Question about Western Digital Protege WD400EB 40 GB Hard Drive
I get a clicking sound. and the drive is not being recognized when i look for it in my computer
  • Western Digital Master
  • 5,660 Answers
The click sound you hear, is referred to as
'The Click of Death'.
I would like you to view this,
http://www.youtube.com/watch?v=vbq8vfs1wYY
[REMEMBER, if you open the harddrive case, the hardrdive is now Junk!
Harddrives are assembled in a Clean Room. This area would make NASA jealous, with it's 99.9 percent dust free atmosphere.
Those who assemble the harddrive don a special suit, and then go through a corridor fitted with air jets. The air jets are at different levels, and direct jets of air to give one final assurance of cleaning.
Opening a hardrdive in any area other than a Clean Room, will cause it's demise]
Reasons a harddrive has the Click of Death.
1.Lack of power.
If you are referring to a WD400EB, you are referring to an IDE harddrive.
There is an area on the back of the harddrive, that has four pins for connecting a power cable.
If you view the back of the harddrive, you are looking at the connection pins.
All the way to the right, are the four pins used for connecting a power cable.
It could be that the 4-pin whitish Molex connector, has come loose from these pins.
A fairly rare occurrence, but perhaps someone has worked on the computer in the past, and the connector was not pushed on all the way.
Or, perhaps the connector did not fit tight in the first place. Moving the computer tower may have jostled it loose enough, so that it is not making a good connection.
The power cable itself going to the harddrive is bad.
Another fairly rare occurrence.
(This shows the whitish, plastic, 4-pin Molex connector that I'm referring to, and where it plugs into on an IDE harddrive,
http://www.playtool.com/pages/psuconnectors/connectors.html#peripheral )
If you look inside your computer, you may find a Molex connector that isn't being used. Unplug the existing one from your harddrive, and plug this one in.
All the Molex connectors you see inside your computer use the same color codes on the wires, and deliver the same voltages.
Doesn't matter if there is a letter/number code, on the side of the Molex connector. You can use any one you like.
(Red is 5 Volts. Yellow is 12 Volts. The two Black wires are Ground wires)
2.Integrated Circuit, (IC. Also referred to as 'Chip'), has failed on the hardrdrive.
On the bottom of a harddrive is a circuit board. There are IC's, as well as other electronic components.
Trying to diagnose which IC, or other electronic component that may have failed, is a waste of time.
Even if you see a failed component by obvious visual signs of failure, trying to replace it requires the correct tools, and lots of experience.
It would be more logical in this case, to find another working WD400EB harddrive, remove the circuit board of off the bottom of it, and install it onto the defective harddrive.
This way you can reinstall the harddrive, get the needed information off of it, by copying all needed personal data, and making a backup.
3.Lack of data being transferred back, and forth from the processor.
Check the flat ribbon cable which goes from the harddrive to the motherboard. These can fail, and will have no visual signs of failure. (Flat ribbon cable = Interface Cable)
The way to check the cable, is to replace it with a known good one.
4.The harddrive has reached the end of it's 'Life-Cycle'
All mechanical components inside a computer, have so many hours of usage. This is referred to as a Life Cycle.
Your Western Digital 40GB IDE harddrive has some age on it. It may simply be at the end of it's Life Cycle.
I don't know if you are aware of the following, due to not knowing your computer expertise. Please disregard the following if you are already aware.
1.Before opening a personal computer, the computer should be unplugged from power.
Not only does it insure your safety, but also the safety of the hardware components inside.
After you make your repair, then plug the computer in, and wait at least 30 seconds, before you turn the computer on.
2.ALWAYS TOUCH the metal frame of the computer case before reaching inside.
Your body carries Static electricity, and Static will fry out the hardware components inside your computer.
Advise work on a table. A bed, couch, or directly on a carpet floor are High areas of Static.
Should you get up and leave for any reason, when you return touch the metal frame again.
(Or wear an ESD wrist s-trap, and connect the alligator clip to the metal frame of the computer case.
Electro Static Discharge. Average cost is around $6)
Posted on Dec 09, 2009
  • joecoolvette
    joecoolvette Dec 09, 2009
    Just to make sure there is no miscommunication,
    The computer should ALWAYS be unplugged from power before reaching inside. It should be unplugged from power, before you touch the metal frame of the computer case.
    President:
  • 987 Answers
This is due to the motor failure in the hard disk drive ..if it under warranty please contact service center for replacement ..
Thank You ..
    Guru:
  • 1,738 Answers
I am sorry to report bad drive. Your head is not moving at all.
Western digital 250gb not recognized
Sounds like a MBR is corrupt.
Click on the link provided. It will explain on how to fix MBR (Master Boot Record) Hope it helps. Fix the MBR Guide for Windows XP Vista 7 8 8 1 10
May 14, 2017 | Computers & Internet
Clicking sound upon power up
If it is the hard drive that is clicking, you have a dead hard drive.
Mar 21, 2013 | SimpleTech Hitachi SimpleDrivell 2TB Turbo...
Hard Drive starts to engage and then clicks. Computer won't recognize the hard drive. Our other computer will not recognize the drive.
Hello
It sounds like the physical damage of the drive, if the hard disk in warranty period avail the warranty otherwise take it to the qualified technician for technical assistance.
Good Luck
Dec 18, 2010 | Western Digital My Book Essential Edition...
USModular Dragon Drive 2.5 just makes a clicking sound when plugged into the computer. Drive not recognized by OS.
The clicking sound you here is a sign the hard drive has physically crashed. If there is important data, consult a data recovery firm to try and retrieve what files they can- if there is modestly important data on the drive, try placing the drive in a freezer drive and place the bagged drive in the freezer for 48 hours. Once that is done, connect the drive- if it is recognized- BACK UP EVERYTHING YOU CAN. You will have only a limited time before the drive heats back up and likely recrashes the heads into the drive
I’m happy to help further over the phone at https://www.6ya.com/expert/susan_42b401e0b1603d8a
Oct 07, 2010 | US Modular Dragon Drive 40 GB USB Hard...
Hard drive clicks several times when turned on,
I have to say from the sounds you describe the Hard Drive is totally destroyed, the noises you can hear are the mechanical parts inside grinding and clanking together. If the information is critical it may be recovered by a specialist data recovery company, but we are talking £100's even £1000's to do the job, so otherwise I would suggest taking case apart and buying a new hard drive for it.
Sorry its not what you want to hear but it sounds very terminal to me.
The reason the PC can detect a device is that it can see the Interface card that sits between the USB port and the Hard Drive.
Mar 03, 2010 | Iomega 1TB Desktop USB 2.0 Hard Drive
Is not recognizing the device. it just clicks 3
the clicking sound you hear is the unit's heads , the
heads are worn and can not function anymore , how
old is this unit ? get back to me , I'll be waiting to hear from you David
Jan 18, 2010 | Western Digital My Book Essential Edition...
Lacie Hard Drive not being recognized on computer
If you are running Vista, You might be one of many people who are reporting an update that is causing some buggy behavior. Try this:
Connect the drive but do not Format the drive, right click 'my computer' then 'manage' go to 'storage/disk management' view the drives; your usb drive will not be allocated a drive letter. You can set one manually or leave it for about 2~5 minutes for one to be allocated auto. Each time you connect the drive you may have to do this.
Oct 10, 2009 | LaCie F.A. Porsche (301177) Hard Drive
Can no longer recognize my external hard drive
I cannot get my computer to detect my external hard drive. It worked fine before? Now i get this clicking sound.Please help.
Nov 15, 2008 | Seagate FreeAgent Pro - 500GB, 7200 RPM,...
Computer not recognizing my Maxtor hard drive
Andrew, That Maxtor drive sounds like it has finally died on you and being just an 80 gig drive means its really old. The systems failure to read the drive as your booting up is what's causing the long boot delay as the system will see the controller board of the drive, but your spindle motor on that drive is most likely dead and there fore you will not be able to access or read any of your data stored on that drive. Hope you had backups of important files.
Apr 15, 2017 | Maxtor OneTouch A01B080 80 GB Hard Drive
Computer won't recognize External hard drive
tru to see the driver , and make sure it's properly installed , by following this path
Right click on My computer >>Properties>> hardware tap>>device manager
then expand Universal Serial Bus Controller , if there's a yellow sign on ur device name , then right click and chose , install driver
Jul 12, 2008 | Acomdata Computers & Internet
Western Digital Protege WD400EB 40 GB Hard Drive Logo
234 people viewed this question
Top Western Digital Computers & Internet Experts
Arora Singh
Arora Singh
Alun Cox
Marvin
Marvin
Are you a Western Digital Computer and Internet Expert? Answer questions, earn points and help others
