My receiver reads overload whenever turned on
    Genius:
  • 1,550 Answers
Check the audio amplifier IC´s maybe are on short circuit
Posted on Dec 09, 2009
When I turn on my receiver the "overload comes on ant it cuts off!
You were lucky the overload protection circuit kicked in, congradulation on finding it.
Mar 14, 2012 | Optimus STAV-3770 Receiver
Pioneer vsx 405 overloading whenever it turns on I checked the speaker wires and they are all OK.
vsx405 came error dc protection chacked all power transistors c2500 ,a1948 all ok i was disconnect dc detector wire then ok after few minutes one pair burned with c945100 ohms resistors that time not fix heat sink then all replaced power on error overload with speaker and without speakers also coming error disconnect ol wire no chang pease help any expert amplifiers thanks
Oct 27, 2011 | Pioneer VSX-405 Receiver
JVC 6010V shows zero on volume wont go up or down
This is a fault on the D/A digital / Analogue converter , The volume control being analogue is not processing the data in the cicuit and so there is no change in the level. This can be a fault in the IC - the D/A convertor IC which is not giving any response with the turn of the potentiometer. So check this within the amplifier ONLY if you are able to trace the circuit and replace the IC connected to the potentiometer.
Oct 21, 2011 | JVC RX-6010V Receiver
Stops working and reads Overload
hi there i have had this problem with technics amplifiers generally with them it was negative and positive mix up between input terminals for the speakers or in other case's running the amp with 2 many speakers.
eg. having 2 speakers Bi wired into 1 input making a 6.1 receiver into a 12.1 which makes the amp struggle causing overload or the worst case is a power unit problem.
Aug 01, 2010 | Panasonic SA-HE200 Receiver
My pioneer amp vsx d508 reads overload.what to do?
Sounds like a bad amplifier IC.
Unhook all speakers at the back of your pioneer. turn it on and turn down the volume. If it's no longer in overload you have a bad speaker or speaker wires touching somewhere.
If its still in overload it's prlobley a amp IC and will cost between $25-$60 just for the part if you can replace it yourself.
Dec 27, 2009 | Pioneer VSX-D508
Vsx-517 keeps going into overload mode!
Try this:
1. Turn off the receiver.
2. Disconnect all the speakers from the back of the receiver.
3. Turn on the receiver. Does it still go into overload? If so, it may need repair.
4. If not, turn the receiver back off and connect one speaker at a time and turn it back on.
Most likely one of your speaker cables is shorted out causing your receiver to get overloaded. Or, one of the speakers is damaged, having the same effect.
Apr 20, 2009 | Pioneer VSX-517
Sa-da8 overload and off
Be sure that the EQ settings aren't accidentally putting you over the top as far as demand is concerned. Bass-heavy material? Same conditions apply...accordianman
Jan 21, 2008 | Technics SA-DA8 Receiver
Amplifier displays "Speakers are overloaded" and switches off
Either the amplifier protection circuit is kicking in due to a fault, or your speaker wires are shorting. Could also be a fault in a speaker - shorted turns due to overdriving. Check amp with speaker leads disconnected, and if OK, see above.
Dec 10, 2007 | Panasonic SA-XR55 Receiver
Technics SU-G91 OVERLOAD PROBLEM
I had the same problem. As soon as the volume reached about 24db it would go into overload. I was able to fix it by soldering all the connections on the larger power module. The one connected the the heat sink. When I took it apart there where several solder points that had come loose.
Oct 10, 2007 | Technics SA-AX540 Receiver
Open Questions:
Televison & Video Logo
21 people viewed this question
Top Televison & Video Experts
