Question about Whirlpool Dryers
I need the wiring schematic for a whirlpool imperial series dryer
    Sniper:
  • 71 Answers
Should be a small envelope or plastic bag inside the machine with the wiring schematic folded up inside. Often includes timer pin outs, and parts list. Usually inside the control panel, but sometimes elsewhere inside the cabinet.
Posted on Dec 09, 2009
SOURCE:
Whirlpool Imperial gas dryer won't heat up.
There are two thermal cutoffs. If you pop open the top of the dryer and find the heating element the bigger one is mounted directly on top of it and the other one is located below it. Those are the thing to check first. You can test with a multimeter set to test continuity. If those are bad that means that the exhaust vent is getting clogged. Those run about 34 bucks for the set. The other piece to check is the element itself. You can test that the same way. Those run between 50 and 70 bucks. Good luck.
Jun 28, 2012 | Whirlpool Dryers
My Whirlpool dryer LGT7848AQO imperial series does not heat up. HelP!
Check the fuse/circuit breaker box, you need 220/240V to heat the dryer. If there is proper voltage going to the dryer, then you will need to goe inside and check the limiters and element.
Feb 17, 2010 | Dryers
Whirlpool imperial series dryer heats not spinning
This problem is almost always a broken belt. Yes you can do it yourself.
Go to repairclinic. com and put in your model number for the exploded view of your dryer. Locate the belt part number and belt orientation.
Jan 03, 2010 | Whirlpool Dryers
Looking for the age of Whirlpool electric dryer model number LET7848AQO Imperial Series CleanTouch 7 cycle 4 temp.
Link Below will give you the ability to calculate your manufacture date from the letters in the SERIAL number.
Whirlpool Date Codes
Sep 09, 2009 | Whirlpool Dryers
I have a whirlpool Dryer imperial series. The piolit light is out. How do I re-light it?
Piolt light ??You mean glow coil,or is this a 37 year old dryer?Either way it lights by itself.
May 22, 2008 | Whirlpool Dryers
Dryer not heating up
did you un hook 1 side of the wire from each componted you were checking to prevent getting a false reading and did you check the thermal limiter on the heater housing the tiny disc with two wires on it and do you have the tech sheet for the dryer
Jan 26, 2008 | Dryers
Dryers Logo
402 people viewed this question
Top Whirlpool Dryers Experts
Sal De
Craig Butler
Craig Butler
Marvin
Marvin
Are you a Whirlpool Dryer Expert? Answer questions, earn points and help others
