any ideas since it dont say anything in my manual about it and its 2 yrs old. cheers andy
Hi andy.
the fault is likely to be in the roller catch mechanism. Hotpoint have modified these. Part Number is C00257618.
It includes both door latch and catch.
If you have problems obtaining one please email me on: aardvark.repairs@btinternet.com or call me on 01733 307019
Regards
aardvark repairs
Nov 18, 2009 | Hotpoint Dryers
Oven will not come on to cook, it will come on in cleaning mode
I've seen this problem on my own oven. If yours, like mine, has a door that has a locking mechanism, the catch is most likely stuck in the locked position. The door still closes and the lever still moves (though it may be very stiff).
Take off the screws around the locking plate, manually push the catch to the open position, spray the catch VERY, VERY lightly with WD-40 and dry it thoroughly. Close the oven door and try the lever again.
At this point, it should move freely and your oven should be able to switch between LOCKED/Self-Clean Mode and UNLOCKED/Cook Mode. If it does still get stuck, you'll just has to a) try lubricating the catch a bit more or b) keep a screwdriver handy! ;)
Aug 05, 2009 | Hotpoint RB757 Electric Kitchen Range
Dishwasher door won't close
OUrs did the same, it was a tiny spring that needed replacing. We just turned off at mains, unscrewed front and took out the unit. Took broken spring out and found one at our local DIY shop. fitted and put back in. ALOT cheaper than replacing the unit!
Oct 20, 2008 | Hotpoint 24 in. FDW60 Free-standing...
WF860 Door stuck in closed position.
FIRST switch off and unplug.
Pull machine out and remove lid by undoing self tapping screws at the top back. May have to slide lid back a bit to lift off.
Internal catch mechanism will be reachable from top for manual release. You may need someone to push door inwards while you release catch.
Good luck
Dec 17, 2007 | Hotpoint Ultima WF860 Front Load Washer
Hotpoint NVL333EY Electric Dryer Logo
123 people viewed this question
Top Hotpoint Dryers Experts
Gerry Harvey
Gerry Harvey
shaun taylor
Are you a Hotpoint Dryer Expert? Answer questions, earn points and help others
