Question about Toshiba e-Studio120 Copier
Computer does not detect scanner - Toshiba e-Studio120 Copier
  • Norman Davis
    Norman Davis May 11, 2010
    what model machine is this?
  • Norman Davis
    is it connected via network cable or usb cable... ???
  • 86 Answers
Have you tried pre-installion of the drivers? Often times once loaded the scanner will then be detected once connected
Posted on Feb 11, 2010
DR-9080c Isn't being detected via USB
Uninstall the device driver, restart the Comp and reinstall the software. If the scanner is not detected, try inserting any working device on the same USB port. if it detected, thee could be problem in the Scanner, if the new device is not detected, then it may be port problem.
S. Mohan, India
Feb 07, 2013 | Canon DR-9080C Path-Through Scanner
> My computer does not detect my scanner >
Search on-line see if you can get an-updated driver for it. Some windows updates remove old drivers.
Apr 09, 2017 | Canon CanoScan N640P ex Flatbed Scanner
2002 pontiac Grand Prix GT Malifuction Indicator Light Circuit.
When the light is on, the computer has detected a problem that you need to know about. You'll need to use an OBD2 code scanner for your vehicle. The scanner will tell you what the computer has detected.
You can borrow, rent or buy a code scanner from most automotive auto parts retailers... some will even help you use the scanner and interpret the results.
Mar 20, 2011 | 1999 Pontiac Grand Prix
I tried installing the HP scanjet 5590 scanner on a pC but it jut shows that it is installing and stays there forever. Anyone knows ow to solve this problem? PLS help-thanks in advance.
1) HOW MUCH COMPUTER MEMORY DDR MEMORY DOES YOUR COMPUTER HAVE INSTALLED?
2) HOW MUCH FREE SPACE IS ON YOU CURRECT HARD DRIVE?
3) TURN OFF YOUR ANTI-VIRUS SOFTWARE AND SPYWARE DETECTORS THEN DO THE FOLLWOING:
A) UNPLUG SCANNER FROM COMPUTER
B) MAKE SURE THE ANTI-VIRUS AND SPYWARE DETECTION SOFTWARE IS TURNED OFF FOR THIS INSTALL.
C) INSTALL SOFTWARE FROM ORIGINAL CD/DVD
D) ATTACH SCANNER AND ALLOW IT TO DETECT THE SCANNER AND ALLOW IT TO SEARCH FOR BEST DRIVER.
E) IF THIS DOES NOT WORK THEN EMAIL ME AT RAFURMANEKJR@HOTMAIL.COM
Nov 25, 2010 | HP Scanjet 5590 Flatbed Scanner
Scanner cannot be detected
Probably did. Just run the installation again and whatever remnants of the old install should either be rewritten or deleted.by the install. Just give me a shout if you need further help
Jan 29, 2010 | Visioneer OneTouch 5800 Flatbed Scanner
Computer prints to hp 2575, but computer will not detect scanner and scanner will not detect computer. what to do?
open control panel and go to Scanners and Cameras check any scanner driver is there what .....try to use the driver if its not working install the all software for the printer and check ..............
Dec 14, 2009 | HP Photosmart 2575 All-In-One Printer,...
No detect hp scanner 2400 on vista 64bit
Make sure the scanner has power and if you are using a USB hub make sure it's powered as well. Also use a USB port from the back of your computer and see if that helps.
Jan 14, 2009 | HP ScanJet 2400 Flatbed Scanner
HELP! my computer cannot locate my scanner
When you downloaded the driver, did you make sure it was for the specific moder scanner that you have?
From the control pannel of your computer make sure that you added the cannon driver to the computer, you have to select
( ) cannon driver. I tmust be the spacific model name and number on your scanner.
The scanner must be on, so you can start test scanning . Why is not ON?
Finally after you done this avobe, If it doesn't work, the problem might be the cables.
Artgirl
Jul 12, 2008 | Canon CanoScan LiDE 25 Flatbed Scanner
Does not detect
First of all you have to uninstall your scanner software completely and to restart your computer with the scanner disconnected.
Reboot
install the scanner software exactly !!! as hp has recommended.
Reboot.
If there#s no success: I started in disassembling the scanner:
disconnect from power
solve 2 screws on scanner top
remove the glass cover
move the scanner slegde backwards to start position
assemble the scanner
power on etc.
then the same procedure as every ....
i.e. reinstall your hp scanning software
hope you hare successfull
Apr 23, 2008 | HP ScanJet 3200C Flatbed Scanner
Need software?
hi.... try to go to control panel and click on add printers and/or scanners....you hsve to check on the settings of your scanner and configure it...
Jan 07, 2008 | Microtek scanmaker 3840
41 people viewed this question
Top Toshiba Office Equipment & Supplies Experts
didi2005
jasbo
jasbo
Branko Djurdjevic
Branko Djurdjevic
Are you a Toshiba Office Equipment and Supply Expert? Answer questions, earn points and help others
