Question about HP Pavilion TX2000Z Notebook
When my screen is flip over, my mouse arrow icon will stuck on the corner of the screen. as if my arrow icon is continuously clicking the corner.
    Guru:
  • 1,481 Answers
Explain the issue in detail pls,
can u move the mouse pointer using an external mouse connected to ur USB port ?
Posted on Dec 09, 2009
How do i reboot my toshiba laptop?
Procedure to reboot your Toshiba laptop may vary depending upon which version of Windows you are using. Refer to the steps below that match your Windows version:
For Windows 8:
If there's a Power icon on your Start screen, tap or click it, and then tap or click "Restart". Else, follow the steps below:
1. Swipe in from the right edge of the screen, and then tap "Settings".
(If you're using a mouse, point to the lower-right corner of the screen, move the mouse pointer up, and then click "Settings".)
2. Tap or click "Power", and then tap or click "Restart".
For all other Windows versions:
1. Click the "Start" button
2. Click the arrow next to the Shut Down button
3. Click "Restart"
OR
1. Click "Start" button
2. Click "Shut Down"
3. Select "Restart" in the drop-down menu below "What do you want the computer to do?"
GuruAid.com
Jun 25, 2014 | Acer Computers & Internet
How to open unlock mouse pad
Click the Windows "Start" button in the bottom-left corner of your desktop.
Scroll up and click "Control Panel."
Choose the "Mouse" icon or type "Mouse" in the field in the upper-right corner.
Click the "Enter" button and then click the "Mouse" link.
Press the "Hardware" tab or the tab to the right of it that specifies the type of touch pad you have.
If you are under the "Hardware" tab, highlight the touch pad in the list of devices and click the "Enable" button.
If you are under the touch pad tab, click the enable button.
Click the "Apply" button and then click the "OK" button
or
Locate the function key on your keyboard (F1 through F12) that has an icon of a touchpad. This is often a rectangle with two smaller rectangles below it, representing the touchpad and its two buttons.
Press and hold the "Fn" key, usually found in the lower left area of your keyboard.
Press the touchpad function key and then release both keys. If this does not enable your touchpad, try holding the "Fn" key down and pressing the touchpad function key twice in a row.
Shortcut Key Method
Press the Windows icon key on your keyboard and hold it down until the Start menu pops up. If your keyboard doesn't have a Windows icon, press "Ctrl-Esc" at the same time.
Use your arrow keys to locate the Control Panel and press "Enter."
Navigate to "Mouse" with your arrow keys and press "Enter" to open the mouse control dialog box.
Then, press "Alt-F" together to access the tabs at the top of this box.
Navigate using the arrow keys to "Device Settings" or "Touchpad" or the similar option on your system and press "Enter."
Press the "Tab" key until the "Enable" option or a check box next to it highlights and then press "Enter." Press "Tab" again until you are highlighting "OK," and press "Enter." Your touchpad will be re-enabled.
hope this helps
Sep 22, 2012 | Computers & Internet
Hi EPSON STYLUS 1290 'Communication Error has occurred' Green light and red light (the one above the paper symbol) are flashing alternatively. Unable to run any utilities. Please let...
Turn the printer off and unplug it from the wall. Press and hold the power button for sixty seconds. Check the paper supply and make sure all papers are uniform and tightly in the incoming tray. Turn the printer on and check the print que on your pc to make sure there are not unprinted documents stuck in the que preventing normal function. If there are documents in the print que you will see a printer icon (picture) on the bottom right side of the screen on your pc near the clock area. Sometimes there is an arrow in this arrow which needs to be clicked on with your mouse to expand and see all icons. Click the arrow and if you see a picture of a printer or Icon, right click with your mouse on top of it and choose open all printers. If there are documents in this area, click on one and choose delete until all are gone. Then try printing again. This should solve your issue.
Sep 14, 2011 | Epson Stylus Photo 1290 InkJet Printer
How do i close window messenger so as i can install adobe flash player 10.2
find the picture icon for the messenger on the bottom right side of your screen near the clock area. Sometimes you will see a down pointing arrow instead. Click on this arrow to open the area and locate the picture of the windows messenger. right click with your mouse on the messenger and choose "exit" and this will close the program.
Mar 21, 2011 | Computers & Internet
Dont know how to control the volume, i cannot find my manual
Most of the time their are multiple ways to do this.
1. On the speaker in the lower right hand corner left click and a volume bar appears. Slide it up and down. It should be adjust to 75% IMO.
2. On your keys there should be symbols that look like speakers that should match the color of you "fn" key. Press and hold the fn key and then press the corresponding speaker key to increase or decrease the volume.
3. There may be a rotary volume control on the front of the laptop case. It's as simple as turning it to increase or decrease it.
On the volume bar in windows verify that the muted in unchecked.
Mar 10, 2011 | Computers & Internet
The arrow dosnot move (M105-s3041)
Lol. This happened to me about 6 months ago, Toshiba has a program called 'TouchPad' Utillity. Which basically enables you to turn ON/OFF the mouse pad, It's shipped with the operating system, Unfortunately if you do turn it off, The mouse pad won't respond and there is no way you can turn it back on, It took my 12 hours to figure this out,It was frustrating, You will need a mouse, Preferably a USB one, plug this in and go to your icon bar in the bottom right hand corner of your desktop screen and there should be an icon saying 'TOUCHPAD', Right click it, Go up and turn it back on, Then you will be back in business:)
Jan 04, 2010 | Toshiba Satellite M105-S3041Notebook
Icons in the screen cannot be directly pointed. "if you click a specific icon the other near icon will respond"
Go into the Display inside control panel. In the second tab, choose Calibrate screen. Once done, it should work properly
Jun 08, 2009 | Sony Ericsson P910i Cellular Phone
When browsing page goes very small in top left hand corner
this happen when you shrink the browser page and close it without maximized it.
open the browser page, click and drag the page to the left top corner of the screen (top left corner of the browser page is at the top left corner of the screen).
move the mouse to the right lower corner of the browser (the arrow will change to 4 direction arrow). click, hold and drag the corner to the lower corner of the screen.
close the browser.
the browser page should be full screen when you reopen the page.
Dec 30, 2008 | Microsoft Windows Vista Ultimate Edition
On my computer at home when I click on the icon for Yahoo or any other the screen appears in the middle and does not cover entire screen until I click on box at top right. It does this all the time. I have...
open the IE, click and hold on the top blue bar and drag it to the top left of the screen.
place the mosue arrow on the lower rigth corner of the IE, the arrow will turn into a double arrow, click and hold the "arrow" and drag it to the lower corner of the screen.
now you should have the IE full screen. click on the "close" upper right corner of the IE.
reopen the IE, you should have the full screen display.
if this help you solved your problem, please rated as "FIXYA"
Dec 23, 2008 | Toshiba Satellite A35-S159 Notebook
Flipped\upside down screen on my compaq
http://forums.techguy.org/tech-tips-tricks/336002-windows-xp-flipping-screen-upside.html
Windows XP: Flipping the screen upside down and back again
Once, at University, someone had flipped the screens of all the public computers (running on Windows XP) of the English Department upside down. The wallpaper, desktop icons, fonts, mouse-cursor and even the start-up screen...everything was displayed or moved upside down. People could not check out their e-mails or surf or do anything.
To reverse the upside down screen mode, press ctrl, alt and the up arrow (arrows console) at the same time; the screen will probably go blank. Turn off the monitor, turn it on again and the display will be normal again. If you possess a sense of humour or are antisocial, press ctrl, alt and the down arrow simultaneously, turn off the monitor, turn it on again and everyone (excluding the culprit) will be desperate --> upside down! Works for Windows XP Home and Prof.
Mar 31, 2008 | Computers & Internet
HP Pavilion TX2000Z Notebook Logo
228 people viewed this question
Top HP Computers & Internet Experts
pontelemon
pontelemon
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
