Question about Kenmore 24032\24036 Top Load Washer
Just recently, when the water valve that fills the washer closes, there is a loud bang. Otherwise, the washer works just fine. Is this a concern?
  • 15,935 Answers
This is called water hammer. It is from AIR in the pipes - and the valve on the washer slamming shut.
There are devices that install into your pipes called hammer arrestors.
Check with a plumber to have them installed properly.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question
Posted on Sep 15, 2010
I recently bought a fisher and paykel front loader washing machine and since it was installed it has created loud banging noises in my water pipes. Do you have any idea how I could fix this?
If you're willing to do plumbing work yourself, these and more will show you what to do.
Otherwise, a plumber will be needed to bring an end to the water hammer you are experiencing by installing an air dampener as shown below - kind of like a shock absorber on your car but in this case, the backlash of pressure is softened or eliminated by it or something similar.
Basically what's happening is the water valves are shutting off the water flow so fast, the water flow ends up vibrating the pipes and they bang against what they are next to.
Odds are you were experiencing it before but it wasn't bad enough to be noticed - I installed a set at my water heater and another set right before the water connections for the washer.
How to cure water hammer noise in your pipes
Noisy Water Pipe Hammering Tips Plumbing Maintenance and Repairs 25345028-0bjacsudnesclogzm4oikctc-3-0.png
Dec 30, 2014 | Fisher and Paykel Washing Machines
Loud banging noise Amtrol WX-203
either solenoid valve is closing or there is a large water hammer occurring
Apr 18, 2014 | Amtrol WX-203 Well-X-Trol Stand Well Water...
I have a Maytag A183 top loading washing machine. It recently starting making a loud buzzing noise when you first pull out the knob to start it. If you turn it off and on a couple of times, the sounds...
That loud buzzing noise is your water fill valve. First turn off the water valves to the washer and unscrew the hoses and check that the filters are not corroded or clogged. I had a maytag washer that was doing the same thing and finally the lid switch and timer had to be replaced. I would unplug the washer and remove the screws along the upper rear cover behind the timer assembly and check that all connections are secure. Unplug them then plug back in if neccessary. Then put the cover back on plug back in and try it.
If it still does it you might need the water valve replaced.
Mar 13, 2011 | Washing Machines
I have an LC front loader washer that has a water hammer problem when the hot water tries to fill the machine. It works fine with the cold water only. It makes my house pipes bang loudly and it is...
actually its a part that needs to be installed before shutt off valves you can find them at your local plumbing shopp lowes homedepot or menards or call a local plumber
Jan 23, 2011 | LG TROMM WM2688H 4.0 cu.ft. Front Loading...
Washer Won't Fill, New fill Valve, makes humming noise
Check your water level switch it may be showing full. If it is it won't fill. If you can set it on spin and run for 2 or 3 min. it might clear the hose from the tub to the switch in case there is too much water in it. Or you could pull the hose off the switch and blow in it to be sure it is clear. Sometime if it gets too much in it it builds up too much pressure and shows full.
Jun 09, 2009 | Washing Machines
Kenmore washer loud bang in spin
Great!! Thanks for the followup -- I mean really, thanks!!
May 02, 2009 | Washing Machines
Loud noise
The vibrating sound you hear could be due to "water hammer" when the fill valve tries to close against high water line pressure. I had that problem and solved it by putting a small valve in the line to the ice maker and closing it little by little until the vibrating went away. You know, the banging could also be water hammer. It only happens at night when the entire neighborhood is asleep and the water pressure is at its highest. You need to check this out because water hammer can be very destructive to the plumbing and the valve.
Tom
Sep 08, 2008 | Maytag MFI2568AES Stainless Steel Bottom...
NO cold water function here, all others fine!
check you have cold water present by cracking open the fill hose and see if a squirt comes out. (you may have the tap turned off by accident) put on cold fill and listen close to the water intake. you should hear a low humming noise which is the valve energised. if not, probability is that the cold water valve is open circuit
Apr 30, 2007 | Frigidaire FWS833A Top Load Washer
Kenmore 24032\24036 Top Load Washer Logo
122 people viewed this question
Sal De
fordexpert
Jim Goldsmith
Jim Goldsmith
