Question about Olympus WS-300M Digital Voice Recorder
When i try to record I get this message "can't be inputted into memory
Hi! I have the same problem; have you get solution? I hope so!
Thank! Federicoaqui@yahoo.com
Posted on Apr 22, 2010
SOURCE:
I have a Sony JA3ES it want record in analog inputs.everything else works what would make this quit working.
I'll give you my best guess since I sold my JA3ES and am doing this from memory. Check your analog connector cables are good, be certain you have the input switch set to analog input.
Be certain you are not setting your inputs for the microphone jacks. If you are getting the error message din unlock the recorder is not getting the signal from the analog source.
It is possible to have damaged analog inputs on a used machine, but you have micorphone jacks and might get adaptor cables to hook your analog inputs in through the microphone jacks. Note this machine is old enough the microphones are 2 mono microphones left and right. If you want to use a modern stereo microphone you need an adaptor cable for that too.
If you try the above be careful as the mike jacks are really for mikes not what I mention, but it is a probable go around if your rear analog jacks are damaged for some reason.
Jan 11, 2012 | Sony Audio Players & Recorders
My FujiFilm FinePix F47 fd has an error message that keeps saying 'Read Error' Help Please!!!
The Read Error message displayed on the Camera when accessing the images which was not recorded correctly. This may also happen when the Memory Stick is corrupted to record or read the files. Please check if the message is displaying when accessing all the images. If it happens with all the images, then it may be an issue with the Camera or the Memory Stick.
To check if the issue is with the Memory Stick, try using a different Memory Stick and check if the message displays.This may also happen when an attempt was made to play back the image or the movie that was not recorded on this camera.
Try to wipe the contact area on the Memory Card with a soft, dry cloth. It may be necessary to format the Memory Card (Format option is available in the Setup 2 Menu of the Camera). If the message still appears, service may be required.
Thanks for using FixYa.
Jan 21, 2011 | Fuji FinePix F47fd Digital Camera
Unable to record
I was using my voice Digital Recorder VN-6200PC. I was recording a my lesson when the screen shows formatting, I immediately took out the battery as not to lose any data, because I was taping and it began to format and I lose the data I was recording. So this time I remove the battery. However when I put back the battery it began to say imput blocked. Please help?
Jul 18, 2010 | Olympus VN6200 Digital Voice Recorder
Message on attempt to record: 'input blocked'
I got this same message on my VN7000PC that I got in LIDL. The message appeared when I tried to record. I could not get it to go away. At the time I just happened to have 5 files in Folder A with lock on. I tried to remove the file locks. I got the same message "Input Blocked". That was a clue. Maybe it had something to do with the internal 1GB drive. I formatted the drive. The message disappeared and now I can record again.
HTH
Brian.
Jul 07, 2010 | Olympus DS-40 Digital Voice Recorder
I am getting 'input blocked' message on my VN-5500PC when I try to make a new recording. Please help.
Copy your audiofiles to computer then format your Olympus unit (worked on my VN-5500PC) After that you can use your unit again no "Input blocked" messages, sorry for my bad English
Jul 05, 2010 | Olympus Audio Players & Recorders
I'm getting a message "Camcorder not connected. I can't program any recordings
When this recorder reads 'not connected to camcorder' you are simply accessing the recorder's 'DV' input on the front panel of recorder. This 'DV' input is used with DV Camcorders, thus the message.
Simply hit the 'AUX' button on the remote control to access the recorders other inputs. It will cycle between-TUNER>>AV1>>AV2>>DV.
Depending on what you want to access or view and where they are hooked up to the recorder. The "Tuner" will access either your over the air digital channels or your basic cable channels when hooked up through the 'UHF/VHF' input on the rear panel.AV1 is input 1 on the back of the recorder. AV2 is the input on the front of the recorder. DV allows for a Digital Video Camcorder to be hooked up to recorder using a 'Firewire'.
Oct 29, 2009 | JVC DR-MV100B DVD Recorder/VCR
1726 does not record messages
System will not record messages
When memory is full, saved messages must be deleted before new messages can be recorded.
If RO (announce only) is selected, no messages will be recorded.
Jan 15, 2009 | AT&T 1726 Digital Answering Machine
Tascam dp-01fx
I am having pretty much the same issue....
Let me know if you found a solution.
Jun 04, 2008 | Tascam DP01 All-In-One Recording Package...
"Recording stopped. Record in internal memory"
This error message indicates that the memory card cannot be used to take videos. Change the storage location to internal memory. Use the memory card to store pictures.
Aug 29, 2005 | Kodak EasyShare C360 Digital Camera
Olympus WS-300M Digital Voice Recorder Logo
191 people viewed this question
Top Olympus Audio Players & Recorders Experts
pankaj rautela
pankaj rautela
leoz
Level 1 Expert
Are you an Olympus Audio Player and Recorder Expert? Answer questions, earn points and help others
