Changing input frequency of Powerware 9315-80 Model 65 UPS
I have a UPS which is designed to work on 60Hz power supply but my utilty service provides power at 50Hz. The UPS gives an error of under cycle voltage and does not work. Please help me to put the UPS to operate. My mail account tanoli902@hotmail.com
  • sakhan Jan 20, 2008
    I have requested Powerware but they have not responded to my problem.
  • Jocelyn Viau
    Jocelyn Viau May 11, 2010
    For small UPS, there is no way to change the input frequency; a UPS is designed for only one. But with a high end unit like yours it may be possible, it depends on how the unit was designed.
    Have you tried contacting Powerware (www.powerware.com) and ask them the question?
    Scholar:
  • 60 Answers
Unfortunately, it seems that you UPS is mostly designed for 60 Hz. However, there seems to be an exception for 380-415V input / 380-415V output where 50 Hz is supported.
Of course, 380-415V is not usable for IT systems as is, you would then have to transform it back to 208V or whatever voltage your infrastructure is requirering.
Check out the table at page 2 of this document:
http://www.armspower.com/Products/Powerware/Powerware9315/Powerware®%209315-80%20UPS%20Data%20Sheet.pdf
One thing that is not specified in this document is if the UPS can be easily switched from one input voltage to another or if you need to replace some parts.
Hope this helps.
Posted on Jan 26, 2008
Model 9155 display says: "UPS
bypass is not available because your input is going in one phase rotation and the bypass is going another. Both input and bypass needs to be a clockwise rotation. A cheap phase rotation meter will fix this. Call me at Gruber Power Services for free tech. support 800-658-5883 x256 ask for Eric
Aug 23, 2011 | Eaton Powerware 9155 UPS UPS System
I need the electrical diagram of prestige ups 3000
Try the legacy products page on eaton.com/powerquality (go to products and services and then click on the legacy products link) or call 800-356-5794. http://powerquality.eaton.com/Products-services/legacy/prestige-info.asp
Jul 23, 2010 | Compaq Powerware Prestige 3000...
Where is the fuse inside the power supply model fsp200
The unit is only 200watt and the fuse cost about $2,Thats if there one built into it,
The replacement power supply is about $20-00 NZD
Probably 20minutes to fix (for a novice) depending on their skill level and tools available,
BEST ADVICE Replace it
Power is something you dont want to mess with because it can kill.
The power packs are replaceable but people arent.
Be very careful and dont mess with the power.
I am an Electrician and I respect power.Misterdj
Mar 24, 2010 | AOpen (FSP200-60SAV) 200-Watt Power Supply
The bypass mode indicator is blinking, what do I need to do?
my be its indicating that the bypass mode is not available because power input is not of range that the ups is designed to take, check the ratinng of ups and use amultimeter to check whether the input matches the input. also depending on the type of ups this could be a code for a fault. please avail the ups type.
Oct 13, 2009 | Powerware 9125 UPS System
Attaching a generator to Powerware 9120 UPS
Power ware has a powerpass bypass switch for $200.00.
There is two inputs on this bypass switch. One for power, and one for the generator.
One ouput for your UPS. There you have it... There is your soluiton. I might add one other thing called a Power Guard, PMM117, to monitor the power of the backup generator. The time delay of this device will prevent over current from cooking your UPS power supply.
They also have a Hardwired version that is more expensive for you 5, 6 ,10KVA UPS. So a automatic bypass switch is what you need.
Jul 15, 2009 | Powerware Invensys 9120 Model 1000i...
The UPS dont go to on batteri
Replace the batteries with new one then power the UPS without load for three hours or more so that the batteries can be charged. Then disconnect or switch off power to the UPS and observe if it will till be on using the batteries. If it will be ON then your problem is solved but if it goes off then your UPS is on BYPASS
Apr 09, 2009 | Powerware 9120 UPS System
Hi i jus need box and speaker specs for the dual 2 ohm 10pw3
General Information Manufacturer: Eaton Corporation
Manufacturer Part Number: 103004248-5592
Manufacturer Website Address: www.eaton.com/EatonCom/Markets/NorthAmerica
Brand Name: Eaton
Product Series: PW3105
Product Model: PW3105 700
Product Name: Powerware PW3105 700VA Tower UPS
Product Type: Standby UPS
Technical Information Plug/Connector Type: NEMA 5-15P
Receptacles: 4 x NEMA 5-15R - Battery Backup System
Switching Time:
  • 6 ms
  • 6 ms
Dataline Protection: RJ-45 Internet
Power Description Load Capacity: 700VA/420W
Input Voltage: 110V AC
Input Voltage Range: 0V AC to 160V AC
Output Voltage: 115V AC
Frequency:
  • 50Hz
  • 60Hz
Management Overload Protection: Circuit Breaker
Interfaces/Ports Interfaces/Ports: 1 x USB
Battery Information Batteries: Maintenance Free Sealed Lead-acid
Backup/Run Time: 3 Minute 420W Full-load
Physical Characteristics Form Factor: Tower
Dimensions:
  • 4.4" Height x 11" Width x 7" Depth
Weight: 9.7 lb
Miscellaneous Certifications & Standards:
  • Safety: UL 1778 3rd Edtion/CSAC22.2 No107.3, Designed to meet UL497A
  • EMI: FCC Class B
  • Software Included: Powerware LanSafe Software
    Green Compliance: Yes
    Green Compliance Certificate/Authority: RoHS
    Jan 22, 2009 | Powerware PW3105 700 (103004248-5501)...
    Powerware Personal 1000
    I hav a smart ups 1000 with 2 batteries are they wired for 12v or series for 24v?
    Jan 10, 2009 | Computers & Internet
    50Hz to 60Hz conversion
    Hi, Your idea is basically sound and should work as long as the UPS originally is designed to produce 240V 60Hz and has its own built in timebase. The reason is that the input as long as the voltage matches makes no difference (50 or 60 Hz). By design, the UPS converts the input voltage to DC to charge the internal battery. The battery then powers an electronic circuitry that produces the 240V 60Hz. The input is then isolated from the output in terms of frequency. This is a common design, however, there are some (not many) that uses for its local oscillation sampling from the source and therefore will replicate the input frequency to its output, but very rare; it's better that you know they exist. Hope this be of some help/idea. Post back how things turn up or should you need further information. Good luck and kind regards. P.S. The only problem with 50 and 60 Hz is heat buildup which is tolerable and still within safe parameters. The only time the 50/60 HZ makes a big difference is when motors are used, timers such as in the early designs of microwave ovens, washing machines, etc., pumps and other highly inductive consumers. Most electronic devices converts the AC input to DC and therefore the frequency has negligible effect. Of course others may see it differently.
    Sep 15, 2007 | Liebert UPStation GXT2700RT-208...
    Computers & Internet Logo
    128 people viewed this question
    Alun Cox
    David Payne
    David Payne
