Question about Hunter 52" Ceiling Fan With Light And Remote Control
It's mod 23457-380 and you can hear the electrical contacts but it doesn't turn on or off, but the light still works
I have a kenmore stove model number 790,72403012 and 3 of the 4 burners are working. They all are getting a spark, but the front left won't fire up.
First, try to light the burner in question with a match. Just hold a match to the burner, then turn the gas on to low. If the burner doesn`t light, the problem is the gas supply to the burner. Next, lift the top cover and put the prop rod in the hole in the cover to support it. Hold a match to the left-front burner. Now, turn the control knob to "light". You should see the igniter spark and hear a snap. If this doesn`t happen, repeat this step with the left rear burner. If you hear the spark and snap.
If the igniter doesn`t work on the front left burner, but does on the rear left burner, the igniter does work. The problem is likely the control knob for the left front burner. The. Control knob includes the electrical switch the activates the igniter when you turn on that burner.
Jan 26, 2015 | Kenmore Kitchen Ranges
Laptop wont start.
Remove the battery and unplug the power cord for 5 minutes, put in the either the battery or the powercord and power on.
if it doesn't power on, make sure the charging light is lit on the front of the laptop when the power adapter is inserted and plugged in properly.
light blinking when you power on means battery low / no power.
If the problem doesn't go away you need to contact acer for warranty service if you are outside warranty contact a local repairer.
Jul 20, 2012 | Acer Extensa 5420-5687 Notebook
Makes a humming noise but doesn't turn
Try this, open the dryer door and hold down the door light switch. Turn on the dryer and press start.When you hear the motor humming, turn the drum clockwise with your hand to see if it will turn. If itruns, you have a bad motor and will need to be replaced. If it doesn't turn, something is jammedinside and you will need to disassemble the unit to find the jam.
Hope this helps.
Oct 31, 2011 | LG DLE2514 Electric Dryer
2002 hyundai Santa fe will not start. I turn key and starter turned for 3 seconds then stopped and now when i turn key NOTHING. I hear a circuit sound in back of car when i turn key but no other sound. ...
Definitely a starting system problem. That sound you hear in the back is the fuel pump.
Starting system circuit components (besides wiring harness)
1. Ignition Key Switch - closes the starter relay control circuit to energize the relay and close the contacts inside the relay (you can check this by locating the relay in the underhood fuse/relay box and have a friend turn the key while you listen/feel if the relay 'clicks'
2. Starter Relay or its Contacts
3. Starter Solenoid - pushes/pulls the starter gear into the engine's flywheel ring-gear and its contacts close to provide battery power to the starter itself.
4. Starter itself - poor brush contact with the armature's commutator will prevent the starter to spin/turn
If you are 'Electrically' talented, you can check to see if you're getting battery power to the starter solenoid by using a simple 12 volt test light/bulb. Connect one lead to the starter solenoid terminal and the other to chassis/engine ground and have a buddy turn the ignition key - if the light turns 'ON', then you know that particular circuit is OK but the starter solenoid is not energizing to push the starter gear into the flywheel ring-gear to turn the engine over. If it doesn't, the problem is elsewhere (wiring, starter relay, starter relay control circuit, etc).
You can have a qualified Hyundai Service Technician properly diagnose your vehicle. OR, you can Go to www.hmaservice.com and register your vehicle by VIN #.. you'll then have access to wiring diagrams, shop manuals, service bulletins, illustrations, etc.
Aug 25, 2011 | 2003 Hyundai Santa Fe
I have an Atwood electronic ignition 6 gal. water heater. When I flip the switch to light, I can hear the ignitor sparking but there is no ignition. How can I isolate the problem?
Use a multimeter or test light for 12volt DC, and check at gas valve for 12 volts when it is trying to ignite (you here/see it sparking ). If no 12 volts to there, it will not ignite because no gas is flowing through valve. Try removing the connectors on the circuit board/module ( with switch in off position ) and cleaning the board contacts with a pencil eraser, and spray WD-40, or preferably an electrical spray/contact spray on connector contacts and retry. Board, or module may be located outside , or inside on top of tank, depending on what year and set-up. If that doesn't work, there is a small cut-out enclosed in plastic sleeve right near pressure relief valve area, that looks like a resistor that may be faulty. Remove it from the circuit and try it then. Simply pull the wire off at thermostat, pull that out of the sleeve by disconnecting it from the female spade connector, then put female spade where it used to be on thermostat terminal. If it works, buy a new thermal cut-off. If all that is done and tried, and still doesn't light, replace module.
Aug 09, 2011 | RTO Atwood Water Heater - 6 Gal LP
Our Dualit toaster doesn't work. The red light doesn't work. I have changed the fuse in the socket with a working one. The timer turns normally. Yet none of the heating units heats...
You need to replace the timer-contactor. This part is acting both as timer and electrical contactor. It consist from electrical contact moved with springs on and off. Due to electrical load and extreme heat these contact have been tear out thus they can not contact properly and in your case they don't contact at all.
So from the web page of dualit or ebay you can order A new timer contactor and replace it.
Jun 12, 2011 | Dualit Vario 3 Slices Toaster
Maytag Mod. MDB4050AWW
Check inlet water flow. Clean the strainer located near the hose end on the machine.
Check the water pump and it's electrical connections.
May 27, 2010 | Dishwashers
How to modify ps2
The chip is nt pirated. The thing is it is a small chip that has to be installed with the main chip on motherboard where code has been installed. After installing chip, main chip can't recognize original code, thus copied PS2 media works on MOD Chip.The chip comes with many little wires. You can't install that. Go to a expert. It will take an hour to install. Feel free to ask any problem related PS2.
Thank you,KABIDkms_pb@yahoo.com
May 28, 2009 | Sony PlayStation 2 Slimline Console
My dryer doesnt heat.
hi there,
check the ignitor and the coils on the burner assy.
Sep 30, 2008 | Whirlpool LEQ8000JQ Electric Dryer
Dryers Logo
148 people viewed this question
Top Hunter Dryers Experts
Joe Paxton
Level 1 Expert
Paul Bade
Craig Butler
Craig Butler
Are you a Hunter Dryer Expert? Answer questions, earn points and help others
