Question about RCA D52W20 52" Rear Projection HDTV-Ready Television
RCA D52W20 will not power up
The power on LED lights up when my RCA D52W20 is first plugged then shuts down. It does not do this three times, only once. After about two minutes, the power on led will light for a few seconds when the power button is pressed and then go out. A visual inspection of the deflection board revealed CP 120 was swollen. CP150, 114, and 120 were removed and tested. CP150 and 114 tested good on a capacitor checker and CP120 failed the leakage test. All three caps were replaced. Symptom are still the same.
    Guru:
  • 1,738 Answers
It could be in the main board.
Posted on Dec 09, 2009
Rca d52w20 blinks 3 times, wont turn on
The set has a three strikes and you are out rule---tries to come on three times and then if fails, shuts down.
A short exists inside the set.
Mar 17, 2012 | RCA D52W20 52" Rear Projection HDTV-Ready...
Describe your D52W20 52 in. Rear Projection HDTV-Ready Television Problem the tv will not turn on the power light will blink three times then shut off
That could be caused by the CP150, CP120 and CP114 capacitors on the deflection board. Very famous issue. You can get the RCA repair kit by that same name from www.tvrepairworld.com which has the capacitors and the CD with repair instructions
Aug 27, 2011 | RCA D52W20 52" Rear Projection HDTV-Ready...
RCA D52W20 WONT TURN ON...GREEN LED ON /OFF THREE TIMES
LOCATION NUMBER CP114,CP150,CP140,CP120,CP130 ANY CAN BE BAD ALSO SOLDER LOOSE CONNECTION UNDER FLYBACK
Aug 28, 2009 | RCA HD52W58 52" TV
Rca d52w20
it should if you can get one most have been on back order. the board with the ihvt on it is the one to replace
Feb 23, 2009 | RCA D52W20 52" Rear Projection HDTV-Ready...
No power
it is the power supply no doubt whatsoever
Aug 18, 2008 | RCA D52W20 52" Rear Projection HDTV-Ready...
Rca tv
when it shuts down and you try to turn it on again does the led blink/ If so how many times does it blink? let me know and I will try to help you out with the problem. Also let me know does the picture do anything abnormal just before it shuts down?
Jun 09, 2008 | RCA D52W20 52" Rear Projection HDTV-Ready...
My RCA D52W20 will not stay on
Clicking sound is power relay engaging. If all systems are not functioning properly, unit will shut down to prevent further damage and/or fire hazard
Apr 12, 2008 | RCA D52W20 52" Rear Projection HDTV-Ready...
My rca model P60752EB does not turn on.
this particular rca also know as a itc222 chasis has a safety shutdown cuircit.. if it detect any problem. high voltage. over current over voltage ..one of 20 problems. it will shut down. if the unit tries to come on that idicates its more than just a fuse. first question u ask is after the set been unplug for 30 minites then plug back up does the set come on or try to come on does the led light flash on the front. does it try to come on 3 times then shut down. there is special diagnostic equipment techs used to read errors recorded in the processor.
Feb 01, 2008 | RCA D52W20 52" Rear Projection HDTV-Ready...
RCA D52W20 52" TV SHUTS DOWN AFTER A FEW MINUTES
this is the filment circuit having a problem. i think you will find it is a loose connection on a solder joint. Goodluck
Jan 16, 2008 | RCA D52W20 52" Rear Projection HDTV-Ready...
RCA D52W20 52" Rear Projection HDTV-Ready Television Logo
Top RCA Televison & Video Experts
jason
matt martin
matt martin
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
