Question about Waring WMK300 Professional Belgian Waffle Maker
Waring pro waffle maker
I have had a Waring Pro waffle maker for 5 months. Today I used it but it will turn on but not heat up??
  • Anonymous May 03, 2009
    just stopped heating
    Problem Solver:
  • 18 Answers
I personnally just went through this.
If it is less than one year old, and you have the receipt, go to the waring site, and look up the nearest dealer for repair and bring it to them. They should be able to contact waring for you and get you a replacement.
My replacement had a silver body virsus the original black body. The shop told me they have yet had a customer repeat of this problem.
Posted on Apr 02, 2008
There are wires that are exposed because of poor wires that seem to crack under heat or oil or both I am calling the factory now that I have opened it up and found a FIRE HAZARD inside
Posted on Apr 21, 2009
Diagram to replace thermal fuse in wmk 300 waring pro
The most common reason for thermal fuse failure is running the iron with the top open, especially when set to a higher number (longer cycle time) and/or not flipping the iron over at the strart of a cycle.
Keep it closed except during the 10-15 seconds needed when adding the batter or removing a waffle.
Thermal fuse 240C often available on ebay 4/$2 or Amazon 10/$7-$10
Feb 15, 2014 | Waring WMK300 Professional Belgian Waffle...
I have a wwm200sa waring pro prof belgian waffle maker that will not get hot. The power light will come on but it will not get hot. Why?
HELP WWM200SA IS WAY TO HOT I HAVE IT DOWN TO 1 1/2 STILL ALMOST BURNED CAN SOMEONE HELP ME THANK YOU VICKY
Aug 02, 2011 | Waring Pro WWM200 Waffle Maker
Waffles sticking to waring pro waffle maker no matter how much spray I apply. Help! thank you
I have had a bad experience with some corn oil spray. The oil (and corn syrup) built up into a crusty and sticky layer. I had to use oven cleaner to strip it back down to the non-stick surface. Now I just use soybean oil with a natural boar's hair pastry brush. (Synthetic will melt!) I heat the waffle maker at the last moment possible. Heat turns oil into varnish. I oil the surface just before the first cup of batter. I like to scrub oil with the brush into all the dry looking areas. If your batter has 1 Tbs (soybean) oil per waffle, that may be all you need for the entire batch. Turn off the heat promptly. I don't wash the oil out of the non-stick surface unless it builds up.
Mar 09, 2010 | Waring WMK300 Professional Belgian Waffle...
Will not heat.
There is a thermal fuse inside the bottom half of the unit, enclosed in a white insulating sleeve. This appears to be the weak part of the circuit. A replacement can be found here on Amazon.com.
Aug 10, 2009 | Waring WMK300 Professional Belgian Waffle...
How do I season my Waring pro Waffle Maker?
Teflon coating does not to be seasoning , but you will need to use a spray shorting like PAM before you make each waffle
Feb 21, 2009 | Waring WMK300 Professional Belgian Waffle...
Waring Pro Waffle maker
Just spray the grids before each use with something like Pam, or put a thin coat of oil on them. I found it's better to spray before each waffle so it won't stick.
Heating element
Feb 25, 2008 | Waring WMK300 Professional Belgian Waffle...
Waring WMK300 Professional Belgian Waffle Maker Logo
418 people viewed this question
Top Waring Kitchen Appliances - Others Experts
jdtech
Robert Weir
Robert Weir
Level 1 Expert
Are you a Waring Kitchen Appliances - Other Expert? Answer questions, earn points and help others
