Question about Berkley Twist Lock Rod Rack
I need a manual for a Berkley fs50 scale - Berkley Twist Lock Rod Rack
  • 10 Answers
Operating Instructions1
A. Powering-on the scale
1. Press and hold the POWER button for two seconds. Scale will perform a self-test by displaying four 8s for three seconds. When "0.00 kg" or "0 lb 0 oz" is displayed on the screen, scale is zeroed-out and ready for normal operation.
B. Normal Weighing
1. Hang fish on the attached hook. Weight is displayed in either kilograms or pounds and ounces.
C. Switching between unit weights
1. Press and hold the POWER and CHOOSE button simultaneously for three seconds. Unit will change from weighing pounds and ounces to kilograms and vice versa.
D. Taring Weights
1. Weigh a bag or container till its weight is steadily displayed on the screen.
2. Press the POWER button once. Scale will zero-out and show "0.00 kg" or "0 lb 0 oz" and is ready for weighing multiple fish together.
E. Holding a weight
1. With the weight displayed on the screen, press the CHOOSE button. This will hold the current weight and is indicated by displaying an H to the left of the screen. To unlock the hold, simply press the POWER button.
F. Storing weights into memory
1. With a weight in the hold mode and an H displayed to the left of the screen, enter the memory mode by pressing the CHOOSE button. While in the memory mode, pressing the CHOOSE button will allow you to navigate through ten stored memories. These are indicated on the left and numbered 0 through 9. There are also 4 letters that indicate other options. An A shows the average of all stored weights. An E displays the total and a C resets the memory.
2. To store a weight, simply hold down the CHOOSE button for three seconds. Weights will automatically store into one of the number registers. To see the numbers with their weights, simply scroll through the numbers by pressing the CHOOSE button as described above.
G. Resetting the memory
1. With the unit in the C mode, press and hold the CHOOSE button for six seconds and scale will reset memory and zero out. Press the POWER button and scale is ready to begin weighing again.
H. Powering-off manually
1. Press and hold the POWER button for 6 seconds.
Posted on Jan 02, 2010
  • michel6632 Jan 01, 2011
    Missing battery position positive at cover way or at botom way.
A Berkley fs50 scale shows Full i cant remove it.
Posted on Oct 05, 2010
Need Instructions on how to put together a Jardine Berkley 0303G00 crib but have no manual.
Try manualslib.com for assembly instructions, or MFG website, or email their customer service.
May 02, 2015 | Baby Gear
Scale BFM588 User manual
Although the HealthOMeter.com site no longer posts a user manual for the BFM588DQ-81 scale, they do have a different model scale, BFM955-60, instruction manual that will work for the BFM588 because all the setting buttons are identical. You can download the manual for free at their site. Go to the site, under "Service & Support" setect "Instruction Manuals", then select "Body Fat Scales". Once there, find and select the BFM955-60. It will open as .pdf document and you can save it to your computer and print it out. It worked for my BFM588 scale for which I had lost the user manual.
Nov 16, 2014 | Health-O-Meter Health o Meter BFM588DQ-81...
Jura fs50 - "Decalcify".
If you read the instructions in the manual (Page 6) it describes how to descale (de-calsify) the machine. You use a vicious liquid to be used with great care. If you lost your manual go to http://www.coffeesolutions.jura.com/home_coffeesolutions_x/service_support/download_guidelines_jura_impressa_s9otc_english.pdf
Mar 23, 2014 | Coffee Makers & Espresso Machines
Berkley poletap
Take a pet bottle of that size. Cut one side and put it around it and then make holes as requires and necessary
Jun 04, 2013 | Fishing
I can't get the light or the bell to stop flashig or ringing on the berkley pole tap.what do i do?
You MUST have the LED light facing down towards the reel when it is attached to the rod. If it is attached upside down with the LED facing up it will continue to flash or beep nonstop. The simple instructions for the Berkley poletap is -
1.Turn the unit to light or sound.
2.Cast your line,( it will blink or beep as you cast).
3. Set unit in rodholder or against chair,(Poletap will blink or beep about 12 seconds and then stop when still).
4. When a fish nibbles or strikes the poletap will alert with your setting of light or sound.
You may want to check out the new Berkley Poletap Pro, It has complete sensitivity settings for windy days and Tilt - angle for slow pull fish, high current and trolling mode.Awsome product!
Check it out at this Berkley site.
http://www.berkley-fishing.com/prod.php?k=299309&sk=299309&p=PURBAPPBA%20(11187809)
Oct 04, 2009 | Berkley Twist Lock Rod Rack
How do I clean the filter?
www.berkley.k12.mi.us/file_repository/id2651vt580%20manual.pdf
Look at maintanance - Cleaning or replacing the filters (page 49)
Make sure you also clear the "filter hours usage" indicator. It is in the same manual on page 48.
Mar 16, 2009 | NEC MultiSync VT580 Multimedia Projector
Need manual to reset scale to weigh properly
Either do a search for that particular scale brand & model, which should take you to the company, whom should have a manual on-line or go back under search and type in "users manuals". There should be several manual websites that come up. Just don't click on the websites that require money for their manuals, when you can get them for free at other sites.
Jan 21, 2009 | Taylor 5599 440 Pound Tempered Glass Body...
Berkley Twist Lock Rod Rack Logo
4,108 people viewed this question
Top Berkley Sport & Outdoor - Others Experts
Bill Eager
Are you a Berkley Sport and Outdoor - Other Expert? Answer questions, earn points and help others
